Help me pick a second fatbike frame- Mtbr.com
Results 1 to 7 of 7
    I'm looking a second fatbike frame and fork (new or used) with the following requirements:
    - Must fit an existing wheelset - 26" x 90mm (150/197 spacing).
    - Hoping it can fit someone in the range of 5'9" - 6'0" - maximal stand-over height key here I think
    - Not looking to break the bank, so aluminium or steel - not carbon.
    Long version - usage is as a spare or guest bike. Would like for visitors to be able to get out and try fatbiking while they are here. But would also be good to have a second bike to use if something goes wrong with my regular ride (XL Salsa Blackborow - 2015).
    My wife has a Medium Bucksaw which can work for smaller guests in the 5'6" - 5'9" range.
    So I'm thinking a Medium/Large frame with lots of standover height.
    Wheelset currently has Vee 2XL rubber but that doesn't have to stay - that would limit things a bit too much I think.
    Thanks for any and all input.
    Reputation: dbhammercycle's Avatar
    RSD still has some V3 Mayor frames at 60% off if you don't want/need a large, they still have medium frames.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Nov 2017
    Nov 2018
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I have this one, it's been great, able to use the largest 2XL tires or move the dropouts up and use smaller tires with shorter chainstay:
    CS-197 NEW Two position dropout Fat Bike Frame CS-197 - Xiamen Carbon Speed Sport Goods Co.,Ltd
    Should be $300-400 normally.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I was also going to suggest the Mayor but like DB said, they're out of Larges.
    I just did a scan over on ebay and based on what I'm seeing only frames going for without forks, I might be tempted to buy a Surly Ice Cream Truck frameset. Careful though, it might become your favorite bike and not just a backup.
    I like turtles
    Reputation: Aresab's Avatar
    My experience is the Mayor runs a little big. I bought two Mediums to build for spares figuring they'd fit the widest range of people. I'm 5'11.5 and typically ride a Large El Oso w/ 20" seat tube and honestly could easily ride the medium RSD Mayor when/if mine was down.
  1. Second Set of Wheels/Tires or a Second Bike?
    By CanyonEnduranceCross in forum Cyclocross
    Last Post: 02-25-2018, 11:33 AM
  2. Replies: 1
    Last Post: 11-18-2015, 09:54 PM
  3. Replies: 9
    Last Post: 12-03-2014, 01:37 PM
  4. Replies: 1
    Last Post: 03-12-2012, 04:55 PM
  5. Pick me, Pick Me....Pick me!
    By brado1 in forum Riding Passion
    Last Post: 01-30-2006, 01:41 PM
Members who have read this thread: 95
