ML and E13 crank no match- Mtbr.com
Results 1 to 9 of 9
    Apr 2005
    Just wanna let you know that the Moonlander and the E13 crank do not match.
    The crank arm on the non drive side hits the chain stay. I tried maximum spacers, but it still hits it. A bit of a downer as this crankset set be back a few $$..
    I was aiming for a single ring setup with a full chain guide.
    Oh well, back to the drawing board.
    I've see e13's for sale online, and a few sites said that they were incompatible with the Moonlander. Looks like there's a Mr. Whirly in your future.
    Jason
    Disclaimer: www.paramountfargo.com
    Reputation: kreater's Avatar
    i'm in the process of building a ML as well. i did't want to run the the whirley cranks so i though i would try the FSA Fatback cranks. so far so good they clear the chain stays and since i am running the ML as a 1/10 and 4in tires looks like things will clear. not sure if it would work with BFL tires though. oh and rolling D rims.
    "Live dangerously and you live right."
    Johann Wolfgang von Goethe
    Reputation: HDTVdevil's Avatar
    Are there any cranks that are known not fit on mukluk Ti frame?
    Sent from my GT-I9100 using Tapatalk
    don't know about fit on the salsa. so far looking good for the ML
    which e*13 crank? i was thinking of the xcx+ single/double crank:
    i have been thinking about chain/tire clearance, and going to use the outside tabs if i had to. i'm planning on setting the moonlander up 1x10, and i thought the e*13 crank would work?????
    Reputation: thesilversurfer's Avatar
    Oct 2011
    When Pete built my Fatback this year he recommended the FSA Fatback cranks as they are wider than then the E13's. Awesome cranks, I highly recommend them.
