If you see Todd's Pants...- Mtbr.com
Results 1 to 31 of 31
    Kill Todd's Pants.
    Todd's Pants must be on fire. Fits with plenty of room to spare, no modifications needed. This is a Holzfeller 32/22 Crankset with a 11-34 cassette.
    Jason
    Disclaimer: www.paramountfargo.com
    Geordie biker
    Reputation: saltyman's Avatar
    nice one!
    2014 milage so far - 2,485
    www.ukfatbikes.co.uk
    bikeboatbrewski
    Reputation: scottybinwv's Avatar
    Jun 2010
    TPI = Todds Pants Inferno
    How much does it weigh?
    Reputation: Borgschulze's Avatar
    Nov 2007
    Surly does some funny stuff sometimes
    How comes Surly says they wont fit a Pugsley without losing a few gears, yet people keep fitting them with seemingly no issues?
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    They wont fit on 100mm wheels as they are to wide. On 65mm Marges, they just fit...
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Quote Originally Posted by XJaredX View Post
    Even in the image shown here it looks too close for comfort in regards to that chain in the lowest combination on that Pugs. Get a little snow or dirt stuck on the tire, add in some rough terrain and that chain is going to be dragging on that tire, me thinks.
    These tires will fit current Salsas and Surlys with 80mm rims, but drive train mods will be necessary to get all combos without chain/tire interference. BFL's and 100mm rims will also work on Salsas with drive train mods.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Any reports yet on if the bead area of the Black Floyds has a message?
    Harmonius Wrench
    Quote Originally Posted by Andy FitzGibbon View Post
    Yes it does. I can't remember what it is though!
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    R.I.P. Pugsley.
    Reputation: Rabies010's Avatar
    Jan 2011
    Maybe you have to play it backwards for the real message to apear....
    Reputation: jfkbike2's Avatar
    Feb 2005
    Who is Todd? Surly employee or future product?
    Reputation: Mojoe's Avatar
    That's just too funny. The label on my Surly cycling cap says something like, " Call if your going to be out late." .
    Reputation: Larry Endomorph's Avatar
    Jan 2011
    Black Floyd:
    DOES NOT SYNCHRONIZE WITH THE WIZARD OF OZ
    Attached Thumbnails Attached Thumbnails If you see Todd's Pants...-img_20110908_070922.jpg
    Hahaha
    Frt Range, CO
    Reputation: pursuiter's Avatar
    I'm going with Todd's Pants, the music group:
    Todd's Pants | Free Music, Tour Dates, Photos, Videos
    OP, your first picture looks like the bead isn't seated correctly.
    Quote Originally Posted by Guitar Ted View Post
    There's more clearance than my picture alludes too. I'll try to get better pics. My granny gear is 22/34, a gear I rarely use. Only the little rubber casting "fingers" drag on the chain, and I'll be clipping those off soon. They tend to turn into icy lollipop lookin' things in the winter.
    Quote Originally Posted by pursuiter View Post
    The message is hidden once the bead is seated, and I had to take a pic of it before I finished mounting the tire.
    Jason
    Reputation: FrontRanger's Avatar
    Hey OP, what rack is that?
    Quote Originally Posted by FrontRanger View Post
    Planet Bike Eco Rack
    Fits perfectly with no mods, just mount drive side to the "inner" part of the lower brazeon.
    Jason
    bikeboatbrewski
    Jun 2010
    Smile Deep fried meat fed Nateopocolypse
    Finally got my BFL and Nate tires via the LBS. Mounted up Mr. Nate on the XC Large Marge hoop that rides in the SC 32. Had to redish slightly as the wheel was off a tad, no problem. About 3-4mm of clearance of the legs.
    Next up the BFL on the rear, figured it would be go or no go. Slipped onto the DH Large Marge easily for a steel bead. Wiggled it in place and it fits! Had to do just a small amout of tweaking on the front derailluer to have no rubbing. Reset the the brake caliper so there was no rub and I am rollin" phat.
    Now I just need some dry weather.
    Harmonius Wrench
    Quote Originally Posted by JAGI410 View Post
    Gotcha. I stand corrected.
    Glad it's workin' out for ya on that rig.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Thanks for the info. What size frame is that?
    Nov 2007
    What does Nate say on the bead?
    Quote Originally Posted by frontranger View Post
    thanks for the info. What size frame is that?
    18"
    Jason
    Quote Originally Posted by Borgschulze View Post
    Deep Fried Meat Fueled Natepocolypse
    or something like that
    Jason
    Quote Originally Posted by jfkbike2 View Post
    Remember that photo from Surlys' blog with that shirtless guy struggling through
    ankle deep muck?
    That is Todd.
    The person in the background is Nate.
    bikeboatbrewski
    Jun 2010
    Bonking ... not feelin' well
    $hit! I just figured out my highroller roof rack will no longer fit my Pugs with BFLs.
    Reputation: loOse1's Avatar
    [QUOTE=scottybinwv;8428019]Finally got my BFL and Nate tires via the LBS. Mounted up Mr. Nate on the XC Large Marge hoop that rides in the SC 32. Had to redish slightly as the wheel was off a tad, no problem. About 3-4mm of clearance of the legs.
    Now I just need some dry weather. [/QUOTE
    Hey Scotty did you happen to try the BFL on the SC32- will it fit?
    Updated pics now that the tire has stretched another 2mm, now measures 100mm at 10psi on the 65mm Large Marge.
    Some street/trail time already thinks the weight difference from the 27tpi Larrys is very noticeable, and the more flexible casing is felt as well. I'm quite happy with the upgrade.
    Jason
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by scottybinwv View Post
    Did it fit with regular larry's? (without letting air out?)
    bikeboatbrewski
    Jun 2010
    Quote Originally Posted by loOse1 View Post
    No sir, I did not. It may fit or not. Next time I get to changing tires I might try it.
    bikeboatbrewski
    Jun 2010
    Quote Originally Posted by Shark View Post
    Yes, the Highroller fits the fat with the Endo or Larry with no air down on my Large Marge wheels. The Nate and Black Floyd should be ok but the BFL will not. Maybe aired down it will but then the bike will not be very stable in the rack. Part of the issue is the plastic ratchet strap is not long enough, I contacted Yakima about a longer strap over a year ago and was told it would not happen.
    Maybe if more folks ask for it they would make a longer strap, squeaky wheel gets the grease.
    I got a North Shore bike rack coming so that will fix that.
  1. Cool weather long MTB pants (soccer long pants)
    By crvt427 in forum All Mountain
    Last Post: 12-30-2010, 05:19 AM
  2. Pants
    By Dictatorsaurus in forum Beginner's Corner
    Last Post: 10-12-2009, 07:32 PM
  3. Todd's Prescott Race
    By atrophy in forum Arizona
    Last Post: 10-29-2008, 04:26 PM
  4. Todd's Rock
    By spandex in forum Downhill - Freeride
    Last Post: 10-31-2005, 01:55 PM
