Having trouble getting Hodags to inflate....Tips?- Mtbr.com
Results 1 to 11 of 11
    Mounting Hodags on Mulefut 80 and cannot get them to inflate. I'm using FattyStrippers
    The tire seem a little loose on the rim.
    Any experience out there?
    fat guy on a little bike
    sorry, i only have experience mounting hodags and mulefuts the way they were designed to be mounted...
    i was told FattyStrippers are:
    Reputation: BlueCheesehead's Avatar
    Did you try a strap or rope to push the center of the tire down and beads out like this:
    Quote Originally Posted by Rodney View Post
    I have always found strippers expensive and not that satisfying...Come to think of it, the product is aptly named. (Yes, I have tried them, but NEVER would with Mulefut.)
    Haven't tried that yet, will tonight.
    Was also considering installing and inflating a tube then just releasing one side of the tire to remove tube.
    Was just curious to see if anyone else had similar issues installing the same combo.
    Dec 2008
    mulefute v1 or v2 rims? I have been hearing the V2 rims are looser than the V1 rims.
    27.5 v1 65mm and they are TIGHT w/ the hodag's
    27.5 v1 80mm and they are tight w/ vanhelga's
    Minnesota Off Road Cyclists www.morcmtb.org
    Quote Originally Posted by Tree View Post
    Tube to set a Fatty Stripper? That would be a new one on me. I guess it could work.
    Oh, you are using an air compressor, right? Not many set with a floor pump.
    Did you remove the valve core for max air flow?
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Remove core, strap around tire, air compressor, add soapy water sprayed around the bead or sealant brushed on around the edge.
    Reputation: Swerny's Avatar
    use the actual Sun Ringle rim strips and tape. Hodags and Mulefut should be an easy setup
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    What I do is put two layers of sill foam from Home Depot around the rim to take up space, with my getto tubeless over the foam. Can be a bit of a pain to mount the tire but it is tight enough to make inflation possible with a floor pump.
    The foam is wider than the rim so you need to cut it to width.
    The strap worked!
    Thank you.
  1. Having trouble getting 5.7 cockpit dialled
    By sukebe in forum Pivot Cycles
    Last Post: 04-16-2013, 11:35 PM
  2. New to duallys - Having trouble getting the front wheel up
    By TurboCrash in forum Beginner's Corner
    Last Post: 06-13-2012, 01:38 PM
  3. Having trouble getting parts for my Woodman SS hub
    By Finch Platte in forum Singlespeed
    Last Post: 09-14-2011, 09:24 AM
  4. anybody having trouble getting Crest rims?
    By HVskier in forum 29er Bikes
    Last Post: 04-15-2011, 07:54 PM
  5. Tips to inflate/seal difficult tires
    By dbblackdiamond in forum Wheels and Tires
    Last Post: 05-01-2008, 01:38 PM
Members who have read this thread: 72
