I seem to have two different sized holes...- Mtbr.com
Results 1 to 11 of 11
    ..is finally semi-skimmed
    Reputation: Slackadaisical's Avatar
    ..on my Salsa Enabler fork
    Bottle cage bolts bolts fit the larger, but what size are the smaller ones?
    Nov 2007
    Really?
    Cause I just bought one last week and bought bolts for all the braze-ons. They were all the same size.
    The fork I've have has six holes that fit standard bottle cage bolts, and four of a smaller diameter.
    The smaller ones are aligned with each other.
    Black Sheep rising
    Reputation: utabintarbo's Avatar
    Rack mounts?
    Let the market decide!
    N42.58 W83.06
    Sounds likely...
    Well that's that sorted.
    The outer threads were gummed up with paint. The inner ones, I'm sure are smaller....
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Slackadaisical View Post
    I have never seen a frame/fork fitting with threads smaller than M5 (bottle boss bolts).
    Where are these smaller holes you have? Pics would help.
    Or look here for what the fork is meant to do: Enabler Fork - Jack-of-All-Trades, Master of Many | Salsa Cycles
    mtbtires.com
    I tried inserting M5 bolts into the inboard threads facing the wheel, but there is so much resistance that I'm worried that the threads will be stripped.
    I have had a look at both threads and there dosen't seem to be any obvious obstruction.
    Dec 1998
    I am still unclear on where these holes are.
    If you can even start to get a M5 bolt into the threads (assuming they are threaded), it is not a M4 hole.
    In this case you just need to clean out the threads with a M5 (5x.8) tap.
    mtbtires.com
    Sounds like you are talking about the mid-blade bosses. This is a thru-boss that runs across the entire blade. It is one long threaded sleeve. The pitch (M5x0.8) is the same at the outside and inside. Generally speaking, masking of these bosses is thorough and overspray is not an issue. Once in a while though, a few get a bit of paint build up in them. Sorry to here you got a fork like this. A simple chasing with a tap takes care of this issue.
    The shop from which you bought the fork from should have the tools required to clean these threads out without damage. If the inside opening of the boss has some overspray, the best thing to do is chase the threads with a tap from the outside through to the inside. If the threads on the outside are clean, another option, though a bit more crued, is to start a long bolt on the outside and run it in until the end clears out the inside end of the boss threads.
    Hope that clears it up.
    [email protected]
    Thanks everyone.
    Eased an M5 bolt through both threads and now everything is good.
  1. Are there xxl sized helmets that anyone knows of
    By Moozh in forum Apparel and Protection
    Last Post: 07-19-2010, 12:54 PM
  2. XL Sized Anthem?
    By iscarrr in forum Giant
    Last Post: 02-12-2009, 03:29 PM
  3. different sized wheels?
    By wildskycomet in forum Titus
    Last Post: 04-11-2008, 12:18 PM
  4. Man Sized Parts
    By wildboar in forum Clydesdales/Tall Riders
    Last Post: 10-15-2006, 08:57 PM
  5. Right sized frame?
    By Johnny Bachelor in forum Bike and Frame discussion
    Last Post: 04-05-2004, 04:23 PM
