Lightweight / Drilled rims for AZ Desert?- Mtbr.com
Results 1 to 22 of 22
    Rhino
    Reputation: urbanseeds's Avatar
    Does anyone have any experience with lightweight or drilled rims for (Arizona) desert and singletrack riding. I never ride snow, and ride mainly rocky desert and singletrack...hard. I abuse my bike like I really hate it. I am using bomb proof Large Marges with no problems. I would rather not invest in a lighter wheelset, only to dent them up pretty bad.
    Any advice?
    I totally realize I am using the wrong tool for the job here. Save it. My wife rarely uses a screwdriver for it's intended purpose, but I don't yell at her.
    I'm a Target Too.
    Reputation: cendres's Avatar
    If you're under 2 bills, drill 'em. If you're over, drill 'em anyway.
    Dr Gadget is IN
    Reputation: wadester's Avatar
    Quote Originally Posted by urbanseeds View Post
    Any advice?
    Are your Marges scratched? Do they actually take hits? You most certainly do not want a wider rim, if you aren't riding soft surfaces - but there are strong, light trials rims that might suit you.
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
    Drilled double wall is a neat idea. Someone should do that for an 80mm rim.
    Reputation: lancelot's Avatar
    Great place to collect rocks.
    The LPG
    Rhino
    @wadester...I am scratching the Marges up a little bit. They take some dings from plowing through the rocks, but no dents. You are correct that I don't want wider rims, but I do ride lots of sandy washes in the desert, so I don't want a narrow rim either. The Marges seem fine, just little heavy after a long day and several thousand feet of climbing. I dent up my XC wheels pretty bad, which makes me a little cautious. I'm not a rockcrusher, weight in a 168, just stubborn and the bikes take a beating.
    Possibly consider a single wall non-drilled rim in similar width to the Marge. They should lighter and a little more durable. If you want to try the drilled route I have set of used drilled Speedway UMA II's 70mm rims in great shape that I could part with for a fair price.
    The LPG
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Any advice?
    You've already got the best tool for the job. Nothing else will hold up as well to what you're doing than the LM's you've already got.
    Reputation: lamard's Avatar
    Feb 2010
    those echo sl rear rims really aren't that light. The Atomz trials rim is lighter but only 48mm wide.I would suggest waiting it out and get a Marge Lite when they come out and maybe some folding bead tires
    your 29er may float over roots and rocks, but my superlight 26 just plain floats
    Reputation: singlespeedstu's Avatar
    Why not just drill you Marge's?
    2011_0212holeymarge0004 by singlespeedstu, on Flickr
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Yah, I vote for drilling out your current rims.
    Rhino
    Quote Originally Posted by mikesee View Post
    thanks. I'll just keep doing what I'm doing, and hit the gym. I guess when you stop worrying about the weight, it doesn't seem so heavy. Shut up and ride is what I'll do.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    How many grams saved by drilling?
    Losing Ground
    Reputation: Guipago's Avatar
    Feb 2010
    Hey Rhino, maybe your XC wheels wouldn't take so much abuse if you added some suspension. -JK
    Rhino
    Quote Originally Posted by Guipago View Post
    True, but I look so silly riding suspension.
    I saved around 250gms per rim,25mm holes on unbranded 80mm double walls.
    Rhino
    Quote Originally Posted by sfbp View Post
    Does the amount sand, rocks, mud, and dirt that you collect inside the double wall negate any weight savings?
    Reputation: shiggy's Avatar
    Dec 1998
    I just did my first ride on the fat bike with Large Marge DH rims, Nates, and the Surly inner tubes, on a wet root filled trail with STEEP ups and downs. The only time I thought about the weight was while loading the bike in the van.
    I would never drill a double wall rim for general trail use. Would just fill with muck.
    mtbtires.com
    Agreed! I tried un-holey Darryls in western Colorado desert/arroyos and they were way more "fragile" than the LM's ( I do weigh 225#'s).
    Drilled Marges, I think, would fill with small rocks and drive me crazy with noise.
    If you have the Marge DH's, maybe try the Marge XC's...the inner wall is drilled out to save some wieght.
    Tape over the holes.
    Latitude 61
    I'd say that I'd collect only a few grams of debris,although if its wet,a fair bit of water,no where near the 250gms of removed ally though !
    Feb 2010
    that's why singlewall > doublewall
  1. Drilled rims?
    By oldsnow in forum Fat bikes
    Last Post: 11-28-2010, 08:20 PM
  2. Presta tubes - Schraeder drilled rims
    By Ratman in forum Wheels and Tires
    Last Post: 08-24-2009, 11:01 AM
  3. Drilled out rims
    By IPA Rider in forum Fat bikes
    Last Post: 03-09-2009, 05:16 AM
  4. drilled rims
    By sean salach in forum Alaska
    Last Post: 12-06-2007, 02:47 PM
  5. Drilled out rims
    By Logantri in forum Weight Weenies
    Last Post: 04-07-2005, 09:05 PM
