Nate rear - which direction?- Mtbr.com
Results 1 to 11 of 11
    rider
    Reputation: Swami Scott's Avatar
    I mounted my front Nate and it seems to make sense which direction to have the treads, I'll call it "speed" direction with the chevron v's forward. I'm not so sure on the rear. What's the consensus for the rear direction, "speed" or "traction"?
    Reputation: Johnclimber's Avatar
    I rode with the front on "backwards" and the rear on the normal way around and rode some very muddy local trails last week and it wasn't as sure footed as I'd of liked it to have been, in fact I was a ittle dissapointed.
    I swapped then around with the front on correctly and the rear on backwards and rode the same trails today but with even more mud and snowy slush and it was a different bike, it felt so perfect and it was the only bike of 40+ riders to clear several very wet and muddy climbs.
    It's the perfect bike for the trails now.
    will rant for food
    I run my rear Nate backwards.
    Reputation: ecub's Avatar
    My Nates are mounted with the rear backwards and the front's normal as well.
    - Ed
    2012 Trek Madone 6.7 SSL
    2013 Specialized Tricross Comp Disc
    2011 Trek Top Fuel 9.9 SSL
    2012 Salsa Mukluk 2
    M8 M12 M15 deez nuts
    Backward on the rear for my Nate.
    Donít frail and blow if youíre going to Braille and Flow.
    Reputation: yxan's Avatar
    I have mine mounted forward and so far so good, leaps and bounds better than the endomorph.
    Reputation: shiggy's Avatar
    Dec 1998
    Since there is no rotation direction arrow, is there really a backwards?
    I usually run tires in what Swami calls the "speed" direction, and I have the Nates mounted that way now. Will likely flip the rear to see if it will latch onto the rocks and roots better, not that I had much problem on the first ride.
    mtbtires.com
    The Dog.
    Reputation: Dogdude222's Avatar
    Aug 2005
    From another thread in which I posted:
    I was also concerned that the Nate in the "backwards" direction would suffer from the "release and buzzsaw" syndrome common to other Nate-like tires like Nevegals or Rampages run in the backwards configuration.
    After running the Nate forward in the rear for 3 weeks and backwards in the rear for 3 weeks, I can say for sure that backwards is far superior. Traction is considerably higher (if that's possible) in all situations (dirt, mud, roots, rock, wet rock, snow). Absolutely no buzzsawing, still a pretty gentle release when traction is lost. Cornering grip is no different that I can notice. Braking performance is somehow improved? I actually have much more difficulty sliding the rear, but I cannot figure out why that is. Rolling resistant is no different.
    Summary: Run Nate backwards in the back. You'll like him even more.
    rider
    So backwards it is to start. Thanks for all of the input.
    I have tried it "speed" right now.
    I will try it "traction" next time. I don't really think there will be a huge difference. If anything, the "traction" way might just cause more resistance. Thats my thoughts on the subject.
    NMBP
    Reputation: gfs69's Avatar
  1. Rear nevegal direction
    By jetpilot in forum Wheels and Tires
    Last Post: 06-03-2009, 01:55 PM
  2. Direction for rear WW 2.55?
    By dirtsurf in forum 29er Bikes
    Last Post: 05-22-2009, 08:38 AM
  3. WTB Weirwolf on Rear - Which Direction?
    By Mike679 in forum Wheels and Tires
    Last Post: 02-13-2009, 04:43 PM
  4. rear shock direction
    By saturnine in forum Shocks and Suspension
    Last Post: 06-05-2007, 08:02 PM
  5. exiwolf rear direction
    By canyonrider in forum 29er Bikes
    Last Post: 04-20-2005, 06:53 AM
