Mastodon and tire size- Mtbr.com
Results 1 to 9 of 9
    I have a Standard pro mastodon 100mm. Don't tell anyone, but I am running a bud on it. Per Manitou's chart I am a rule breaker. Chart can be found here...scroll a little bit. https://509cycles.com/2017/05/09/manitou-mastodon-fork/
    No issues so far...am I risking my life? Anyone else risking their life this way?
    So I am planning on building a summer wheelset for my fat bike. Was considering 29+ until I was told I couldn't do that. How much taller is a 29+ than my 26 with a Bud. My bud on 80mm rims is taller then my 29er hard tail's wheels.
    “How inappropriate to call this planet "Earth," when it is clearly "Ocean.”
    ― Arthur C. Clarke
    Reputation: BlueCheesehead's Avatar
    i have the same fork and am running 29+ with 2.8 tires. There will be ample room for 3" tires.
    There is a lengthy discussion in the Mastodon thread.
    https://forums.mtbr.com/fat-bikes/ma...n-1039416.html
    Stubby-legged
    I wish we could boil down that thread to the most relevant info. Too much bs and infighting.
    I have the pro-std 100 and run a Bud on it.
    29+ wheels set waiting on dry trails with no snow.
    Sep 2013
    I've tested a 27.5 x 4.5 studded Gnarwhal(approx 1/4" larger in radius than Lou/Bud) at 15psi in a Mastodon 120 Pro Standard. Airing the fork down revealed that the studs literally just kissed the bottom of the crown. I run it without any issues...YMMV...
    The standard Mastodon will fit a 29 x 3 Chupacabra ( now called XR2) fine.
    The only tires I've tried that don't fit is the VeeXXL and the 27.5 x 4.5 Gnarwhal
    Once you compress the bottom out bumper, the tire will hit the crown....trust me on that.
    Just letting the air out....they barely clear.
    You can easily put a bottom out spacer in to make them clear....or just have enough air in it that it won't bottom out.
    Quote Originally Posted by BlueCheesehead View Post
    I actually have the 100 mm. I edited my original post. To confirm, you have the 120mm?
    ― Arthur C. Clarke
    Quote Originally Posted by urmb View Post
    Yes, I have the 120.
    "The mayor said:
    4 Days Ago
    You can easily put a bottom out spacer in to make them clear....or just have enough air in it that it won't bottom out.". Mayor is your fork a 120mm or ? Urmb
    I have both standard and EXT forks....and they are set at 120 or 130 ( depending on the bike). The travel doesn't matter ( unless you are removing spacers from under the bottomout bumpers)
    The 100 and up will have the same tire clearance.
    EXT will have 20mm more clearance.
  1. Manitou Mastodon?
    By Dnek1999 in forum Fat bikes
    Last Post: 4 Weeks Ago, 01:35 PM
  2. Manitou Mastodon for sale.
    By mikesee in forum Fat bikes
    Last Post: 11-09-2017, 01:51 PM
  3. Manitou Mastodon for sale.
    By mikesee in forum Classifieds
    Last Post: 11-08-2017, 07:36 PM
  4. Manitou Mastodon review.
    Last Post: 09-12-2017, 09:51 AM
  5. Sneak Peek at the Manitou Mastodon
    By Dougal in forum Shocks and Suspension
    Last Post: 05-06-2017, 11:18 AM
Members who have read this thread: 79
