Modular fat/29" front fork and wheels package- Mtbr.com
Results 1 to 6 of 6
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Spam pass.
    Start with a brand new, never been ridden Maverick SC32 suspension fork.
    <a href="https://picasaweb.google.com/lh/photo/PcCFiTbxTe5nnR4dp2UOAQ?authkey=Gv1sRgCJGuwKDHxt2ha g&feat=embedwebsite"><img src="https://lh5.ggpht.com/_Z3iU73Uw_T8/S1kzbIWz4hI/AAAAAAAAS-E/WUSxaPiWAb8/s800/IMG_9088.JPG" /></a>
    10" of steerer tube.
    <a href="https://picasaweb.google.com/lh/photo/iGD4R_LrAhujeGA0NLs6xQ?authkey=Gv1sRgCJGuwKDHxt2ha g&feat=embedwebsite"><img src="https://lh5.ggpht.com/_Z3iU73Uw_T8/S1kzdtE5z7I/AAAAAAAAS-Q/tafu7mkyM5A/s800/IMG_9092.JPG" /></a>
    <a href="https://picasaweb.google.com/lh/photo/ZERCV92rnoWS85_xE-y8vQ?authkey=Gv1sRgCJGuwKDHxt2hag&feat=embedwebsit e"><img src="https://lh4.ggpht.com/_Z3iU73Uw_T8/S1kzfrQs8TI/AAAAAAAAS-Y/uxuivz3HOfQ/s800/IMG_9095.JPG" /></a>
    Dummy axle hasn't even been removed.
    <a href="https://picasaweb.google.com/lh/photo/mFmJDn3WNWHvBa3TBzJUsQ?authkey=Gv1sRgCJGuwKDHxt2ha g&feat=embedwebsite"><img src="https://lh6.ggpht.com/_Z3iU73Uw_T8/S1kzh_k1VEI/AAAAAAAAS-g/Vz9la3BKpVk/s800/IMG_9098.JPG" /></a>
    Worst thing you can say about it is that it has some fingerprints.
    <a href="https://picasaweb.google.com/lh/photo/z_i0uEFtf4YgbfREZIErjQ?authkey=Gv1sRgCJGuwKDHxt2ha g&feat=embedwebsite"><img src="https://lh6.ggpht.com/_Z3iU73Uw_T8/S1kzkEG0UnI/AAAAAAAAS-o/bnFlwaru3ss/s800/IMG_9102.JPG" /></a>
    I've already installed the travel limiters, so it's ready to run with the fat front or the 29" wheel included.
    Then add in the fat front wheel. Maverick front hub in 32h, laced to a Speedway 70mm rim with DT Comp butted spokes and DT Prolock alloy nipples.
    <a href="https://picasaweb.google.com/lh/photo/zB7QROvMigfcZuB2k26upA?authkey=Gv1sRgCJGuwKDHxt2ha g&feat=embedwebsite"><img src="https://lh5.ggpht.com/_Z3iU73Uw_T8/S1kzJYb6omI/AAAAAAAAS84/GzgTTvCvvYs/s800/IMG_9012.JPG" /></a>
    I created a rim strip out of alternating 'dots' of reflective and glow in the dark tape inside of each drilled hole. Then I backed them up with some Reflectix (on the inside--between rim and tube) to protect the tube from the nipple heads.
    <a href="https://picasaweb.google.com/lh/photo/MJvQ42I6buprNwGecBKRuA?authkey=Gv1sRgCJGuwKDHxt2ha g&feat=embedwebsite"><img src="https://lh3.ggpht.com/_Z3iU73Uw_T8/S1kzLrObGOI/AAAAAAAAS9A/751cQtFiiq8/s800/IMG_9024.jpg" /></a>
    I installed a crisp new Endomorph tire and a (light) 2.6 tube. Ready to roll.
    <a href="https://picasaweb.google.com/lh/photo/aLBGEBXRNhqBx9456uDOCg?authkey=Gv1sRgCJGuwKDHxt2ha g&feat=embedwebsite"><img src="https://lh6.ggpht.com/_Z3iU73Uw_T8/S1kzG9Yl0UI/AAAAAAAAS8w/lnWLgofPBd8/s800/IMG_9003.jpg" /></a>
    Lastly--the 'summer' wheel. DT Swiss 240s OS front hub in 32h. This has a DT/Maverick adapter axle. Knurling courtesy of Ethan Franklin @ Maverick.
    <a href="https://picasaweb.google.com/lh/photo/YglCENTOn74FnmCPB4_L1g?authkey=Gv1sRgCJGuwKDHxt2ha g&feat=embedwebsite"><img src="https://lh3.ggpht.com/_Z3iU73Uw_T8/S1kzphs35gI/AAAAAAAAS-4/v9395LzOBUo/s800/IMG_9111.JPG" /></a>
    Should you ever decide you want to use this wheel on other than the Maverick fork, it can be converted to QR, 9mm thru-bolt, 15mm thru-axle, or 20mm thru-axle. Those parts sold separately.
    Rim is a Stans Crest 29" in 32h, laced with butted DT Comps and DT Prolock alloy nips.
    <a href="https://picasaweb.google.com/lh/photo/I-I5rDuCuysDMpyKZf9qOg?authkey=Gv1sRgCJGuwKDHxt2hag& feat=embedwebsite"><img src="https://lh4.ggpht.com/_Z3iU73Uw_T8/S1kzsBMyp3I/AAAAAAAAS_A/QMG9O8OHp4E/s800/IMG_9112.jpg" /></a>
    I wrapped it with Stans yellow tape, inserted one of the NoTubes valves, slapped on a Bontrager Jones XR 29 x 2.2 Tubeless Ready tire, splashed in a little sealant, and pumped it up to 25psi. Beads seated immediately and it holds air perfectly.
    <a href="https://picasaweb.google.com/lh/photo/U7x5KTrcTFpC8KHqyaKAvw?authkey=Gv1sRgCJGuwKDHxt2ha g&feat=embedwebsite"><img src="https://lh3.ggpht.com/_Z3iU73Uw_T8/S1kzmYI05cI/AAAAAAAAS-w/7IYJWcDiLYQ/s800/IMG_9109.jpg" /></a>
    Both wheels were hand built by me, right here in my shop. Stress relieved and tension balanced, they are 100% ready to ride.
    Assuming you could even find all of the parts (good luck!), the MSRP on this package would be over $1500 and that doesn't include tax or shipping.
    Get the whole package here for $1025 including shipping/insurance to anywhere in the lower 48.
    Canada or Alaska? Sure, just plan to spend more on shipping.
    No lowball offers--it's already a helluva good deal. Thanks.
    PayPal preferred. [email protected]
    Cheers,
    MC
    Reputation: dRjOn's Avatar
    whoah.
    For a rock steady Gas Tank bag > the DeWidget
    bit.ly/BuyDeWidget
    https://www.instagram.com/drj0n_bagworks/
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Quote Originally Posted by mikesee
    Just built one of these up actually, damn are they light.
    Wait, doesn't this stuff go on the Moots?
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    I don't suppose you have a Larry you could throw on there instead of the endomorph (or along with the endomorph for an additional cost)?
    Quote Originally Posted by MendonCycleSmith
    That's what I was thinking.
    Aug 2003
    Are you suggesting that you've never come home from the store with a backup case of beer, or bag of chips, or carton of Nestle Crunch bars?!
