Hubs which convert between 177 and 197 spacing. Is there such a thing?- Mtbr.com
Results 1 to 8 of 8
    Oct 2014
    Bit of a long shot but is there a hub available that converts between 177 and 197 spacing by changing end caps? Would be great as could then share one wheel set between my Wednesday and upcoming Big fat Dummy. Thanks.
    fat guy on a little bike
    there was a local convinced his Hope 197 hub was "convertible" to 177. Turned out it could only be changed to a 190 QR.
    I have not seen any hubs that do this, good luck.
    I can't be done.
    The difference is in the hub body....using spacers would put the disc rotor and free hub too far inboard
    Oct 2014
    Quote Originally Posted by the mayor View Post
    I can't be done.
    D'oh! Got it thanks. Good idea though.
    Mar 2011
    I can't be done.
    Could a conversion kit be made to go from 177 to 197 like the boost conversations wolf tooth and mrp make?
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    Quote Originally Posted by gregorysmithj1 View Post
    Not likely. You would need to do one of two very unlikely options.
    1. a 10mm spacer on each side, which would require a 10mm brake rotor shim, but more difficult still, your derailleur would need to swing 10mm beyond its normal limit.
    2. a 20mm spacer on the brake side, a 20mm brake rotor shim, and to re-dish the rear rim by 10mm.
    Those are ugly options.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Quote Originally Posted by GuitsBoy View Post
    Maybe option 2 would work. If thru-axle end caps are available for your pugs hubs, there is an ebay seller called "MBT Tools" that could probably fab the spacers in option 2 above. If you want to go that route, I'd dish the wheel 13.75mm to the left, instead of the standard 17.5 on the Pugs. That would probably give you acceptable (but not perfect) dish for both the pugs and the Big Fat Dummy.
    --Peace
    Nov 2007
    I'd worry about bearing and/or hubshell life since the bearings would be further inboard compared to a true 197mm hub. Unless you're going with some high-end wheel (just the rear, right?), the time and materials to come up with a (compromised) fix won't be worth it.
  1. Replies: 10
    Last Post: 01-28-2017, 05:24 PM
  2. Any dually frames with 197 spacing?
    By Mike E. in forum Fat bikes
    Last Post: 08-16-2016, 08:07 PM
  3. Any stock 150x15 170/177 29er wheelsets out there?
    By DBoyle in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 12-22-2015, 03:33 PM
  4. Replies: 2
    Last Post: 11-13-2015, 05:51 AM
  5. Is there such a thing as a sub 2 pound chromoly fork ?
    By phoenixbikes in forum Weight Weenies
    Last Post: 05-19-2011, 05:33 AM
