Mini Fork Fender?- Mtbr.com
Results 1 to 8 of 8
    MaxTheCyclist.com
    Reputation: mdilthey's Avatar
    Dec 2014
    Mini Fork Fender?
    Yo,
    I want to make my own mini fatbike fender to zip-tie right beneath my rigid fork. I am looking for a template but all I can find are 29er templates. Anyone have a fatbike template?
    Looking specifically for one that only covers 4-6 inches behind the fork, not in front.
    Nov 2015
    This guy has a template (scroll down to the pdf link):
    Fatbike Fenders ~ Fatbike Republic
    Feb 2012
    I would just buy some thick paper stock and keep cutting them until the shape is to your liking and then trace that to actual plastic sheet.
    Might take some time but won't cost much and will be how you like it.
    Based on 100mm hub fork and 150mm fat fork. I took the 29er template and folded it in half along the centerline of the bike. Traced 1/2 of it added 50mm of straight lines (perpendicular to the centerline of the bike) then traced the other 1/2 on the far end of the straight lines. You've now "widened" the original template to fit a fat bike.
    You can get fancy if you want but this gets the job done.
    Sep 2014
    I just bought a cheap plastic trash can and started cutting it bigger than it needed to be, test fit and then trimmed it till it was how I wanted. Poke some holes for zip ties and voila!
    It's about time to put the fenders back on now.
    I made one for the front downtube and the seat tube in font of the rear tire. The one on the rack is a Dave's Mud shovel. I dislike getting wet and cold.
    Sep 2014
    Oh, and you may want to rethink the part about nothing in front of the fork. With the one in my pic, I still almost run into stuff flung up from the tire with my face!
    Jul 2015
    These are mine, buy a $1 poly binder. Easy to replace and makes a front and rear set. Thin enough for large tires. Buy a $2, or $3 binder for ticker material. Dimensions might be a bit off, a few mm, depending on how well your printer is setup. Both are 600dpi for standard printer resolution.
    Mainly made these cause I find the Dave's Mud Shovels to be overkill for anything other then spring. Just need to keep mud out of my eyes, and a dry butt.
    Front
    Rear
    Install
    Aug 2005
    Marsh guard. A little pricey at $15 but it does its job.
    MarshGuard
    Vermonter - bikes, beers and skis.
  1. Carbon fork fender mount on a Fargo
    By YUKON CHARLIE in forum Salsa
    Last Post: 08-09-2015, 07:34 PM
  2. Replies: 2
    Last Post: 12-26-2011, 01:19 PM
  3. Fender with Fatback Carbon Fork?
    By bdundee in forum Fat bikes
    Last Post: 12-21-2011, 10:09 AM
  4. mini 2011 stumpy comp review and revelation fork not 140mm
    By darkest_fugue in forum Specialized
    Last Post: 11-30-2011, 04:33 PM
  5. Replies: 2
    Last Post: 04-02-2011, 10:10 PM
