Helmet cover for cold weather fat biking- Mtbr.com
Results 1 to 14 of 14
    Anyone tried an over the helmet cover instead of, or with, head cover for cold weather riding? Pros and cons?
    Thanks,
    Urmb
    “How inappropriate to call this planet "Earth," when it is clearly "Ocean.”
    ― Arthur C. Clarke
    Reputation: BlueCheesehead's Avatar
    i have used one of these:https://www.amazon.com/AYAMAYA-Refle...e+helmet+cover
    You still need to wear a beenie/hat, moisture will condense on the inside of it and you need to cut it up to install a light. By eliminating any ventilation it does help retain some heat but at the cost of a wet head. Mine sat in a box all last winter.
    Reputation: veloborealis's Avatar
    I wouldn't bother. I biked year round in Alaska for nine years and never used one. A thin, Smartwool beanie did the trick most days. My outerlayer, Marmot ROM soft-shell, had a hood that fit over my helmet to prevent wind infiltratation. Rarely needed it, but it was there for extreme conditions or for rest stops to preserve heat. We lose most body heat through our head, so during exertion it needs less insulation than other parts of the body. Often I would be sweating with just the beanie. Good reason for using wool.
    Veni vidi velo!
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Why buy some other random bit of Chinese made junk and give Amazon another chance to kill the world one order at a time, when you have the solution in your shop already?
    Been duct taping the front vents on my helmet for years. Stops that cold flow in front, lets the back ones keep working, problem solved.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Quote Originally Posted by MendonCycleSmith View Post
    Great idea!
    Veni vidi velo!
    Lot of people use downhill ski/snowboard helmets. Many have adjustable vents. You don't even need a beanie when it's in the 20's but are also good to go when it's cold.
    Latitude 61
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    I use an LG cover
    https://garneau.com/ca_en/h2-cover-1083138
    and one or two thin merino wool beanies. usually one but two if at night and getting into the 20's F or lower. neck gaiter also
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Sep 2016
    I just use clear Gorilla tape over the vents....works great.
    Reputation: chode's Avatar
    Genius! I’m going to try black electrical tape and see how that goes.
    16' Framed AK white/black 21" FAT
    97' Cannondale Super V yellow/black
    Feb 2005
    Glad to help!
    - FrostyStruthers
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    That and let me put a shout-out for Buffs. They are incredibly versatile and good to temps like 20s. You can use as a beanie or more like a balaclava, or a neck-warmer. Small and easy to pack.
    Mar 2016
    I use a lightweight hat under my helmet that has windblock built into the hat. If it is really cold (<0 F) then I will use a light hat/beanie under the windblock hat. Both hats wick moisture and block wind. Works great, no need to tape vents, etc.
    I was considering 10 and below rides and windy rides, but the collective experience makes sense. My skull caps work. I like the vent taping ideas for extra windy rides. Even leaving the back ones open for sweat evap path.
    urmb
    ― Arthur C. Clarke
    Reputation: Velobike's Avatar
    I am another user of duct tape. The secret is to leave enough vent to get some airflow to remove the mist of sweat around your head otherwise it can freeze solid if you have a fast descent, but if you don't have a vent then your head gets sweat soaked anyway with the potential to ice up.
    Experimentation is worthwhile because there's not many helmets with the same vents.
    Latitude: 57º36' Highlands, Scotland
  1. Onyx in COLD weather? Good cold weather hubs?
    By car bone in forum Wheels and Tires
    Last Post: 02-11-2016, 04:23 PM
  2. cold weather riding - how cold do you ride?
    By overmodulated in forum Massachusetts
    Last Post: 12-27-2014, 10:43 AM
  3. Preferred brakes for cold weather fat biking
    By DAVID J in forum Fat bikes
    Last Post: 12-04-2014, 08:34 PM
  4. Cold weather apparel. What are you wearing for the cold rides?
    By masterlucasdude in forum Apparel and Protection
    Last Post: 08-10-2011, 06:42 PM
  5. I get a cold after cold weather riding
    By rockdude14 in forum General Discussion
    Last Post: 11-17-2006, 03:56 PM
