Mudhugger Fat fender on Mastodon- Mtbr.com
Results 1 to 14 of 14
    Fat and bouncy
    Reputation: JackWare's Avatar
    Aug 2016
    No link to the company, just posting for info.
    As it's not specifically mentioned on the MH website if their Mudhugger Fat fits the Manitou Mastodon I emailed to check, this is their reply;
    Hi,Yes it does you can fit via the leg tabs alone or add new fitting holes to utilise the brace bar for extra support.
    Regards Bruce and Jay
    What a perfect waste of time
    fat guy on a little bike
    i use the RRP Fatguard. Got it from ChainReaction.
    Reputation: BlueCheesehead's Avatar
    I use T'aint Muddy fenders on the front and they work well. I flip it over so that the logo is on the bottom side.
    https://www.taintmuddyfenders.com/
    Reputation: kntr's Avatar
    Works fine
    Attached Thumbnails Attached Thumbnails Mudhugger Fat fender on Mastodon-img_e1101.jpg
    fyi, any fender that attaches to the mastodon arch and protrudes forward of the arch, WILL get broken off when the fork is bottomed out. i broke both of my RRP Fat Guards on both bikes hucking...
    you can only run a shorty fender, towards the back. I cut one of mine in half, and will test it tomorrow.
    Quote Originally Posted by Rodney View Post
    The same would be true with a Bluto except the rearward piece would brake off at bottom out, correct?
    I've run mine for 2 winters and I just run higher air pressures so I don't bottom the fork out. I don't ride the bike as hard in the winter as I do in the summer.
    Quote Originally Posted by BlueCheesehead View Post
    not sure, as i never ran a fender when i had a bluto. I do not think the crown goes past the arch on the bluto like the way it does on the mastodon. the Don' is essentially a guillotine when it bottoms out...
    Quote Originally Posted by kntr View Post
    i used to think the same, but squirrel when i see something shiny and BAM! broken fender...
    as you can see, the crown hits the fender before the fork bottoms out ~20mm suspension travel remaining
    i traced the crown where it hit the fender, then cut the line. I test fit it, but it still had some interference. i trimmed it till it fit.
    he is what is left of the fender back on the fork-
    fyi, i recycled the old fender, and fitted it to the rear of the bike. some colored duct tape to fix the damage and she was good to go...
    Fat and bouncy
    Aug 2016
    Thanks for all the info, I was about to order the mudguard and bonus points for using that tape
    Reputation: midwestxmike's Avatar
    Apr 2014
    Braaap!
    ^^^I was going to suggest Beaver guard also, just don’t expect the same delivery as Amazon, if I recall it took two weeks for me to receive mine, and I'm just over the border here in Michigan…
    Apr 2014
    Quote Originally Posted by tmbrown View Post
    I think mine took about a week, also here in Michigan.
    Braaap!
    Fat and bouncy
    Aug 2016
    Works fine
    How did you fit the Fathugger to your Mastodon as the tabs that the cableties go through don't appear to be the correct angle or long enough? TIA
    Quote Originally Posted by JackWare View Post
    I just cut 4 holes and put a sticker over the stock holes.
  1. Theoretic lightest weight fat bike with Manitou Mastodon
    By scottyferrari in forum Fat bikes
    Last Post: 11-29-2018, 08:57 AM
  2. Mudhugger with 2.8 tires?
    By Endless Trails in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 12-18-2016, 12:40 PM
  3. Mudhugger Mudguards
    By Legbacon in forum Components
    Last Post: 12-12-2016, 08:45 PM
  4. Mudhugger damage to Bronson frame
    By Ernest Becker in forum Santa Cruz
    Last Post: 12-11-2015, 04:55 AM
  5. Replies: 2
    Last Post: 12-26-2011, 01:19 PM
Members who have read this thread: 14
