Lets see some SS fatbikes!- Mtbr.com
Page 1 of 2 12 LastLast
Results 1 to 200 of 204
    Mar 2011
    I'm motivated to do my first bike build this year ..a SS 29er or fatbike so I need ideas and motivation.I love the clean,simple look of a SS fatty! Build lists and problems encountered would be appreciated.
    Reputation: Johnclimber's Avatar
    I ride single speeds and I ride a geared fat bike.
    I'd never consider riding a single speed fat bike on sand as there is so many different sand consistencies riding without gears will mean lots of pushing
    Racing Snake
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Are people using magic gears on the surly and fatback? I've got a just built up mukluk with an alfine tensioner, but the less chain links you use the further the top jockey wheel gets from the cog and the less chain wrap. Seems OK for now, but not ideal. Was planning on a custom EBB sandman but we bought a house and I ran out of money!
    The Pugs has horizontal dropouts ("track ends" not "sliders") that allow you to position the wheel for proper chain tension. I use a set of tug nuts to keep it in place.
    Quote Originally Posted by SSBonty View Post
    Are people using magic gears on the surly and fatback? ......
    Magic gear would work with a half link, fcebb or philcentric.
    spenardslugger2 by anrothardonn, on Flickr
    Doh two errors in one post! Forgot the pugs has ss dropouts, and didn't click Seans pic to spot that there was a very neat looking tensioner tucked away! How do you find that (DMR?) tensioner, and does it allow you to easily remove the wheel? (I had on old DMR that required lots of fiddling to get the rear wheel in and out, the alfine lets you drop the chain and pedal it back on.)
    The DMR is perfect in every aspect except removing the rear wheel. If you have to do that, it becomes a pain in the ass. It's simple, quiet while pedalling forward, low profile, and doeen't look half bad. I had to take a file to mine to get it to fit the beefy Fatback der. hanger, but that was a minor setup issue. I'm not a fan of chain tensioners with springs in them. If I was going to run a tensioner that pivoted, had springs and stuck out as far as a der, I would just use gears. For me, the only advantage to a ss is the elimination of the rear derailluer.
    I'm running the STS on my Sandman, too, and I concur with everything Sean says.
    I love my fatbike as a ss, by the way
    Reputation: Velobike's Avatar
    I'm running a magic ratio on my 907. This is it set up for a race.
    Although I have ridden singlespeed for decades, like JohnClimber I have found that gears are necessary for riding in very loose surfaces. Basically because if I geared low enough to ride the soft stuff, the gearing would be too low to actually ride there. (Talking about mud, soft snow, peatbog, etc)
    Latitude: 57º36' Highlands, Scotland
    Reputation: Big Hustler's Avatar
    Jan 2009
    Velobike,can we have more info and pics of those fenders?they look amazing!
    FAT since 09.
    Fatties are year round bikes!
    don't fear the barleywine
    Reputation: Moe's Tavern's Avatar
    Aug 2010
    magic-free!
    Quote Originally Posted by Big Hustler View Post
    Take a look at Toni Lund's thread - there's some interesting ideas there too.
    One comment on magic ratio - it's only good as long as the chain remains in reasonable condition, otherwise slack develops.
    Sean - sounds ideal apart from the wheel removal thing. I might have to play around with magic ratios, I've got a couple of SS bikes running like that at the moment, but didn't have any spare gears to try with on this one.
    Moe - is that some kind of eccentric rear axle? V cool!
    Aug 2010
    Thanks. It's not eccentric per se, but it's effectively the same. Photo is of the (working) prototype. Aesthetically and functionally, it's fine. However, now that I have a proof-of-concept, I plan to make another axle out of a stronger/lighter material. Doesn't offer much range but it's enough to give *some* flexibility in gear selection, and most importantly, it affords chain tension adjustment.
    Oct 2011
    here is my 1994/95? gt borrego hacked off the rear end, welded it back together and low and behold fatties fit fine.Its also single speed its the only way to travel.Lets see some SS fatbikes!-sdc1300069.jpg
    Quote Originally Posted by angryx View Post
    here is my 1994/95? gt borrego hacked off the rear end, welded it back together and low and behold fatties fit fine.Its also single speed its the only way to travel.Click image for larger version.
    Interesting - snowflake spokes
    Oct 2011
    unfortunately, spokes were alittle to long so I did what I had to. It gives it a different look than other bikes and it makes the wheel alot stiffer.
    That GT looks awesome.
    That GT rules! Standard BB width? No offset wheel with a 135mm rear hub? Elaborate, please!
    yes plese
    Ska
    Ska is offline
    Steel is real.
    Reputation: Ska's Avatar
    I know I've posted these already but thought I'd contribute to this thread as well.
    Here it is fresh from the build
    Another angle....
    And here is a short video clip of one of the early "test rides". Absolute blast for sure....... finding the gear a little too hot on really soft sand. At least for MY legs......
    <iframe src="https://player.vimeo.com/video/31827957?title=0&amp;byline=0&amp;portrait=0" width="400" height="225" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    Here's my crummy, slow-going blog The Slow Spoke if you're interested.
    Reputation: can't get right's Avatar
    May 2005
    Quote Originally Posted by Orkje View Post
    +1
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    ska, that video is awesome. Nice editing.
    Just a regular guy.
    Quote Originally Posted by Ska View Post
    I know I've posted these already...
    The Pug looks quite lean and businesslike in that colour.
    Have you weighed it?
    Oct 2011
    thanks for the interest in my frame. as soon as I have my 5 posts I can start my own thread and not jack this one. I will post more pics before, I painted the gt.By the way I did extend the bb. I will show you.
    Racing Snake
    Angryx, is that a standard BB, how did the chain line up?
    First SS snow ride.
    Attached Thumbnails Attached Thumbnails Lets see some SS fatbikes!-img_1797.jpg
    Quote Originally Posted by jncarpenter View Post
    jncarpenter,
    What make of high-flange front hub is that?
    Regards,
    Wilhelm
    after screwing around with a number of different internal gear hubs I've decided to turn this thing into the singlespeed that it always wanted to be.
    Attached Thumbnails Attached Thumbnails Lets see some SS fatbikes!-01-1-.jpg
    Reputation: thesilversurfer's Avatar
    Oct 2011
    I love the single speeds they look so clean and so much fun the ride
    Oct 2011
    Pugsley sizing and rules
    I know that this has been discussed off and on for ages but I'm a little confused.
    I'm about to buy a Pugs. I'm 6 feet tall and have a 33" inseam.
    On the surly site I'm between an 18" and a 20" pugsley. I ride a large (19") stump jumper and a 56cm road frame normally.
    I sat on both last week and both were comfortable but I understand from different forums that you should go smaller for the increased stand over height but what about overlap with the front wheel? I have size 9 feet (small i know)
    The guy at Bow Cycles said that I would be a 20" for sure but he didn't know about the need for increased stand over height with snow.......and also that your height will change with winter boots.
    I'm a bit confused guys and would love some input....... I wanna start fatbiking soon but I need to know what size frame I will need before I order.
    Richie
    Reputation: vikb's Avatar
    Quote Originally Posted by thesilversurfer View Post
    Richie
    Size the bike by the effective TT you need not by the standover.
    I've got no standover clearance on my Pugs and it's not an issue. I was out riding some techy trails last night with my Pugs and stopping suddenly, crashing, etc... I'm still a man today...
    I've had the Bow Cycle guys size me just by looking at me and every time it's been bang on.
    Besides if you go with their recommendation and you end up being unhappy they'll get you on a smaller Pugs. If you go against their recommendation and later conclude you need a bigger Pugs you'll be on your own.
    Safe riding,
    Vik
    www.vikapproved.com
    well,I tried to post a pic of my homebrew frankenfat,but as my post count is less than 10,I can't. :-(
    Quote Originally Posted by Wilhelm6 View Post
    jncarpenter,
    Regards,
    Wilhelm
    Chub hub, now made by Hive/E13.
    THX. Just found your thread "The PhatSchtickel!!!!" in the 29er subforum with plenty of pics including the Chub front hub by the HIVE. Nice built.
    Oct 2011
    The chub hub looks great!
    Thanks...that is a fun bike, and I decided to keep it...but the SS bike pictured above is the most recent build
    Mar 2011
    @ jncarpenter
    What kind of internal gear are you using? It looks very closed and fit
    Regards from Spain
    Reputation: Elderberry's Avatar
    Dec 2010
    Just SS'd my pug to lighten things up and see how it worked. Quite well is the answer!
    Look out honey, 'cause I'm usin' technology
    Reputation: 7daysaweek's Avatar
    Quote Originally Posted by ov3rm4x View Post
    @ jncarpenter
    Regards from Spain
    I'm sorry, but I don't think I understand the question...???
    Fatback
    Reputation: thirstywork's Avatar
    J Lackey's SS Fatback
    This is one the the sexiest bike we have put out, and rides even better than it looks. Can't wait to see John throw some power to it.
    Attached Thumbnails Attached Thumbnails Lets see some SS fatbikes!-john-lackey-ss-fatback.jpg
    Speedway Cycles owner http://fatbackbikes.com
    Dec 2010
    Whoa.
    Oct 2011
    I love that Fatback!…..what wheels are they?
    Oh damn.....
    Fatback
    These are a special project wheelset using the Uma III 90's.
    M8 M12 M15 deez nuts
    Quote Originally Posted by thirstywork View Post
    HOLY CRAP that looks awesome!!!
    Don’t frail and blow if you’re going to Braille and Flow.
    Dec 2010
    Am I really the first to ask what it weighs?
    What's it weigh!?!?!
    Oct 2011
    That is so sick……now where is Pete's number in Oregon…..I had it somewhere here…lol
    Fatback
    Quote Originally Posted by Elderberry View Post
    It's 27 1/2lbs. Still waiting on a few parts, so it's not quite where it will be. We're doing the new Middleburn X type cranks whenever they get done with the spindles. The Mr. Whirleys are loaners in the meantime.
    Reputation: maxus's Avatar
    what will be the chainline of the second ring ?
    Reputation: bprsnt's Avatar
    That is one badass bike
    I think I just did a little 'sex wee'.....
    Reputation: modifier's Avatar
    That seems kind of heavy. What does the bare AL frame weigh in at? The fork is just under 2 lbs right?
    With light parts what do you think you could get it down to?
    With Floyds on for fire roads
    24 hour racer
    Quote Originally Posted by tlupfer View Post
    smart move
    Addict
    Reputation: RENCRN8's Avatar
    Dec 2010
    First time out Feb.25,2012. Anyone else ride in the New Jersey Pinelands?
    Attached Thumbnails Attached Thumbnails Lets see some SS fatbikes!-100_0087.jpg
    Reputation: NOBBY605's Avatar
    Nice One Cog...love the coaster brake! We will have to get together for the W40.
    Quote Originally Posted by NOBBY605 View Post
    I sent you a pm on that.
    Bad cat!
    Reputation: montana_ben's Avatar
    Oct 2010
    Bumps...
    Fresh bikes, pics anyone? Planning my next summer singlespeed ride, it's definitely going to be fat, but...used pugs? 2013 Mukluk (alternator dropouts)? Anyone ever get a carver ti with slider option? Anyone ever bothered to check a magic gear on a '12 Mukluk? Or other frame? Want to keep my Muk 2 geared and more or less winter oriented.
    Thinking:
    Marge Lite/hope hub for wheels. Spacer kit or homebrew pvc, 32:21
    Nate 120 front, lightweight HuDu back
    E13 crank probably? Chainring?
    As many carbon bits as I can afford to throw at it (need fork, have bars...) Or possibly new aluminum fork from Beargrease?
    BB7s or Shimano SLX
    Thompson post/stem probably
    What's your ride...or dream?
    Oct 2011
    Reputation: drofluf's Avatar
    Dec 2010
    Here you go
    In It's Element by paulfulford, on Flickr
    And in a more urban setting
    Pugsley goes sightseeing by paulfulford, on Flickr
    If you need me I'll be at the bar
  67. #67
    Racing Snake
  68. #68
    Reputation: SeaBass_'s Avatar
    Quote Originally Posted by flashes View Post
    Deja Vu
  69. #69
    Mar 2011
    keep the pics coming guys im loving them .
  70. #70
    Oct 2011
    I...
  71. #71
    Oct 2011
    need
  72. #72
    Oct 2011
    to..
  73. #73
    Oct 2011
    post
  74. #74
    Oct 2011
    10 times
  75. #75
    Oct 2011
    before
  76. #76
    Oct 2011
    posting
  77. #77
    Oct 2011
    pho..
  78. #78
    Oct 2011
    ..tos
  79. #79
    Oct 2011
    Black Sheep - Snow Salamander
    68 mil BB - Schpumpf 2 Speed - Double Dingle Speed (Quingle?) - *not a single* - Haters gonna hate
  80. #80
    Oct 2011
    sorry about the large pics.... not sure how to scale them properly. Booo.
  81. #81
    Bad cat!
    Oct 2010
    I do love that purple beach pugs...
    And the sheep is nice, like that you can run a regular 68 bb, I wasn't sure if that was possible if you had a dedicated single (dingle, quingle) fat frame made... Interesssting....
    Mukluk, anyone? Tensioner, magic? I need to go play around with mine and see what I can see, my wife will kill me though she likes riding it and likes gears.
  82. #82
    Drew
    Reputation: wheelcool's Avatar
    Do any of you ss'ers ride on front range of co? I really want a fb but am not a fan of gears so I'm not sure a ss is doable on these bikes. Curious to hear your thoughts.
  83. #83
    Dec 2008
    Curious to hear the same thing. Would love to ride a Beargrease or Pugsley, but do not want the hassle of dealing with all of the gears. Wonder how the SS would do in Colorado in winter.
  84. #84
    Dec 2010
    Quote Originally Posted by SilverBullet View Post
    Never been to Colorado summer or winter, but ignorance has never stopped me chipping in
    Singlespeed will work fine anywhere, you'll need to find a ratio that works for your area trading off pushing uphill against spinning manically on the flats. It's really just a question of changing your mindset gaining simplicity against the greater flexibility that gears offer.
  85. #85
    will rant for food
    cjellmoney - I didn't catch your bike earlier. Holy cow. Slick.
    Is that a Schlumpf crankset hiding in there?
  86. #86
    Oct 2011
    here is a pic of a friends new pug and my bikeLets see some SS fatbikes!-brantford-20120929-00513.jpg
    I put a new chain on
  87. #87
    Reputation: Jstews's Avatar
    Oct 2011
    I like the yellow.
    Here's mine
    Pugsley by jstewse, on Flickr
  88. #88
    Reputation: jesusburger's Avatar
    Old School Purple Pug
    A few pairs of brake pads, one brake bleed, one chain, one ISIS bottom bracket and a new front tyre in six years of ownership! 36 spoke wheels still straight and true after much abuse.
    <a href="https://www.flickr.com/photos/[email protected]/8323250661/" title="Antoine - Crop by ibikenz, on Flickr"><img src="https://farm9.staticflickr.com/8364/8323250661_ba3ca0b56c_b.jpg" width="1024" height="682" alt="Antoine - Crop"></a>
    <a href="https://www.flickr.com/photos/[email protected]/8111154253/" title="Motorway Sound Barrier by ibikenz, on Flickr"><img src="https://farm9.staticflickr.com/8467/8111154253_87e91355a1_b.jpg" width="1024" height="768" alt="Motorway Sound Barrier"></a>
    <a href="https://www.flickr.com/photos/[email protected]/5208291941/" title="Furly Commuter by ibikenz, on Flickr"><img src="https://farm5.staticflickr.com/4104/5208291941_76135a3ba0_b.jpg" width="1024" height="763" alt="Furly Commuter"></a>
  89. #89
    Reputation: calzonical's Avatar
    Aug 2005
    Fatback SS
    With the lack of Snow in CO front range thought I'd try something different; that is as long as the knees hold up. Ended up with 34:21 by way of the yess.
    <table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/lRdDLzwZ1FYuEZyNj9L-RsRz1_cSnf6Lb-4k12ngV0I?feat=embedwebsite"><img src="https://lh3.googleusercontent.com/-4TMcqlXxRLo/URQOeXtN83I/AAAAAAAAAiU/l0BYnpAFTq8/s640/20130207_130117.jpg" height="438" width="640" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/115054835021648291848/Fat_n_Single?authuser=0&feat=embedwebsite">Fat_n_S ingle</a></td></tr></table>
    <table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/J_wO5alOE4yjrgAZeWF_LsRz1_cSnf6Lb-4k12ngV0I?feat=embedwebsite"><img src="https://lh3.googleusercontent.com/-8PE6LIoPyoM/URQOdvnIrrI/AAAAAAAAAiM/z7IfBe8dy-Y/s640/20130207_130035.jpg" height="385" width="640" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/115054835021648291848/Fat_n_Single?authuser=0&feat=embedwebsite">Fat_n_S ingle</a></td></tr></table>
  90. #90
    Nov 2008
    Not my fattest, but the Krampus holds up under SS fire:
  91. #91
    Reputation: dvo1's Avatar
    68 mil BB - Schpumpf 2 Speed - Double Dingle Speed (Quingle?) - *not a single* - Haters gonna hate[/QUOTE]
    Strange days, I was there the first time you stopped by on your ride home.
  92. #92
    Feb 2012
    image by Salomo_fin, on Flickr
    Fatty with Exzentriker and Turbine cranks for summer. 32-20 gearing seems quite ok. For winter, it's probably going to be 2x10.
  93. #93
    Reputation: DubzOxford's Avatar
    Nov 2012
    2013 Necromancer.
    Modified with Thomson stem, post, Devo saddle, Bob Keller fork, UL Knards with lightweight Quality tubes. 36 x 18 gearing. 30.5 lbs
  94. #94
    Reputation: coastkid71's Avatar
    SURLY KramPug
    KramPug NB Law 030 by coastkid71, on Flickr
    KramPug NB Law 016 by coastkid71, on Flickr
    KramPug NB Law 009 by coastkid71, on Flickr
    Film and some story of this bike
    <iframe width="560" height="315" src="https://www.youtube.com/embed/tVPEo3m4wRo?rel=0" frameborder="0" allowfullscreen></iframe>
    coastrider: SURLY KramPug... Meet The New Boss... Same As The Old Boss...
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
  95. #95
    Here's my PugSS - well kinda SS. It's dingled, 34x22 and 36x20. White Industries freewheels are awesome!
    <a href="https://imgur.com/orEm87m"><img src="https://i.imgur.com/orEm87m.jpg" title="Hosted by imgur.com"/></a>
    <a href="https://imgur.com/M1MSD8p"><img src="https://i.imgur.com/M1MSD8p.jpg" title="Hosted by imgur.com"/></a>
  96. #96
    Quote Originally Posted by mattgVT View Post
    Best bike-related $100 I ever spent!
  97. #97
    Does half-fat count?
  98. #98
    Reputation: Lone Desert Walker's Avatar
    Brakeless fixie in the desert
    Lets see some SS fatbikes!-photo.jpg Lets see some SS fatbikes!-s.jpg 30/16 fixed boooiiiiiiiiii!!!!!!!!!!!!!!! The cholla destroya
  99. #99
    Quote Originally Posted by Lone Desert Walker View Post
    Brakeless fixie in the desert 30/16 fixed boooiiiiiiiiii!!!!!!!!!!!!!!! The cholla destroya
    I like it.
    I suppose when all else fails you can find a nice soft cactus to crash into...
  100. #100
    Racing Snake
    That's nice. I was only thinking fixed fat the other day......
  101. #101
    Feb 2013
    Another angle....
    <iframe src="http://player.vimeo.com/video/31827957?title=0&byline=0&portrait=0" width="400" height="225" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    Great filming!
  102. #102
    nothing to see here
    Reputation: Stevob's Avatar
    Quote Originally Posted by Salomo View Post
    Nice. This will be almost a carbon copy of my build when I get approval. Maybe not green cranks though. Happy to hear the Exzentriker works with the Turbines too.
    I see hills.
    I want to climb them.
  103. #103
    Reputation: SSPirate's Avatar
    Oct 2011
    The Fat Pearl
    And with Black Sheep Bars
  104. #104
    Feb 2013
    Out of interest, how wide are those BS bars?
  105. #105
    FATBACK single checking in!
  106. #106
    Bump...
  107. #107
    Feb 2012
    Tubeless with Marge Lites and Knards. 32-18, with a 20t freewheel front cog for the extra climbing gear if needed. LOVE this bike.
  108. #108
    Would love your wheel / tyre combo. My fatty is pushing 36lb with the original Large Marge XCs and heavy tubes. Still love it though - 7 years of smiles and still going strong.
    <a href="https://www.flickr.com/photos/[email protected]/9385940781/" title="Poo Pumper by ibikenz, on Flickr"><img src="https://farm8.staticflickr.com/7422/9385940781_b22c9a2498_b.jpg" width="1024" height="683" alt="Poo Pumper"></a>
    <a href="https://www.flickr.com/photos/[email protected]/9714820768/" title="Even when life is shit, a ride on your bike is never a bad thing. Ride your bike every day. by ibikenz, on Flickr"><img src="https://farm6.staticflickr.com/5487/9714820768_680e90056c_b.jpg" width="1024" height="683" alt="Even when life is shit, a ride on your bike is never a bad thing. Ride your bike every day."></a>
    <a href="https://www.flickr.com/photos/[email protected]/10242933913/" title="Mt Albert Singletrack by ibikenz, on Flickr"><img src="https://farm9.staticflickr.com/8122/10242933913_bde0077896_b.jpg" width="1024" height="683" alt="Mt Albert Singletrack"></a>
    <a href="https://www.flickr.com/photos/[email protected]/10242880736/" title="Mountain Meadow by ibikenz, on Flickr"><img src="https://farm3.staticflickr.com/2888/10242880736_5ffc7aed9c_b.jpg" width="1024" height="683" alt="Mountain Meadow"></a>
  109. #109
    move on up...
    Reputation: Forged1's Avatar
    Dec 2011
    <a href="https://s59.photobucket.com/user/Metal_Morphosis/media/el%20mariachi/20131007_180636_resized.jpg.html" target="_blank"><img src="https://i59.photobucket.com/albums/g306/Metal_Morphosis/el%20mariachi/20131007_180636_resized.jpg" border="0" alt=" photo 20131007_180636_resized.jpg"/></a>
    32-20 for now! 34.5 lbs
  110. #110
    Reputation: sickmtbnutcase's Avatar
    Nov 2012
    I don't have a good pic of the School Bus in SS mode, but this late summer/early fall I switched my Pugs over to SS just to try it out. I didn't think it was possible to make a fatbike even more fun, but it is! It'll go back to geared for the winter though. Running 32x19. Swapped the axle in the Deore hub with a plain solid one with some good axle nuts and put a SS kit on it.. Hasn't slipped but I have some tensioners on the way just to be safe. Was considering just throwing a freewheel on the "front" hub and switching wheels front-back, but I really didn't want to run my Endo up front.
    I don't think I'll run it geared in the spring/summer/fall ever again. Even when my wife wants to ride it, she doesn't complain about it being SS either. I love her
  111. #111
    WNC Native
    Reputation: nitrousjunky's Avatar
    Haven't added mine to this, but here she is. 29.5 lbs and 30x20
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
  112. #112
    Oct 2011
    What is everyone running for their wide spaced rear hubs? is anyone making SS specific freehub or screw-on type wide hubs?
  113. #113
    nothing to see here
    I don't think anyone is manufacturing such a hub Cjell. Pretty sure the options are normal geared freehubs for 170mm or 135mm choices with offset frames. Please tell me you aren't planning to ride such a beast on the GDT next year!
    I see hills.
  114. #114
    Oct 2011
    boohoo
    My latest bike was stolen and I am building another. I was planning on jumping on the Super-Short Chainstay bandwagon for a few reasons including: It's popular/marketable, Don McClung does it, would be optimal for 29+ handling. Anyway, would like to find a way to push the chainline out without running a geared hub. Enter-wide SS hub...that doesn't exist.
    Maybe offset, maybe spacer on freewheel, or running farther outboard on a SS freehub. Just messing about on MTBR for now...
    Gone. I hope that dude is having as much fun being high as sh!t on crack as i had on the bike. It is technically SS and fat-ish. Anyway, building another.
  115. #115
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Quote Originally Posted by cjellmoney View Post
    I don't see any benefit to making a wide hub SS-specific. The hub flanges are already spaced so that the wheel is stiff. Pushing the right flange outboard would only increase bracing angle of the drive side spokes, but that angle isn't shallow to begin with.
    For the same reason I recommend regular cassette hubs + a spacer kit for anyone who wants a SS wheelset for their Moonlander. It makes for the most symmetric spoke tension. Using a SS hub would ruin it.
  116. #116
    Quote Originally Posted by Saul Lumikko View Post
    I looked at this too and came to much the same conclusion.
    The only thing is many SS dedicated hubs have a better takeup in the freehub, so that is all that's lacking.
  117. #117
    If we're reviving the thread, we might as well add recent(ish) photos.
    Playtime on Soldotna to Homer beach ride.
    Lets see some SS fatbikes!-10330484_10154345530970051_607038328414618607_n.jpgLets see some SS fatbikes!-10361263_10154345530725051_4669764781670222108_n.jpg
  118. #118
    Revival Part II
    sean salach - How much gear were you packing, and what was your gearing with that set up?
  119. #119
    It was a 3 day beach trip. I generally pack pretty light, but brought a few luxuries along on this trip as far as food/beer and camp go. I would guess a base weight of 15 - 20 lbs plus 8 beers and maybe 9 lbs total food. I was usually carrying 100 oz of water at a time. The weight was pretty evenly divided between bike and body.
    Gearing was 32 x 22.
  120. #120
    Jan 2015
    What do you mean by SS specific? Something like the Surley New Hub with thread on free wheel, or something like the Hope SS Trials Hub, that uses a short Shimano splined cassette.
    I would love a FatSno SS Trials hub. But I see your point. It may be better to get the standard cassette but with the 80 points of engagement.
  121. #121
    Just built this up last week:
    <img src="https://farm9.staticflickr.com/8573/15763017094_182beb1474_b.jpg">
  122. #122
    will rant for food
    Quote Originally Posted by Leopold Porkstacker View Post
    Holy balls that is a f'n cool looking bike!
  123. #123
    Thanks! I am having a blast with it! It’s the second lightest bike in my stable at the moment, at just shy of 27 pounds. Wish I’d had been able to justify spending more for the Next SL carbon cranks to drop a couple pounds though.
  124. #124
    Thanks for the info, sean salach.
    Porkstacker - What gearing are you using? Is that an Endless sticker? Love their cogs.
  125. #125
    I suppose I'm breaking the rules, because mine is technically a dinglespeed, but here's the Muk in all it's glory. Set up Knards tubeless and put on Shimano Hydros instead of the Avids it did have. 28lbs 7oz as it sits currently. Same gear ratio as the Blackborow DS. 30x18 and 26x22.Lets see some SS fatbikes!-img_2799.jpg
  126. #126
    Quote Originally Posted by phsycle View Post
    Yes, running a 32t Endless narrow-wide chainring and an 18th cog. Of course, anodized purple. Now I just need to find a tensioner that doesn’t suck ass.
  127. #127
    Feb 2014
    Can't go wrong with a Rennen Rollenlager tensioner, a little annoying to need a wrench to tighten, but very sturdy.
  128. #128
    Quote Originally Posted by adw31 View Post
    Thanks! Just ordered one. Looks like it has the range of tension into the chain (as opposed to outward tension) that will work on my 9:zero:7. The Sette tensioner hasn’t got the required clearance.
  129. #129
    Feb 2014
    Works well pushing up on the chain. I've had to use a washer to space it out on a frame that the hanger wasn't flush with the dropout, set up and tension is easy to adjust.
  130. #130
    nothing to see here
    Really LP? A couple of pounds difference between Next SL and what you've currently got?
    I see hills.
  131. #131
    Quote Originally Posted by Stevob View Post
    1040 grams versus 425 grams. Sorry, 1.3 pounds… “almost” (but not quite) a couple of pounds.
  132. #132
    Race Face says it's 590 grams. Race Face
    Where did the 425 number come from? Maybe not including bb cups?
  133. #133
    Quote Originally Posted by sean salach View Post
    fatbikes.com website.
  134. #134
    nothing to see here
    It's still a lot, regardless. Nice bike man.
    I see hills.
  135. #135
    Quote Originally Posted by Drew Diller View Post
    This^^^!!! Keep coming back to gawk at it. tubeless on those nexties is so beasty.
    Not too sure I've seen many running Lou-Nate either. Interesting. You been running that combo for a while? Supercrawler?
    This bike makes me wanna go smash smurf villages in the hills...
  136. #136
    Quote Originally Posted by frozenmonkey View Post
    Have since upgraded to a Lou in back. The Nate was just temporary, and I wasn’t able to get it set up tubeless. Getting the Lou set up tubeless was pretty easy: 3/8" wide strip of Gorilla tape down the middle of the spoke holes, seat beads with innertube, delflate, pop one side of bead and remove tube, soap up other unseated bead side, inflate with compressor, deflate, inject with Stan’s, all is good! Bike is only two ounces heavier now (Nate was running a tube).
  137. #137
    Well that totally sucks! Rennen tensioner arrived today (after my race) and well, it simply doesn’t work on my 9:zero:7 frame with my 32x18 ratio. Roller wheel submarines into the driveside chainstay, so I cannot get it to provide enough tension. I suppose it would work fine if I were running a 32x20, but that would be too spinny of a ratio.
    Meanwhile, it would seem as though the only singlespeed tensioner that will work is one of the Paul Components Melvin tensioners. Expensive, but I’ll try it out.
  138. #138
    Try the DMR STS II tensioner, or the Black Spire Stinger. Both should work on that frame. The STS makes wheel removal take a tiny bit longer, but works really, really well. Stinger is really light and simple, but not easily adjustable. I have around 5 years of use on an STS. Just repacked the bearings after submerging it in seawater repeatedly over a three day ride, then ignoring it for 6 months. Rolls good as new. I heven't used the Stinger, but it will be running it on my new frame.
  139. #139
    Feb 2014
    What about taking out a link so there's less slack to take up. Also could take a link out and add in a half link.
  140. #140
    Oct 2012
    How about 36/20 then? You'd get a bigger cog and retain the same gear ratio.
    If you go the way of double-jockey tensioners, just get an old RD (short or even road type) and it won't break the bank. The Melvin looks as complicated anyways.
  141. #141
    nothing to see here
    I see hills.
  142. #142
    Agreed.
  143. #143
    If only there were a way to try them all out… without having to purchase them and end up with a collection of ones that don’t work.
  144. #144
    Black Spire Stinger wins! Best tensioner I've tried yet.
    -Low profile and out of the way.
    -Wheel removal is as easy as with an ebb or magic gear.
    -Light. 90 grams. Could probably be drilled out even lighter.
    -Fixed/static. No annoying, failing springs or pivots. It has a reasonable amount of adjustment, and once it's adjusted you can effectively forget about it.
    -Can be set to push up or down.
    I see no downsides yet. Maybe, if you for some reason need to remove it from the bike. That would be time consuming. But I really can't see a good reason to need to do that if the bike is staying ss.
  145. #145
    will rant for food
    Nice, good summary.
    When I ran a Yess ETR-B for a while, I didn't need to fiddle with it in practice.
    Say, how's the noise with the Stinger? My Yess unit was a bit chatty.
  146. #146
    Both the Stinger and DMR STS make an audible noise as the chain passes over the rollers. It's not as loud as knobbies on asphalt, but it's there. Hasn't bothered me. I bet if it was modified to have a derailler pulley instead of a roller, the noise would mostly go away.
  147. #147
    WNC Native
    Always thought the Stinger would be a good tensioner to use on a non SS bike!
    While I'm here, I keep forgetting to post this in here. Loving the SS Puffin!
    <a href="https://www.flickr.com/photos/[email protected]/16484179585" title="IMG_0968 by Nathan Whitmire, on Flickr"><img src="https://farm8.staticflickr.com/7432/16484179585_0992653713_b.jpg" width="1024" height="768" alt="IMG_0968"></a>
  148. #148
    It's almost ideal for ss period. It's lighter than an ebb, sliders or rockers, doesn't affect geometry when changing out to a different gear and allows easier wheel removal than track ends. Only place it would lose is for trials, if going to the bashring, on frames with thick chainstay yokes like most carbon frames, since they necessitate it sitting lower than the chainring.
  149. #149
    Best thread in the house right now. These bikes are badass. Rock on boys.
  150. #150
    PugSS
  151. #151
    Teen Wolf
    Reputation: cr45h's Avatar
    love this thread.. really makes me think about changing the fatty over to SS for the summer.
  152. #152
    Why wait for summer?
  153. #153
    Quote Originally Posted by cr45h View Post
    Sure does!
    Jason
    Disclaimer: www.paramountfargo.com
  154. #154
    Reputation: MMcG's Avatar
    Jul 2003
    Why did you go with pushing down mode rather than pushing up? Any particular reason? Does the down mode prevent a bit of chain "bounce" upward that would happen if you did it in push up mode?
  155. #155
    It's just what worked with my chainstay length, gear combo and the angle of the arm as it was set up. I initially tried it in push up mode and I still had a little bit of slack in the chain. In theory, it might create a little bit less resistance, but I doubt it's significant enough to be noticeable.
  156. #156
    Time to go farther
    I've got a Les Fat on order with HEDs and my usual lightish parts sitting here. Should be a pretty wicked SS when it's done.
    On-One Lurcher SS
    Speedway Cycles Fatback Ti SS
    1984 Trek 560
    http://slipangles.blogspot.com/ - It's supposed to be fun
  157. #157
    Racing Snake
    Sound's nice. Pics when it's together please.....
  158. #158
    Teen Wolf
    I just don't know if I want to torture myself that much right now. snow conditions vary so much. if i rode all hard-pack, then maybe, but i don't.
  159. #159
    For me, a dingle is the way to go. Mainly because I like to ride to the trails. 12 mile round trip would truly be torture with snow gearing. As soon as I can find the right set of chainrings for MWOD, I'll be converting.
  160. #160
    For me, a dingle is the way to go. Mainly because I like to ride to the trails. 12 mile round trip would truly be torture with snow gearing....
    It sure is. I'm prefer SS, but I ride to my trails, and this is the biggest hassle, and dingle is one answer.
    A simple light 2 or 3 ultra wide ratio speed hubgear is something I'd love - basically a bog/snow gear, a trail gear, and a getting to the trail gear. Not exactly single speed though, but a clean chainline.
  161. #161
    Quote Originally Posted by Velobike View Post
    Also, it should come in 197 thru axle spacing.... I would probably get one.
  162. #162
    WNC Native
    Yes, something like the Shimano Nexus 3 speed in 170 & 190mm widths would be awesome!!
  163. #163
    Quote Originally Posted by nitrousjunky View Post
    ^^hear, hear^^
  164. #164
    Having been a ss guy for the majority of the last 15 years and have raced waaaaay more with one gear than any other combo i always find it amusing to hear a majority of "ssers" yapping about this gear for this and that gear for that.
    If your ratio is way too easy where yer spinning out on the flats and it's annoying to get to and from the trailhead then yer running too easy of a gear and you might as well go 1x10 or something and get a real range that is still super simple. Ss riding isn't supposed to be easy. It's not about needing a different gear for each new trail or location. It's about standing, sitting, or running with the bike. If yer able to stay seated on most tough climbs then yer ss ratio is way too easy.
    52 inch gear has and always will be about right for living ss.
    Get stronger. Adapt.
    rog
  165. #165
    Quote Originally Posted by newmarketrog View Post
    ...If your ratio is way too easy where yer spinning out on the flats and it's annoying to get to and from the trailhead then yer running too easy of a gear and you might as well go 1x10 or something and get a real range that is still super simple. Ss riding isn't supposed to be easy. It's not about needing a different gear for each new trail or location. It's about standing, sitting, or running with the bike. If yer able to stay seated on most tough climbs then yer ss ratio is way too easy....
    Single speed isn't a religion. Single speed is just nice and simple and suits most circumstances. It's about having a simple straight chainline so you can go bashing through rocks or scrub and not worry about wrecking a derailleur, and having minimal maintenance.
    There is no right ratio. In my youth, before mtbs, the purists all claimed 63" was the right ratio, and of course, we had to ride fixed. (Not to mention riding on tubulars ).
    The purists were wrong about the perfect ratio because the mtb came along, and it could be ridden in places a skinny tyre 63" bike couldn't be, and the common ratio dropped to 32/16 (52"). No doubt the purists curled their lips in contempt at such degeneracy.
    Then along came the fat bike, and suddenly the standard mtb proved to be a very inadequate offroad vehicle in comparison. Fat bikes create different circumstances and benefit from an even lower gear because they can get grip where no other bike can, and that lower ratio is much too low to spin for long periods on the road. Hence the need for a transit gear to make it pleasant. A dingle speed is equally valid for a clean chainline.
    Getting stronger and adapting is all very well, but most regular single speeders are already pretty fit.
    I can still ride my fixed skinny tyred CX bike round our local mtb course, but it is not pleasant to do so.
    And what's the point of doing that if it's not pleasant? Horses for courses.
  166. #166
    no dood. ss is serious bidness! horses for courses is why god invented multi-speeds
    52 BIAHTCHES!!!
    rog
  167. #167
    52 BIAHTCHES!!!
    rog
    I always believed the devil designed derailleurs. I was convinced of this way back in the dawn of time when my you-beaut nylon Simplex derailleur snapped in half on a very steep climb. During the imprecations following the TTTII* I was divinely inspired to remove the derailleur, singlespeed the bike on the spot and hurl the derailleur as far as I could into the woods. Never looked back.
    *Top Tube Testicle Interface Incident
  168. #168
    superr steep climbs were meant to be run (faster than riding) on foot with bike on shoulder or at one's side holding the tt, not one of those silly extra handle thingys that are being welded to all these new metroseXual custom frames out there these days.
    gotta go shovel more fvcking snow, but i'll be back!
    rog
  169. #169
    handle thingys...these new metroseXual custom frames...
    rog
    It's cuz er'body too self-conscious to just weld the unicorn horn on the front that they really want.
  170. #170
    Jan 2015
    MattgVT... I see your Stowe Green chair SS and raise you a green chair SS pic.
    PugSS
  171. #171
    Eversince I switched to SS, i never climbed a hill on the wrong gear. Sometimes having no choices is great. here's a pic of my fatbike geared up to 32x22 from 32x23
    Attached Thumbnails Attached Thumbnails Lets see some SS fatbikes!-uploadfromtaptalk1425267388076.jpg
  172. #172
    WNC Native
    Quote Originally Posted by JRockF3 View Post
    Agreed! Sharp ride, how's the Hugo's working for you?
  173. #173
    Thanks! Unfortunately, i havent had a chance to ride this with the Hugos. I just got the fork and handle bar this weekend. They did inflate tubeless with a floorpump. Mounting the tires had a little resistance. I'll post an update as soon as I can. I'll be comparing it to tubeless MargeLites w HuDus
  174. #174
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Nice looking bike. BTW, Are you in Tx BBQ?
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
  175. #175
    Thanks Drevil! Yezzur I am.
  176. #176
    Jan 2015
    Non-SS frame but still lot of fun
  177. #177
    Quote Originally Posted by VitaliT View Post
    That just looks totally b¡tchen!!! Is that a Paul Components Melvin SS tensioner?
  178. #178
    Jan 2015
    No its Shimano Alfine S500 Chain Tensioner
    And I’m almost got banned on mine local forum for posting such discussing bike
  179. #179
    I blame all of you.
    It's actually really perfect. 30x19.
    Jason
  180. #180
    Quote Originally Posted by JAGI410 View Post
    I blame all of you.
    Very nice! I didn’t know Salsa made a fatbike with swapouts… I race singlespeed (on my fatbike) and am getting tired of having to run a tensioner (every single type has given me problems); perhaps a Salsa is in my future.
  181. #181
    This is Salsa's "Alternator" setup, which is on their Mukluk and Blackborow fatties, and a few of their skinny bikes. There's a few styles of Alternator plates to choose from too. It's a pretty slick system!
    Alternator Dropouts | Part & Accessories | Salsa Cycles
    Jason
  182. #182
    I’ve determined that a through-axle SS setup is for me.
  183. #183
    Using Black Spire Stinger and a half link(if needed for gear combo), ANY thru axle fat frame will work for you. There is less that could go wrong with the stinger than swinger/rocker dropouts.
  184. #184
    There's a thru axle Alternator plate set, includes the axle too. It's aftermarket for the Mukluk, but an easy conversion. In fact, the Blackborow DS comes with it.
    Blackborow DS | Bikes | Salsa Cycles
    Jason
  185. #185
    move on up...
    Dec 2011
    I did this conversion to my 2013 muk when I got my whisky/hope wheelset. The wheels are really stiff so it is hard to tell how much it stiffened up the rear end but I'm not going back to qr any time soon
    Just switched back to SS last night, love the ease and versatility of this bike!
    32/17 for now
  186. #186
    May 2012
    I am sold on single speed and now I have no interest to ever go back.. (Mainly because I don't have these components for a geared setup.. hehe.) But seriously though, I will probably keep it like it is.
    22x32 suits me right now.
    Lets see some SS fatbikes!-11260729_10153305438258545_2281669658442782076_o_zpstq4qm6bu.jpg
  187. #187
    Trail Rat
    Reputation: devans's Avatar
    Apr 2015
    Looks great Qtep!!
  188. #188
    Nov 2014
    Yes, awesome rig Qtep!
  189. #189
    Feb 2015
    Nice!
    Going SS with my Farley build later in the year.
  190. #190
    Reputation: Loz2e's Avatar
    Here's Mine....
  191. #191
    Quote Originally Posted by Loz2e View Post
    Love this photo
  192. #192
    Vertigo Cycles titanium fat bike with Black Sheep Faith fork. I've changed bits and pieces over the 3+ years I've had it. It's the funnest bike I've owned.
    FatPinklespeed by bundokbiker, on Flickr
  193. #193
    Time to go farther
    My LES Fat is supposedly arriving today
  194. #194
    Oct 2010
    Quote Originally Posted by Pivvay View Post
    For you then.....
  195. #195
    Time to go farther
    Sick! I have HEDs waiting too
  196. #196
    Reputation: Stopbreakindown's Avatar
    Drevil's vertigo is sooo hawt!
  197. #197
    Oct 2010
    Thanks. Those aren't HED's, HED's were unavailable when I built these up, but they would be nice. They are LB 90mm rims on I9 hubs. well the geared rear is and I9, the SS wheel is a 907 hubs.
  198. #198
    Quote Originally Posted by Drevil View Post
    With the amount of time it seems to spend in the air, it must be indestructible.
  199. #199
    Oct 2011
    Looks a lot like trail I used to ride in Glendora, Ca.
  200. #200
    Reputation: floorguy724's Avatar
    Finally picked mine up from the shop today! First ride was today, awesome! Still way out of shape lol.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  1. kids and fatbikes
    By coldbike in forum Fat bikes
    Last Post: 02-07-2013, 04:21 PM
  2. Singlespeed and fatbikes
    By Velobike in forum Fat bikes
    Last Post: 12-08-2011, 01:04 PM
  3. SS Fatbikes
    By aTomOfAllTrades in forum Fat bikes
    Last Post: 07-16-2011, 01:18 AM
  4. Suspended Fork for FatBikes
    By rasidi in forum Fat bikes
    Last Post: 07-09-2009, 10:41 AM
  5. Fatbikes
    By husaberg in forum California - Socal
    Last Post: 04-16-2008, 08:21 PM
