    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    half the fat i want to be
    Fun. Very tough to pedal, but better than when I ran the fat front on my 29er. Def. need to get a full fatty. But, this is better than nothing.
    Veni Vidi Biki
    I came, I saw, I biked.
    Thumper
    Reputation: WickedLite's Avatar
    Till you do you might want to get a better rear tread. I love Voodoos and know they run pretty tight in the stays but maybe you can go more paddle tread like a Smoke. Should fit.
    OR a set of dh Nokian Gazzalodi 26 x 3.0 (with rims, rotors and cassette) on ebay for $50 right now if you can make them fit. Heavy though 1700g a tire. Note: they are 26" and deflated but when inflated are a lot bigger. Google some images to see.
    VENI VEDI BIKI
    clearance on these bonty 2.35s is about 3 mm on each side down at the chainstay
    Veni Vidi Biki
    Thumper
    Yes that is tight.
    If you go a 26" rear it might fit behind the tight section of your stays and open a little room for a 3.0 26". You Hoodoo should have 425mm stays.
    Nokian Gazzaloddi 3.0 Tread width: 71.6mm, Axle to tallest tread: 356mm
    Nokian Gazzaloddi Jr. 2.6 Tread width: 62.6mm, Axle to tallest tread: 346mm
    Nokian NBX DH 2.5 Tread width: 60.5mm , Axle to tallest tread: 345mm
    (copied from mtbtires.com with plenty more details of each tire and there are smaller choices)
  1. Half Fat
    By drofluf in forum Fat bikes
    Last Post: 08-16-2015, 02:32 PM
  2. Crank Bros pedal question: Half platform, half clipless?
    By Hawgzilla in forum General Discussion
    Last Post: 12-19-2013, 11:53 PM
  3. I need help with 26" tire set up for half XC and half road.
    By cornsupial in forum Wheels and Tires
    Last Post: 03-25-2013, 12:10 PM
  4. Replies: 2
    Last Post: 06-23-2012, 11:09 AM
  5. Our half Colorado and Half Wyoming weekend
    By Zeroack in forum Riding Passion
    Last Post: 06-15-2011, 01:01 PM
