Help with 190mm X 15mm thru axle. What size are these threads?- Mtbr.com
Results 1 to 12 of 12
    Jul 2017
    New question here. Help with 190mm X 15mm thru axle. What size are these threads?
    Can anyone tell me what threads the shorter axle has in these pictures?
    I need a 190mm thru axle with the threads of the shorter axle.
    I didn't realize there were different thread sizes on these axles.
    Thanks for the help.
    Attached Thumbnails Attached Thumbnails Help with 190mm X 15mm thru axle. What size are these threads?-axle01.jpg
    You're looking for something that doesn't exist as far as I know. A 197x12 thru axle should be what you need. What frame is this for?
    Jason
    Disclaimer: www.paramountfargo.com
    RAKC Industries
    Jan 2017
    Best to loom up the manufacturer of the axle and drop out.
    Not possible to know thread diameter and pitch from a picture. But looks like m12x1.75, LOOKS LIKE judging by your 197 fat bike rear requirement.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    Jul 2017
    The receiver that will thread onto the shorter axle will not thread onto the longer one.
    These threads have to be different.
    RAKC Industries
    Jan 2017
    Ya i had to zoom in to get a good look, changed what i said. You need to know manufacturer and such to know for sure unless you have a caliper to measure diameter and pitch
    Jul 2017
    The fork is from a Mongoose Argus Comp bike. Called Pacific Cycle and could not get any help at all from them.
    RAKC Industries
    Jan 2017
    Well forks are not 190 so a bit confused as to what exactly your trying to do. Is the threads in the rear drop out the same?
    Anchorage, AK
    Reputation: Lars_D's Avatar
    I think the threads are 15 x 1.25 on the shorter axle.
    --Peace
    Jul 2017
    So if I ordered this course threaded Paul axle it would more than likely be the same as the top axle in my pictures?
    Attached Thumbnails Attached Thumbnails Help with 190mm X 15mm thru axle. What size are these threads?-paul.jpg
    RAKC Industries
    Jan 2017
    You need to confirm thread diameter and pitch otherwise your just wasting money
    And does the shorter axle fit your rear (except being too short)? Slides in hub correctly and threads into the dropout?
    Reason i ask is that if both those axles are for 15mm thru axle hubs, the threads on the shorter axle are not 15mm diameter. They are smaller, can see that in the picture.
    Us a ruler and check the diamter at the very least.
    And dont order that, the longer formula axle you have pictured says the thread specifications right in your second picture.
    M15x1.5
    M (metric in mm) 15 mm
    Pitch= p 1.5
    Same exact thing your trying to order which you know is wrong already.
    Reputation: blekenbleu's Avatar
    Aug 2016
    Using my calipers on the image for diameters and counting threads in comparison to the upper, the lower thread appears to be M13x2.0
    Jul 2017
    Mind Blown, I'm just giving up.
  1. Replies: 33
    Last Post: 04-22-2018, 12:41 PM
  2. Replies: 7
    Last Post: 12-22-2015, 01:21 PM
  3. 10mm thru-axle skewer for 170 or 190mm hubs?
    By awai04 in forum Fat bikes
    Last Post: 12-02-2015, 02:38 PM
  4. 15mm Axle wheels with 9mm thru axle
    By shmtastic in forum 29er Components
    Last Post: 12-01-2014, 12:30 PM
  5. Need help. 9mm thru axle to a 15mm thru axle.
    By specialized11 in forum 29er Bikes
    Last Post: 07-05-2013, 03:33 PM
