MWOD Moonlander crankset- Mtbr.com
Results 1 to 8 of 8
    Reputation: thickfog's Avatar
    Oct 2010
    Since the SURLY MWOD Moonlander crank has a 14mm longer spindle than the MWOD Pugs version, would it matter if I used it on a pugs? Other than increasing the q factor, is there an issue? Is it going to stick way out on one side? We''re only talking about 14mm about 1/2 inch, but that could be goofy.
    Trying to come up with a decent crankset solution and Pugs MWOD are not available yet unless I buy the old Mr. Whirly and new MWOD chainring set (antoher $100) and make my own. Looking at a $400+ crank set at that point!
    CRAMBA Chairman
    aka bOb
    Reputation: bdundee's Avatar
    You could check into Fatbacks new crankset, I think that one is $250.
    Talk to Ben Witt @ Milltown Cycles about the Origin8 crankset. Much cheaper and it seems to accomplish similar results, all without using the overly complicated/heavy Whirly crank.
    Jason
    Disclaimer: www.paramountfargo.com
    Oct 2010
    Thanks.
    I had come across this Milltown Cycles: Mukluks and 4.7" tires. but it looks like the Origin 8 crank has 29 and 44 tooth sprockets. I need a granny gear. Will the inner ring spot take a 22? Form other pics looks like the outer can obviusly take a 32, etc.
    On the blog he does say: "On the 2012 Mukluks you'll of course need a ISIS splined BB, and 22t and 32t cogs if you wish.This is of course all doable with a MWOD, these are just available now, are less expensive, and will require less changes to stock Mukluks to make this work. So, I suppose you can. Origin 8's website is horrible for info.
    CRAMBA Chairman
    http://forums.mtbr.com/fat-bikes/my-...uk-754183.html
    There's Ben's bike with the Origin8 crank with 32/22 rings.
    Jason
    Oct 2010
    Thanks for the help. You guys on the fatbike forum are great.
    Think I'll try the O8. I'll post my experience for others to learn from.
    CRAMBA Chairman
    Oct 2010
    Tapatalk test of carriage return.
    Test 1
    Test 2
    Test if quotes "" "word"
    CRAMBA Chairman
    Oct 2010
    Tapatalk pic test:
    CRAMBA Chairman
  1. any moonlander reviews yet?
    By saltyman in forum Fat bikes
    Last Post: 10-17-2014, 01:34 PM
  2. UK Moonlander delay?
    By motorman in forum Fat bikes
    Last Post: 11-04-2011, 02:21 PM
  3. Moonlander spotted
    By Lintott in forum Fat bikes
    Last Post: 08-25-2011, 12:00 PM
  4. Moonlander compatibility
    By western high plains in forum Fat bikes
    Last Post: 07-14-2011, 10:19 AM
  5. MWOD: The worst best thing ever
    By playpunk in forum XC Racing and Training
    Last Post: 06-01-2011, 06:24 PM
