Marge Lite Offset Spoke Length on Pugsley- Mtbr.com
Results 1 to 6 of 6
    Feb 2007
    Finally decided to upgrade the Pugsley with some lighter wheels. I've never had to calculate offset hub/rim spokes before. Would someone with experience building these could please confirm that I'm entering the dimensions correctly from the attached image?
    I haven't received the rims or the hubs yet, so just going from the dimensions I found online. I'll measure everything once I get it all in.
    Both wheels will be Marge Lite rims with Hoozer rear hubs. Sapim Race spokes and brass nipples.
    Larger image here: https://i.imgur.com/4c6V5b1.jpg
    Attached Thumbnails Attached Thumbnails Marge Lite Offset Spoke Length on Pugsley-4c6v5b1.jpg
    Feb 2007
    Just found this post Building a Pugsley fatbike wheel
    Looks like I didn't enter -12.5 for the hole offset in the original specifications. That was default on the freespoke calc. Are both positive values on that for non offset wheels?
    This seems better:
    https://i.imgur.com/079x9NX.jpg
    Attached Thumbnails Attached Thumbnails Marge Lite Offset Spoke Length on Pugsley-marge.jpg
    MaxTheCyclist.com
    Reputation: mdilthey's Avatar
    Dec 2014
    Bookmarking this for later, interested to hear some answers as I plan to build some wheels for my pugs.
    Ultralight bikepacking and gear lists... MaxTheCyclist.com
    Reputation: slower_than_u's Avatar
    Quote Originally Posted by norcom View Post
    To answer your question, yes. The image in your first post is what the spokes would look like if you laced your wheel using spoke holes on both sides of the rim. The values in the second image are right on the money.
    turtles make me hot
    Reputation: NYrr496's Avatar
    That length sounds right off the top of my head. The second pic is correct.
    What hub are you using?
    I like turtles
    Feb 2007
    I'm using the KOOZER hubs. There's a long thread on them here:
    http://forums.mtbr.com/wheels-tires/...60-919051.html
    They're pretty light at ~305g and cheap at $60. The 5 degree of engagement is also nice. Good thing the Pugsley can use two identical wheels if a one hub doesn't hold up.
  1. Maverick/Marge lite spoke length?
    By jjcarr in forum Fat bikes
    Last Post: 04-15-2014, 02:18 PM
  2. spoke length for hope marge lite combo?
    By cherrybomber in forum Fat bikes
    Last Post: 01-07-2014, 07:39 PM
  3. Spoke length Marge lite on a Lefty
    By Wombat in forum Fat bikes
    Last Post: 10-05-2013, 10:40 PM
  4. Marge Lite spoke tension?
    By Polk in forum Fat bikes
    Last Post: 02-17-2013, 06:37 PM
  5. Spoke Length Question, Enabler and Marge Lite
    By mtbboy2000 in forum Fat bikes
    Last Post: 02-08-2012, 07:42 AM
