How much does a Fat Bike weigh?- Mtbr.com
Results 1 to 115 of 115
    Reputation: gbuckham's Avatar
    I've been asked a few times how much the Pugsley weighs compared to a normal bike. So I borrow the neighbours scales to find out. My road bike, a Dawes Ultra Galaxy comes in at 13.1 or 28.9 lbs Kg, the Genesis iOiD sits at 13.6 Kg or 30 lbs and the mighty Pugsley an interesting 19.3 Kg or 42.5 lbs. All bikes without panniers, etc. I'd be interested to see what other fat bikes weigh?
    is buachail foighneach me
    Reputation: sean salach's Avatar
    I've seen Fatbacks built up, with gears, anywhere from 24lbs(10.9Kg) to 35lbs(15.9Kg). You could make them heavier with cheaper or burlier components. You could make one lighter if you're very light yourself, have a buttload of money and don't mind going 1x10/9/8/5/1.
    shut up and RIDE!
    Reputation: capefeartrailrider's Avatar
    Nov 2006
    my Pugs is 34.5lbs - that's with no racks/panniers
    '11 Surly Pugsley
    '07 Prophet 3
    96' Killer V 900ht
    04' F700sx
    '10 TommiSea Terrain Destroyer
    Reputation: coastkid71's Avatar
    Mine weighs 38 lbs...must be full of sand
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
    ride more
    Holy crap, mines 42, guess it's time to start upgrading some stuff.
    aka bOb
    Reputation: bdundee's Avatar
    My Pugs was 34#.....No racks.
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    My Alum Fatback is right at 30 pounds. I know of a few more pounds of weight savings, but that comes at a steep price tag. Carbon Fork/Ti Pedals/Saddle.
    Reputation: dvo1's Avatar
    Cubic money will make a fatbike light.
    Reputation: Velobike's Avatar
    38.5lbs
    Any bike, anywhere, anytime.
    Latitude: 57º36' Highlands, Scotland
    drc
    drc is offline
    annoyingly cautious
    My Pugsley weighs 35#.
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    42lbs
    But Hey , I`m 260lbs !!!
    Life IS a Beach and then you Corrode :)
    How much does it weigh?
    Reputation: Borgschulze's Avatar
    Nov 2007
    Full Tilt Boogie
    May 2005
    My steel fat bike weighs in at 35lbs. Not many weight wienie parts at all except Rolling Darryl rims.
    I sell bikes here. Check out the Blog here. Facebook.
    Reputation: lancelot's Avatar
    Mine is coming in at 29.5lbs. Build listed below to get an idea.
    Fatback 22" polished nickel w/ Fatback carbon fork
    Uma II drilled rims with Fatback (Hadley) hubs and Ti skewers
    Fatback E13 180mm crankset
    Shimano 10sp Dyna-sys drivetrain (yes it works with the E13 crank)
    Formula R1 disc brakes w/ Ashima rotors (180/160)
    Thomson seatpost, stem and seat collar
    Specialized S-Works carbon riser bar
    Specialized Phenom SL Ti saddle
    Twenty6 Prerunner Ti pedals
    Cane Creek 100 Headset
    Ergon GA1 Leichtbau grips
    Surly Larry/Endo tires 120tpi
    Q-tubes super light 26"x2.4"-2.7" tubes
    I have a medium older generation Ti Fatback @28.5# or 12.9 Kg with bar ends, speedometer, bottle cage and 2 X 8 with a bash ring.
    Wife has X Small Alu Fatback @ 29.5 # or 13.4 Kg.
    Most of the difference is in the fork, I have an older lighter steel fork on mine. Also the pedals, mine have ti axles hers don't. That will get taken care of soon enough. Now if I get a carbon fork for me and give her my steel fork both our bikes can get a bit lighter. That should count as a win / win right?
    Reputation: fishingis4play's Avatar
    My Aluminum 9 Zero 7 with a steel Pugs fork, 3 bottle cages, cushy seat, ergo grips with bar ends, and a rear rack weighs in at 34.5 lbs. I weigh in at a light 300 lbs in bike shorts
    Reputation: bighit's Avatar
    I think We crunched these numbers a while ago. We reached a conclusion back then that a fat bike carries 5 lbs of extra weight do to fat bike specific parts.
    Maybe now we should redo the math
    100 mm bottom bracket has to be used.
    45-50mm rims because that is the generally accepted minimum rim for the tires.
    Vs two say gordos.
    Two larrys vs the largest 29er tires out there
    Two legit tubes. Debatable, but surly tubes should be used for a standard.
    Other than that it's all personal.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    PUG U!!!
    Reputation: joboo's Avatar
    My Pug comes in at 36# naked! 42ish# fully clothed!!??
    In all seriousness, if I was worried about the weight of my "Fat" bike I'd have purchased a road bike, NOT!!
    After all, isn't it just a number??!! HAA HAA
    Peace, Joboo
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Wow, anyone over 50 lbs???
    This is the anti-weight-weenie thread haha. I'll post what mine ends up in a few weeks.
    *JUST RIDIN*
    Reputation: justridin's Avatar
    my Pugsley is 41 lbs, there seems to be a big difference in weights here???
    Nov 2007
    My Fatback isn't intended to do long hauling or epic trips or anything.
    It's meant to commute/be a fun trail bike.
    If I wanted it to be tough, I'd use the steel fork, and probably Surly Rolling Daryll rims now that they're available. Which would add roughly 1.5lbs. Then I'd consider it epic worthy/
    As of now, I wouldn't do any drops or jumps on it.
    Addict
    Reputation: RENCRN8's Avatar
    Dec 2010
    My new Fatback weighed in it at 34.4 lbs ready to ride tonight....
    Quote Originally Posted by RENCRN8
    You gotta post some pics of that one.
    Addict
    Dec 2010
    aka bOb
    Nice Fatback RENCRN8. I tried buying one and nobody would return my emails. So I bought a 907.
    Reputation: NOBBY605's Avatar
    Grandpa's skidmark
    Weight 31.5 pounds
    Surly Pugsley XL
    Surly 100mm spacing fork
    Surly Rolling Darryl rims 80mm wide laced to American Classic hubs
    Surly Larry front Endomorph rear tires
    Avid Juicy 5 rear brake 160mm rotor (no front)
    Race Face ISIS cranks
    FSA platinum 100mm BB
    2X10 drivetrain---SRAM X-9 derailleur, Paul Thumbies, 10 speed SRAM Red TT shifters
    XT e-type front derailleur
    KMC x10sl chain
    XT 11-36 casette
    Easton EA 70 straight bar w/ carbon bar ends
    Truvative 70mm stem
    ODI lock on grips (must for snow riding)
    Thomson seat post
    Selle Italia seat ti rails
    Salsa seat post clamp
    Salsa skewers
    Chris King Headset
    I think thats everything
    Attached Thumbnails Attached Thumbnails How much does a Fat Bike weigh?-021_001.jpg
    will rant for food
    Quote Originally Posted by Shark
    I got close, I'm at 45 pounds with a descending seatpost and studded Larry tires. EDIT: And a NuVinci hub, duh, forgot that part.
    Toyed with the idea of making it electric motored for winter commuting, but the old commute that I had to do went away... but that would have added 15 pounds.
    That has to be one of the lightest Pugsleys on the planet. Well done.
    I am curious why you say Lock On grips are a "Must Have"?
    My cup runneth over
    Reputation: rmac's Avatar
    18” alu Fatback with steel fork – 33 lbs. Same weight as my ‘primary’ fs bike. On Saturday I did a 4 ½ hour ride on the fat bike that was a combination dirt, rocks, snow, ice (ugh, lots of ice) and road (some pretty significant dirt and snow climbing too). I was very pleased with the performance of the fat bike. I do the exact same ride on my fs bike ~20 times a year in the summer and fall and was expecting more trouble with the climbing than I had. The low pressure tires definitely mitigated the wheel/tire weight. It was also snowy and icey enough that I wouldn’t consider this ride in the winter on my fs.
    Quote Originally Posted by sryanak
    If you take a couple spills in the snow or it is snowing regular grips tend to move.
    Quote Originally Posted by NOBBY605
    I've been using Ritchey WCS foam grips for years, and have had my share of falls into the snow, with no issues. Maybe I'm just lucky. I use hairspray to put them on for what that is worth.
    Your bike looks like a great setup enjoy it.
    Reputation: Sevenz's Avatar
    That is exactly what I said when he weighed it in front of me...Sick Bike!!!!
    Reputation: 7daysaweek's Avatar
    33 lbs before all the mud.
    CAMBA Creature.
    Reputation: KrateKraig's Avatar
    17" Salsa Mukluk... (Stock)
    36.8 pounds, with Bar Mitts and Shimano PD-M324 (Boat Anchor) Pedals.
    eSpeCially CrAzy IrRegular TrailBuildin' Crew
    Chequama Mama
    MTB: Mukluk/Moonlander/Super V-1.
    bikeboatbrewski
    Reputation: scottybinwv's Avatar
    Jun 2010
    I am pretty sure I weighed mine when I got it and it was right around 38lbs, now its pushing 42 lbs.
    Reputation: AdamJay's Avatar
    Jan 2014
    Thought I would resurrect this thread, now that there are a few more fat bikes and lighter components on the market.
    My 17" Motobecane FB4 Elite was 36lbs stock w/o pedals.
    I've got it down to 33lbs, 15oz with Larry/Endo 27tpi, and part swaps...
    reduced weight:
    -Origin8 UL Wheelset (Drilled HL-80s w/ Or8 front hub, XT rear hub)
    -XT rear mech
    -HG50 cassette,
    -bbg drilled bash in place of 44t ring.
    -Charge Scoop saddle
    -Surly Tubes (i keep Qtubes as spares only)
    added weight:
    Ergon GP-2 grips.
    Bigfoot platform pedals.
    Running Origin 8 Captiv-8er UL 3.5" 60tpi tires, it weighs in at 32lbs, even.
    Could have saved more rotating weight with a SRAM cassette, but I saved more money on a pair of HG50s for two wheelsets.
    Reputation: Finski's Avatar
    My small Necromancer Pug currently weighs 31.5 w/pedals. Upgrades are carver carbon fork, drilled RDs, Race Face turbine crank with single 32t ring, On-One floaters, etc.
    I'm hoping to get under 30lbs with a set of new Hope hubs, different pedals, and I just went toobless.
    NKAWTG
    Reputation: vikb's Avatar
    My Pugs is over 40lbs with an Alfine 8....I'd guess 45lbs...no scale so I can't confirm....probably a good thing...
    Safe riding,
    Vik
    www.vikapproved.com
    dvn
    dvn is offline
    Reputation: dvn's Avatar
    2013 large Muk. 32.5 in winter mode with studded Bud and Lou on Holy Rolling Darryl's. 29 as it sits now in "summer" mode.
    "Either way it doesn't really matter, I just got back from a bike ride."
    > dbhammercycle
    Mar 2013
    My Pugsley mk1 is 40lbs and I'm 260lbs and together we are 300lbs of rolling thunder.
    Jan 2005
    26.5 lbs
    2014 Mukluk, 28.9lbs
    Jason
    Disclaimer: www.paramountfargo.com
    Jan 2015
    Beardgrease on self-studded Dillinger’s 10.5kg/23.1lbs, waiting for kenda juggernaut pro to drop 1-1.5kg/3.3lbs
    aka bOb
    Trying to get under 200 pounds combined weight.
    12.27kg - My race bike for the StrathPuffer 24 Hour.
    Reputation: Way2ManyBikes's Avatar
    27.2lbs as is
    Marty-MJ
    www.garagescene.net
    MJ
    14 Farley,Bluto,i9-27.5FatBNimbles
    16 Farley5,CarbonFork,27.5x4.5Barbegazi
    16 Farley9.6,Bluto,Onyx-26JumboJims
    aka bOb
    Quote Originally Posted by Way2ManyBikes View Post
    27.2lbs as is
    Marty-MJ
    Garage Scene
    Nice looking whip right there!!
    Quote Originally Posted by Velobike View Post
    Including 3 kilos of stem spacers.
    Reputation: mtbeagle's Avatar
    Jan 2009
    The bikes I am building come in around 24lbs. South Pole Bikes Adventurer - www.epicbiking.com
    My Pugsley is under 28lbs
    Nov 2007
    24.5 lbs.
    aka bOb
    Quote Originally Posted by SmooveP View Post
    24.5 lbs.
    The bike that cost me a small fortune!!
    aka bOb
    This thread needs a bike with a little more meat on it's bones.
    28.2 pounds.
    <iframe src="https://www.flickr.com/photos/[email protected]/14628878785/player/" width="500" height="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    Quote Originally Posted by bdundee View Post
    Thank you
    Marty-MJ
    www.garagescene.net
    MJ
    Nov 2007
    28.2 pounds.
    Dude.
    Feb 2006
    My old 9zero7 ranged from about 29-31 depending...
    Bucksaw is 30-31 or so.
    I'd like to point out, the OP has a heavy road bike lol
    Reputation: Tunalic's Avatar
    Feb 2012
    31.5 lbs
    2018 Trek Stache 7
    2016 Trek Farley 9.6
    2015 616 Muenzie
    2013 On One Fatty
    2011 Trek Sawyer (27.5+ Alfine 8 spd)
    Quote Originally Posted by sean salach View Post
    Yeah, but they're so sparkly...
    They are so I can have the bars high enough for when I end up walking and have to push. My usual dropbars give me back pain in steep uphill walk mode (that's after about 15 hours riding) so I found I was trying to stay pedalling when it was more efficient to jump off and have a walking rest. (I'm a great believer in walking on uphills when the pace drops to walking speed.)
    Reputation: Captain_America1976's Avatar
    Mar 2005
    As it sits in the picture it was 31 lbs and 5 oz. Since it was taken I have swapped out the bars and grips for a Jones H Bend bar and Ergon GX1 grips. I have also swapped out the brakes for XT. I also drilled out the rims, and set it up tubeless. Current weight is 30 lbs.
    Attached Thumbnails Attached Thumbnails How much does a Fat Bike weigh?-img_1460.jpg
    How much does a Fat Bike weigh?-bcdca3ce-45b5-4ea5-b954-73ac2d4e54a8_zps26mb5dxk.jpg
    Dec 2013
    Hi, does anyone know the actual weight of a stock (14") XS Pugsley ??
    / F
    Reputation: tyriverag's Avatar
    Jan 2014
    Quote Originally Posted by Frax View Post
    / F
    lol
    it's a challenge some of us are ultimately worthy of.
    i was thinking of a total bike weight thread. my moonlander with 8in discs, 2xls, jones bars, leather seat and all other comfortable stuff is 40lbs.
    2012 Moonlander.
    Jan 2014
    Bird zero AM with mt7 danny mcaskill, eagle nextie and some fun bits
    Reputation: Ducman's Avatar
    About 33lb as ridden with a pump and tools in the top tube bag. Don't really notice the weight out of the trails
    Attached Thumbnails Attached Thumbnails How much does a Fat Bike weigh?-kk-port.jpg
    Reputation: duggus's Avatar
    / F
    Thread bumpin for a steel fat bike weight eh?
    They are somewhere around 34lbs, but it's not a bike to ask about weight. You don't get steel for light weight.
    ...Be careful what you're looking at because it might be looking back...
    Apr 2014
    Not to much 😃
    Attached Thumbnails Attached Thumbnails How much does a Fat Bike weigh?-fb_img_1441137713759.jpg
  67. #67
    My pug is about 45# w/ rack and fenders.
  68. #68
    Quote Originally Posted by HardyWeinberg View Post
    man up!
    2012 Moonlander.
  69. #69
    Dec 2013
    Quote Originally Posted by duggus View Post
    Thanks, might be a bit to much then? , i was thinking of buying one to my 11 year old son, i know it's steel and that Surly don't do light stuff!
    He have tried my ICT 16" and likes it, but the frame size is to big.
  70. #70
    Quote Originally Posted by bighit View Post
    man up!
    It looks like I could take several pounds off w/ new wheels and maybe tires. And that rack.
  71. #71
    Small Hellga Comp
    32.4 lbs
    Will investigate if the potentially new spec stout xc 90 rims are more tubeless compatible or not. Then I will await my Large FatCAAD.
  72. #72
    Reputation: LewisQC's Avatar
    Jul 2013
    Salsa Blackborow: 32 lbs
    1x conversion with Raceface Turbine Cinch 26NW
    JJ 4.8, tubeless with clear duct tape method and 4 onces of Stan per wheel
    Attached Thumbnails Attached Thumbnails How much does a Fat Bike weigh?-img_4218.jpg
    2015 Salsa Blackborow 1
    2017 Devinci Hatchet Carbon
    2009 Spec Tricross Sport
    2019 Ibis Ripmo
  73. #73
    Jul 2013
    Turner King Khan fully, 33lbs with Beist combo
    Muru rigid fatbike, 26lbs
    Both bikes with hydraulic dropper post
  74. #74
    Nov 2014
    My Pugs was just over 38lbs...
    my new carbon fiber fatty is 22.5lbs
  75. #75
    Jul 2015
    Just under 31 LBS before the bag and before the Raceface NextSL seat post (only a ****hair lighter)
    Attached Thumbnails Attached Thumbnails How much does a Fat Bike weigh?-image.jpg
  76. #76
    Um...my medium 2x10 pugsley with sarma carbon wheels, XTR, schmolke TLO & Tune cockpit is just weight around 12kg.
  77. #77
    Jan 2014
    My new large Pugsley SS weighed in at ~32lbs naked, and 37 lbs loaded for a day ride with tire-repair kit, pressure gage, bike multi-tool, full 22 0z water bottle, Topeak Mt Morph frame pump, gas-tank frame bag with phone, camera,& snacks, keys, I.D., medical info card, and a bell.
    Add 5lbs to the above to get the weight for my other Pugs with Shimano Alfine 8-spd hub and Big-O fenders.
  78. #78
    Fen
    Fen is offline
    Mar 2014
    Large Ice Cream Truck, 14.4kg / 31.5lb:
    Rockshox Bluto 120mm
    KS LEV 150mm dropper post
    Nextie 90mm Carbon rims
    Hope hubs
    203 f and 180 r IceTech rotors
    Dillinger 5s tubeless (no studs)
    Next SL crank & Cinch BB
    Raceface 6C Carbon bar & 35mm Atlas stem
    XTR 1x11, brakes and pedals
    Tune Speedneedle saddle
    Attached Thumbnails Attached Thumbnails How much does a Fat Bike weigh?-img_2441.jpg
  79. #79
    Feb 2012
    Blinged ish ICT size large 32lbs with Jumbo jims and 34 with buds! Damn far too light I need to MTFU and make it over 40lbs
  80. #80
    Reputation: DubzOxford's Avatar
    Nov 2012
    With the new Kenda Juggernauts, I got my SS Pugs under 24 lbs. I took the Kenda's off and put the Husker Du's back on, she is under 25 lb now. I love this bike.
    How much does a Fat Bike weigh?-img_6468.jpgHow much does a Fat Bike weigh?-img_6465.jpgHow much does a Fat Bike weigh?-mill-photo.jpg
  81. #81
    Dec 2011
    Just weighed my Motobecane Boris the Evil Brut Sprung. 17.5 inch (medium) frame. Tubed setup. 120mm Bluto.
    35 pounds, almost exactly.
    Edit: weight post tubeless conversion: 33 pounds.
  82. #82
    Addict
    Dec 2010
    19lbs 14oz without pedals like a manufacturer would weigh it.
    20 lbs 8oz ready to ride
  83. #83
    Jan 2016
    2016 Trek Farley 7 size small,100% stock, with tubes . 29.4 lbs.
  84. #84
    Reputation: sbsbiker's Avatar
    My Beargrease w/ carbon hoops is just under 28#.
  85. #85
    Reputation: danaco's Avatar
    My Borealis Crestone.
    150mm KS dropper
    Bluto fork
    HED BFD's/Bud/Lou
    Next SL cranks
    XO 1x
    SPD pedals
    Guide brakes/Storm rotors
    King Ti cage
    26.75 lbs weighed on very accurate analog scale
  86. #86
    Reputation: dbhammercycle's Avatar
    @RENCRN8
    I saw your bike in another thread and would like to repeat, more or less, that the weight of that bike is ridiculously low. Wow.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
  87. #87
    Mar 2012
    36lbs
    XT drivetrain 2x10
    e13 TRS+ crank
    BB7 brakes
    Atlas 760mm bar
    D4 27tpi studded tires
    lightweight tubes
    stock On One wheels
    Chromo fork
    2018 RSD Middlechild
    2010 Giant STP SS
  88. #88
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    My Fatback "June" is about 1/25 of Honey Boo Boo's mom.
    Attached Thumbnails Attached Thumbnails How much does a Fat Bike weigh?-honey-boo-boo-mom-most-googled-women-2012.jpg
    ptarmigan hardcore
  89. #89
    Nov 2015
    Quote Originally Posted by RENCRN8 View Post
  90. #90
    mamadirt
    Reputation: mamadirt's Avatar
    Sep 2004
    On-One Baby Fatty just a touch over 34lbs - pretty much stock apart from cosmetic changes
    Happy with that and in no rush to change anything else as it feels light compared to my Bottlerocket.
    Welcome to the Hotel California . . .
  91. #91
    Reputation: MUSTCLIME's Avatar
    My Boris exceeds the max hauling weight of my friends super duty pickup....or so I have been told.
    The bike is never to heavy, you are just to WEAK!
  92. #92
    Old, Slow and now FAT! :)
    Reputation: TheNormsk's Avatar
    My Motobecane Stugis Bullet stock with no pedals is 35 lbs. In current config with pedals it's 34 lbs.
    I plan to swap out tires soon and go tubeless. Expecting to get to 32 lbs with no weight weenie parts and big Bluto fork.
  93. #93
    Reputation: Heikki's Avatar
    Jul 2015
    Stock 2014 Trek Farley 19.5" + 45nrth Helva pedals + Raceface Bash
    32#
    33# with 2 Bottle Cages + Odo + Redlight + Lezyne Micro Floor Drive HV
    37# with above + Front and Rear OMM Racks
    Wannabe Biker
    14 Farley * 16 CAADX * 01 Raleigh M60
    07 Monty Paratrooper
  94. #94
    Not the fake Jay Leno
    Reputation: Chinman's Avatar
    Dec 2014
    Quote Originally Posted by DubzOxford View Post
    That's mighty impressive right there. Nice work! My Pug SS is 30.8 lbs, pretty much stock with the exception of ghetto tubeless, Ergon grips, Surly tugnut, and an extra cog on the back (17 or 22 T). This is a great riding bike!
  95. #95
    Nov 2015
    My large NTB w/100mm Bluto is coming in at ~34 pounds now, stock but for:
    Mulfuts tubeless with SunRingle kit
    40mm Husselfelt stem
    640mm XLC riser bar
    Ergon GE1 grips
    Candy 1 pedals
    T-Mars dropper seat post
    I'm annoyed that I'm so far from 30#, but still feel that the bike was a good deal. I think if I converted to carbon handlebars and stem, a lighter dropper, and 1x10 or 1x11 I could get down to 31.X# but it doesn't seem worth it.
  96. #96
    Reputation: Swerny's Avatar
    that is redonculous!
    Mike
    Toronto, Canada
    2019 Scott Foil 10 Disc
    2019 Norco Search XR Steel
    2017 Trek Farley 9.6
  97. #97
    Dec 2011
    Quote Originally Posted by danaco View Post
    150mm KS dropper
    Bluto fork
    HED BFD's/Bud/Lou
    Next SL cranks
    XO 1x
    SPD pedals
    King Ti cage
    This is not a particularly low end bike. Awesome stuff there.
  98. #98
    Addict
    Dec 2010
    Quote Originally Posted by Swerny View Post
    Trust me, I agree. It sits in my living room and every once in a while I walk by and pick it up just to be amazed again and again.
  99. #99
    Surly Wednesday, 32.25lbs with pedals/dirt/snow
    Medium frame/stock fork
    Salsa hubs/Mulefut rims
    Flowbeist/Dunderbeist (tubeless)
    SRAM x9 1x10
    Race face turbine crankset
    Hayes Dyno comp brakes
    Thomson post/80mm stem
    On One Knuckleball carbon bar
    Ergon GA2 grips
    Xpedo Spry pedals
    Jason
  100. #100
    Jan 2016
    Small Farley 7 with tubes 29.65 lbs.
    Small Farley 7 tubeless with 6oz of stans in each wheel 28.24 lbs.
    Brian
  101. #101
    I would do the same.
    Here is my blue Farley I stole the carbon wheels from the black Farley (converted it to 27.5+)
    A hair under 25lbs ready to ride and trust me there is a boat load of Orange seal in each tire. I hate flats.
    Marty-MJ
    MJ
  102. #102
    Dec 2011
    That's an incredible weight given the Bluto.
  103. #103
    Oh, that's pretty.
    I contemplate things to lighten up the fat caad1. Ditching the dropper post would be a good start. And something like those HEDs once a lefty 73 hub becomes available (preferably in fun colors via i9 or elsewhere).
  104. #104
    Reputation: Dilligaff's Avatar
    Nov 2015
    My '08 Pugs shows up at 35# almost exactly, even with the heavy assed double wall Large Marge wheels. It also has tubeless Nates, aluminum seat post, and heavy pedals, so I know it could drop some more weight pretty easily.
    I don't have a picture, but my Motobacon NTB Ti is just a shade over 33# but that is tubeless.
    Nothing to see here, move along folks.
  105. #105
    I want to see a thread of frame, Fork only weights. lets face it that where the heart of the overall weight is. if you have a 5lb Surly frame you are always gonna have 2lbs over some of the Alu/carbon frames.
    40lb Moonlander. no weight savings at all. Didn't even cut the steerer. 2xl up front, Lou rear, 100mm rims plus tubes. Jones bars w/ergon grips. Fenders, flats, stock cranks rings and bash guard.
    2012 Moonlander.
  106. #106
    Feb 2012
    This should make some of you happy with your weights.
    My Mongoose Argus Expert (small) was 16.82kg stock, but now weighs a minumum of 19.16kg=42+ pounds because I am going for reliability.
    One time I had to push a KLX250 out of the jungle after burning out my clutch and thought I was going to die doing it.
    There are 60 poisonous snakes in Thailand and my friend saw a King Cobra (not the malt liquor) riding around. FYI, I have seen one in a tree but it was at a zoo.
    So I made it a little lighter going 1x.
    Deckas 32t 104bcd NW chainring (41g). Stock 24/38t rings were 25/64g.
    Losing the front derailleur/shifter/cable dropped 394g.
    A Ritchey WCS stem (45mm reach=124g) helped.
    Then I went heavier on everything else and stopped measuring grams.
    Brooks B67 spring saddle.
    Ergon GP3 biokork size small grips.
    Truvativ alloy seatpost 400mm (stock 270mm too short for 30" inseam).
    I made the framebag (poorly) to hold a 2 liter water bladder and pump.
    Modded Beto CMP-088 floor pump 351g.
    Strida cage on the seatpost to hold sweet drinks.
    Saddle bag contains a full size spare tube, multitool, chain breaker/links, patch kit, and 2 levers.
    Copper ID badge.
    Innertube chainstay wrap.
    I was not OK with split tubeless on these undersized rims; so I added 8oz of Slime/Stans mix in each tube instead.
    With another 1-2kg of drinks this baby is a real handful, but I don't ride fast and its still lighter than a motorcycle.
    If I go night riding I will add another kilo in 2 lights and a battery pack.
    If I never crash this one and stick with fatbikes a few years; then my next one will be all carbon.How much does a Fat Bike weigh?-2016-02-11-22.25.24.jpgHow much does a Fat Bike weigh?-2016-02-11-22.25.57.jpgHow much does a Fat Bike weigh?-2016-02-11-22.25.33.jpg
  107. #107
    aka bOb
    I don't believe in reliability also means it needs to weigh a ton, there is a happy medium if one wants to throw the cash at it.
  108. #108
    I bet that if i took all the parts off my Moonlander and put them on a fancy carbon frame i would have a 37lb carbon bike.
    2012 Moonlander.
  109. #109
    aka bOb
    It's funny how people equate a carbon frame bike to be automatically super light. It's not, it's a sum of all parts.
  110. #110
    Yes the sum of the parts. However if you use a frame and fork that are lighter you will end up with a bike thats lighter in the end.
    2012 Moonlander.
  111. #111
    Has anyone mentioned weight loss, ie going on a diet?
    Ya know, it's a lot cheaper and generally a healthier way to go physically as well as fiscally.
    My Mutz is over 30#, I have no idea by how much because I think weighing it would be silly.
    I just added a pound by changing from a Bluto 120mm to a longer travel, burlier fork (Wren 150mm). This change gets filed under "Hell Yeah"!
    I just lost a pound changing from Floaters to JJ 4.0s, this was a positive change, better tires, running cleaner, still give good traction and support. I run 300gm tubes, which are more reliable than tubeless and just about the same weight.
    I suppose I could get some RF Carbon Cinch cranks and lose 250 grams, that might be worth it....
    Deity nylon pedals with steel pins are 300gm, not a lot better out there for platforms that work and are durable.
    Volt Comp seat wide, fairly comfortable, for $150 I could lose 100gms changing to a Pro.
    SRAM ghetto 1x, I suppose I could spend a bundle and get a lighter weight 11sp rig, but the weight loss would be minimal and the cost would be substantial as I share wheels on multiple rigs.
    In terms of functionality and strength:
    - I'm not losing the dropper, it's one of the most functional things I own, awesome for changing position when riding steep terrain and doing drops.
    - My Onyx rear hub is the shite, durable, instant engagement, you can take it from me when rigor mortis has set in.
    - All my little parts are light and functional, Ergo grips, 7000 series Kore bars, RF stem, Guide RSC brakes.
    But if I lose ten pounds, now there's a change I can live with and it won't cost me a cent!
  112. #112
    Good point Ben, you shouldn't care too much about fat bike weight if you've a tire around your waist. Unless it's a bling bling thing.
  113. #113
    Quote Originally Posted by ttakata73 View Post
    How much did the cobra's bike weigh?
    Latitude 61
  114. #114
    I had a light bike once. I realized i was still fat and slow.
    2012 Moonlander.
  115. #115
    Quote Originally Posted by Nurse Ben View Post
    Come on Ben, only everyone who thinks removing weight from a bike, any bike not just fat bikes, is silly has asked this. Well maybe not everyone of them but lots and lots. This is not a new question and it will never be resolved. Both sides of the debate have good, and bad, points that can be made. Sorry to be contrary, but you did ask.
    Latitude 61
