Hope Fatsno thru axle QR Skewer- Mtbr.com
Results 1 to 10 of 10
    Reputation: Lordie's Avatar
    hi all,
    anyone knows what works best for Hope Fatsno hubs on Surly Wednesday?
    will the DT Swiss ones works? or those china OEMs like this Bitex : MTB hub,BMX hub,SHOW hub,FOLDING hub,CHILD hub, Wheelchair hub
    thanks in advance,
    Well, i can tell you that based on the frame, your either going to have thru axle OR quick release skewer. They're two different things.
    Reputation: dbhammercycle's Avatar
    The front is a 15x150
    The rear is 177x12, but compatible with 170x10mm QR with the Surly adapter.
    WEDNESDAY FAQ | Blog | Surly Bikes
    So, yes the DT RWS should work nicely, as long as you get the right size.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by dbhammercycle View Post
    DT RWS is not available in a wide variety of fatbike-compatible sizes. I have a 15x150mm one for my Bluto. IIRC, though, the Wednesday fork doesn't have threads built into the fork, so the thru axle needs to have a nut included with it. Surly's site doesn't mention thread pitch of the included nut/thru axle. The bike comes with the front thru axle, FWIW.
    RWS does come in a 12x177, but it's sold under the Salsa name, and it's made to specifically fit the Beargrease. My Bucksaw is a 12x177, but it uses a different thread pitch than the Beargrease frame, so the RWS 12x177 thru axle won't fit. Surly doesn't mention the thread pitch of the rear axle "washers" that let you use a thru axle in the Wednesday.
    Thread pitch is an absolutely essential piece of information for this query, and I think you'll have to ask Surly directly to get the answer.
    I didn't realize that different manufacturers are using different threads for their forks or rear dropouts. I probably should not have assumed that would be consistent/compatible/standardized. The ASS bypasses U and lands squarely on ME.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Paragon Machine Works modifies DT Swiss RWS skewers with longer bolts. They MAY make the one you need.
    I like turtles
    since 4/10/2009
    Quote Originally Posted by NYrr496 View Post
    I looked into it, but they still don't offer every possible option. Still can't get one that fits the rear wheel of my Bucksaw. What I REALLY want is a thru axle without the lever (turn it with a hex wrench) for the back to eliminate a hangy bit that catches on stuff sometimes.
    turtles make me hot
    I tried asking them about making 135x9 and 190x10 RWS for QR fatbikes. They told me some crazy crap like needing to pay for R&D and a 300 minimum.
    Needless to say, I dropped it.
    I like turtles
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by Harold View Post
    I've toyed with the idea of a hollow ti axle with an allen with a loop on one end and another piece to make it a t wrench stored inside of said axle.
    since 4/10/2009
    Quote Originally Posted by bdundee View Post
    I'd buy one.
  1. Hope Fatsno Thru Axle Conversion?
    By Fatty In Hamilton in forum Fat bikes
    Last Post: 07-27-2016, 11:14 AM
  2. Replies: 36
    Last Post: 01-31-2016, 12:00 PM
  3. Replies: 7
    Last Post: 12-22-2015, 01:21 PM
  4. Having Hope Fatsno Problems? Look Here.
    By jonshonda in forum Fat bikes
    Last Post: 04-27-2014, 07:35 PM
  5. Replies: 3
    Last Post: 09-13-2013, 07:34 PM
