Maintenance on Mukluk's KMC Z99 Zinc Coated RustBuster chains???- Mtbr.com
Results 1 to 3 of 3
    Reputation: ecub's Avatar
    So the Mukluks have the KMC Z99 Zinc Coated RustBuster chains. According to KMC's website...
    Our RB (Rust Buster) treatment is a coating of zinc and chrome, protecting your chain against rust, in fact it makes your chain resist rust 500 times longer than a regular chain. Our RB coating meets with the highest international standards on rust resistance.
    Furthermore, all models, except the Z51RB, have received a special thermal Long Life treatment to ensure maximum chain life.
    So, the next time you forget to dry your chain after the rain: don't worry... KMC RB chains can take it!
    I'm assuming, since the zinc is only a coating, that it will eventually come of, So is there any chain cleaners I should stay away from? I normally use a mix of Simple Green and water.
    I'm also assuming that the chain still needs to be lubed as normal. What type of chain lubes do you guys recommend for winter riding? I have all 3 White Lightning lubes.
    - Ed
    2012 Trek Madone 6.7 SSL
    2013 Specialized Tricross Comp Disc
    2011 Trek Top Fuel 9.9 SSL
    2012 Salsa Mukluk 2
    i heart singletrack
    Reputation: mgersib's Avatar
    Quote Originally Posted by ecub View Post
    I'm using my standard lube (Squirt) on my Mukluk's chain with good results and no problems.
    I like bikes
    I was thinking of swapping out my basic Shimano chain for a rust proof chain. It looks like KMC might be a good chain for salty conditions.
  1. Nickel Zinc
    By buddhak in forum Lights DIY - Do It Yourself
    Last Post: 08-20-2010, 04:30 PM
  2. Zinc anti-seize in NYC?
    By endurbuderi in forum Tooltime
    Last Post: 06-28-2009, 11:15 PM
  3. Question about Teflon-coated chains
    By djork in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-15-2007, 03:42 PM
  4. Vid found over on NSMB Zinc > you
    By pdirt in forum Downhill - Freeride
    Last Post: 11-02-2004, 09:50 AM
  5. IRD Teflon coated chains/cassettes
    By endurowanker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2004, 08:14 PM
