Results 1 to 26 of 26
    Jun 2016
    Moonlander compatible frames
    Fellow riders!
    I have a complete Moonlander minus the frame. My frame was damaged beyond repair. Everything else has around 3-400 miles on it.
    Question, before I decide to buy another Moony frame...is there another frame manufacturer that builds a frame that may be compatible with this component group.
    Component Type Description
    Headset Cane Creek 40 1-1/8" threadless. Black
    Crankset & BB Surly Mr. Whirly
    Offset Double 22/36t
    Brakes Avid BB7 Cable actuated. 160mm rotors front & rear
    Brake Levers Avid SD-7 Black
    Rims Surly Clown Shoes Single wall aluminum. Welded seam. 100mm width. Black. With cutouts
    Front Hub Surly New Disc 135mm New model HU0207. Disc. 32-hole. Black
    Rear Hub Shimano XT 135mm M756. Disc. 32-hole. Black
    Tires Surly Big Fat Larry 26 x 4.7". Larry tread. 120tpi. Ginormous
    Shifters Microshift Thumb Shifters Model SA-109. 3 x 9
    Front Derailleur Shimano SLX M661 direct mount via Problem Solvers adapter. Top pull. Black
    Rear Derailleur Shimano Deore M591-SGS. Black
    Cog or Cogset Shimano HG-61 9-speed 11-12-14-16-18-21-24-28-34t
    Stem Kalloy AS-008 25.4mm bar clamp. 7 rise. 4-bolt face. Aluminum. Black
    Handlebar Salsa MotoAce 17 bend. Black
    Saddle WTB SST Comp Steel rails. Black vinyl. Feels pretty o.k.
    Seatpost Kalloy SP-342 27.2mm. 350mm. Black
    Chain SRAM PC-971 Silver
    Extras Surly stainless steel post clamp. 14g DT Swiss spokes
    Its just a bone stock Moony, one of the black sparkly models.
    Thanks in advance for any info.
    Aug 2010
    Since you have 135mm spaced hubs on Clown Shoes you'll need an offset frame so Moony might be your only choice.
    Why not get another Moony frame?....Great bike.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Yep. Or buy this:
    Pro Deal Purple Frameset Special (Color-Matched Fork Included) - Fatbikes
    And have your wheels re laced on to 197 and 150 hubs.
    I like turtles
    Jun 2016
    I probably will end up with another Moony, I already have a Pugsley and a Spec. Fatboy. I just kinda wanted to see if there was anything more exciting out there....
    Reputation: vikb's Avatar
    Quote Originally Posted by evad nosam View Post
    Lots more exciting is out there, but nothing with that specific wheel offset.
    If you are happy with the ML no reason not to get another. It may not be exciting, but it is a classic.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: bighit's Avatar
    it is a true classic. I am looking for exciting as well, but will hold onto my ML for a fat touring bike forever.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    MaxTheCyclist.com
    Reputation: mdilthey's Avatar
    Dec 2014
    I have a Pugsley, and I think the offset wheels have a certain charm to them. I really fell in love with the bike, and can't wait to ride it every day. It's replaced my entire fleet.
    Ultralight bikepacking and gear lists... MaxTheCyclist.com
    Aug 2010
    Quote Originally Posted by mdilthey View Post
    At first I didn't care for the offset rear on my ML, but now I love it. It's different and has personality. And uses cheap durable hubs.
    Since you have all the parts and the wheels to fit seems to make sense to stay with the ML. You may want to check to see if there are any good deals on ML frames out there.
    Jun 2016
    Ive been on the hunt for a ML frame for a long time. They just dont come up on the used market. I suppose Ill have to go down to the shop and ask.
    turtles make me hot
    I like turtles
    turtles make me hot
    I like turtles
    Jun 2016
    Its complete unfortunately...I just needs me a frame, 16". Here's what my current Moonie l frameooks like....yes, I like to go big.
    Attached Thumbnails Attached Thumbnails Moonlander compatible frames-20151111_083551.jpg
    Jun 2016
    Dang, that "18 is gettin there....come on 16"....
    Reputation: cassa89's Avatar
    Jun 2014
    Keep in mind, buying a new Moonlander frame set through a bike shop will include a set of rolling darryl rims too. Not a bad deal for $675!
    Here's the link to the info!
    Get Rad on the Cheap | Blog | Surly Bikes
    Surly Pugsley
    Surly ECR
    Jun 2016
    Cool, wonder what Id do with some rolling darrylls...
    Reputation: Velobike's Avatar
    Dave, that will polish out.
    I'd find a decent welder and get it fixed. Perhaps add a gusset.
    Repairs add character to a bike.
    Latitude: 5736' Highlands, Scotland
    turtles make me hot
    Quote Originally Posted by Velobike View Post
    I agree. Maybe even see if a tapered Paragon Machine Works headset could go in there.
    I like turtles
    Jun 2014
    Start building a second wheel set or sell them on ebay!
    Surly Pugsley
    Surly ECR
    Reputation: Kirkerik's Avatar
    Apr 2016
    A repair is definitely worth a shot!
    Feb 2015
    I found the offset wheels had no impact on riding. They looked kind cool but adjusting the brakes was not fun at all. That was one of several factors that pushed me to sell my briefly owned Moonie.
    Reputation: Junglejay's Avatar
    What happened???
    Quote Originally Posted by Junglejay View Post
    What happened???
    The front end fell off.
    Latitude 61
    Jun 2016
    Living in a union/mining community, I have access to some of the best welders in the midwest. Even though its easy to imagine welding this puppy back together, its not possible. The tubes are buckled a bit so the alignment of the separation is off, and the headtube angle would be nasty.
    Jun 2016
    J.r.a.
    turtles make me hot
    Surly did a blog a while back about cutting up an old frame and making wind chimes...
    I like turtles
    Jun 2016
    Yeah, done that before at the shop, we also made wind chimes from cogset sprockets.
  1. 26+ Plus compatible frames
    By seat_boy in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 04-09-2017, 02:22 PM
  2. List of 26+ compatible frames
    By ticketchecker in forum All Mountain
    Last Post: 07-18-2016, 09:10 PM
  3. 29+ & 27.5+ Compatible frames and tires
    By Toot3344556 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 04-25-2016, 01:48 PM
  4. Anyone sell Moonlander frames only?
    By hummbusa in forum Fat bikes
    Last Post: 10-28-2013, 09:58 AM
  5. 659b compatible FS frames.
    By Cycle64 in forum 27.5
    Last Post: 01-26-2011, 07:43 PM
