Mulefut 80 tape question- Mtbr.com
Results 1 to 13 of 13
    Sep 2015
    Looking to go tubeless with 26 mulefut wheels. My wheels are bare. I was going to go sunringle 78mm tape but all Im seeing is yellow...yuck.
    Where to find some color or even black?
    Ive never done a fat bike set...tape; stuff the right post ; set with compressor let rest overnight to get tape good and set; then deflate and add sealant... missing anything?
    2016 Remedy 9
    2016 Farley 7
    2017 Santa Cruz V-10 C
    2017 Remedy 9.9
    2017 Domane SLR 6
    Feb 2012
    Sun Ringle also sells black rim strips for those wheels.
    So you first put on the strips, then tape over the strip.
    That's what I did on my set, worked out great.
    Reputation: solarplex's Avatar
    Apr 2014
    You dont see the tape.... you need a rim strip first. Tape is inside tire.
    Fatbike, XC bike, Gravel Bike....
    Feb 2006
    If you don't use a rim strip first you will probably be able to turn the hourglass upside down, and your set-up will fail into the first ride about the same time the sand runs out.
    Reputation: BlueCheesehead's Avatar
    Generally you will want to cut the rim strip so that it extends only about 1/4" past the edge of the cut outs or spoke holes. That give the tape more rim to adhere to, thus a longer glue path that the air would have to make it through.
    There is a good thread called "Tubeless Tuesday" that will tell you everything you ever wanted to know about tubeless and more. You will find many opinions as there are different methods/materials, but you will find common themes.
    Mulefut are excellent rims for tubeless so 3/4s of the battle is won.
    Reputation: Swerny's Avatar
    glad to see the others have this covered.
    Moving on.
    Mike
    Toronto, Canada
    2019 Scott Foil 10 Disc
    2019 Norco Search XR Steel
    2017 Trek Farley 9.6
    Sep 2015
    Rim strip ordered!
    Nov 2014
    There's a video by sun-ringle on youtube as well on how to tape
    Reputation: Teton29er's Avatar
    Great! I used this product just the other day and it worked perfectly.
    -Cut the black rim strip down a little as mentioned by others
    -I put the rims (without tires) on the upside down bike for application of tape. Pull it on tight and give it a good overlap.
    -I put in a tube and inflated to 25psi overnight and it really helped the yellow tape adhere tight to the rim.
    -Mulefuts are pretty easy to inflate tubeless, but I still needed to put a cam strap around the tire and inflate with a compressor to get the beads to seat. I had zero leakage of sealant anywhere and it held air 100% the first time!
    Good luck and have fun.
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    This tape is great stuff, miles better that any of the duct/gorrilla type stuff.
    I give my rims a scuff up to help with the tape sticking to them, then a wipe down to remove any contaminents. Trimmed rim strip on, then wide tape and finally I add a wrap of standard stans tape to each bead. This you can pull super tight and get the perfect seal for longlasting tubeless, even when tyre changes are required.
    Apr 2014
    Quote Originally Posted by Flying_Scotsman View Post
    If you heat gun that it will tighten right up.
    Reputation: watermonkey's Avatar
    Quote Originally Posted by solarplex View Post
    This works on the mulefut tape without shrinking it too far that it pulls away from the sidewalls in the beadlock channel? Cause if so, I'm doing this tonight.
    I would advise not taking my advice.
    Apr 2014
    Quote Originally Posted by watermonkey View Post
    Not really. Just takes the air bubbles out. You can also put a tube in over night and it will seal down.
  1. Mulefut 65 rim tape?
    By ShortTravelMag in forum Fat bikes
    Last Post: 10-23-2017, 09:44 AM
  2. Mulefut 50 SL tubeless taping question
    By triathloner in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 07-14-2017, 01:07 PM
  3. Mulefut spoke hole question
    By Shinkers in forum Fat bikes
    Last Post: 05-06-2017, 07:07 AM
  4. Tubeless ready Sunringle Mulefut 50; do I need to re-tape it?
    By joevdenne in forum Wheels and Tires
    Last Post: 04-14-2016, 01:48 PM
  5. Replies: 2
    Last Post: 04-12-2016, 02:07 PM
Members who have read this thread: 8
