Lauf vs Mastadon Pro vs Mastadon Comp- Mtbr.com
Results 1 to 11 of 11
    Aug 2017
    What would I be losing going comp over pro ?
    And is Lauf really gonna give me a decent cushion?
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    What are you using it for? Smooth out rough snow and sand, or actual trail riding?
    Comp is heavier... Not sure on internals
    Aug 2017
    Salsa Beargrease - trail riding
    Reputation: BlueCheesehead's Avatar
    In addition to a weight advantage, the Pro has a rebound speed adjustment that the Comp does not have.
    I have not ridden the Lauf, but it is just a spring, no dampening. It's going take most of the energy that it absorbs and return it back up through the bars.
    I bought my Mastodon Pro through 365 Cycles. It was the lowest price I could find and it arrived quickly. Please note that you will need to buy the appropriate race for your headset.
    Quote Originally Posted by BlueCheesehead View Post
    Wrongo....both the Pro and Comp have rebound adjustment. They differ in Compression adjustments
    Sep 2013
    Quote Originally Posted by the mayor View Post
    Yep. The Pro has two compression adjustments while the Comp has one.
    Also, to the OP, if you define trail riding with lots of roots and rocks, DO NOT get the Lauf. I had one and for snow riding and just general riding on fire roads and smooth dirt it's great. The lack of damping creates a lot of bouncing and vibration on irregular surfaces.
    Aug 2017
    Yes lots of roots - Lauf out
    Comp or Pro ... is the comp a big drop off in quality ?
    Iím not sure I need all of the extras , Iím s set and go guy.
    My mistake. The Pro has high and low speed compression adjustments on top of the stanchion where as the Comp only has low speed.
    If not riding in super cold and value light weight over flex then a Bluto may suffice.
    Aug 2017
    I hear a lot a negative on Bluto
    Quote Originally Posted by TheNatureBoy View Post
    From what I read the Bluto was okay, but the Mastodon was better.
    Feb 2006
    Mastadon is significantly stiffer and has higher quality damping than a Bluto. I owned two Blutos before the Mastadon Pro. Preferred a rigid carbon fork over the Bluto, very happy with the Mastadon so far.
  1. Small Fatboy with a Mastadon
    By 1spd1way in forum Classifieds
    Last Post: 12-18-2017, 04:35 AM
  2. Lauf Trail Racer Fork. The lightest 29er suspension fork ever?
    By Shalom in forum Shocks and Suspension
    Last Post: 06-11-2015, 05:45 AM
  3. Replies: 40
    Last Post: 12-24-2013, 12:22 PM
  4. Lauf trail racer 980 gram fork
    By Hogdog in forum Shocks and Suspension
    Last Post: 07-12-2013, 08:15 AM
  5. Replies: 0
    Last Post: 07-10-2013, 02:24 PM
