Hub and Wheel questions...HELP!- Mtbr.com
Results 1 to 7 of 7
    So I'm considering a 907 build with the 135 offset. Part of the draw to the 135 is the ability to use whatever hubs you would like. That's leading to a couple of questions:
    - I would love to build it with red hubs (probably Hopes). I believe I can use a regular Hope rear hub. But what would my options be for a red front hub? Would I have to use a Hope 135 rear SS hub? Maybe the new Salsa hub, but not sure that would match. Any other options for red (I'm vain like that )?
    - Does anyone have experience with the Hopes in cold temps? I've used them on my SS down to about 20F with no issues, but I've got plans on going colder than that once I get the fattie built.
    Also, I remember a thread not long ago that had pictures of several wheels built up using the colored RD's. Does anyone have a link to it? I've searched back several pages and must be overlooking it.
    Quote Originally Posted by Otter View Post
    Depends of your fork
    Every hubs should do the job. Make sure you can regrease the freehub body pawls easily
    R.I.P. Pugsley.
    Reputation: Rabies010's Avatar
    Jan 2011
    With a 135mm offset you can run a nice red Rohloff in the rear...
    And with a hope SS hub you can even manage to put on a gear or 6 if you wish to do that.
    And they are easy to repack with another kind of grease as well.
    Here are the threads you were looking for :
    http://forums.mtbr.com/fat-bikes/lim...ls-746246.html
    http://forums.mtbr.com/fat-bikes/news-flash-746392.html
    Reputation: atom29's Avatar
    Feb 2010
    Sounds like in your case it may be easier to go 170? Then you can either get Salsa or Hadley in red and you know they'll match. The salsa red hubs only come as sets as far as I know.
    I'll be using a 907 fork, so 135 spacing front
    Rabies, thanks for the links, but that's not the thread I was thinking of. The thread I saw showed several sets built up and looked like they were all hanging in the same shop.
    Thanks guys.
    locked - time out
    Jun 2010
    I can't find the thread either, but here's a link to the pics.
    http://forums.mtbr.com/members/teaniner/albums/fat/
    Reputation: Smallfurry's Avatar
    Thanks guys.
    Some 135 forks are set up for a rear hub, and some for a front. It the brake disc position that varies. Most of the 9zero7, Surly, and salsa forks use a rear spacing. Fatback and white brothers use a front.
    A big boy did it, and ran away.
    62*28'
  1. Some questions regarding a new set of wheels
    By vladxc in forum Wheels and Tires
    Last Post: 03-03-2010, 01:31 PM
  2. questions on deetrax wheels
    By osifer in forum Downhill - Freeride
    Last Post: 11-05-2006, 11:30 AM
  3. Building wheels (few questions)...
    By mahgnillig in forum Wheels and Tires
    Last Post: 11-06-2005, 01:02 PM
  4. Wheels Questions
    By JBsoxB in forum Downhill - Freeride
    Last Post: 05-13-2005, 09:19 PM
  5. Big wheels and FS questions
    By pigpen in forum 29er Bikes
    Last Post: 04-26-2004, 12:53 PM
