Ground Control 4.0 vs 4.6- Mtbr.com
Results 1 to 7 of 7
    Just picked up a FatBoy as a Christmas present for my wife. When I picked it up I totally missed that it had 4.0's on it. Obviously a mix up since it's a standard Fatboy and should have the 4.6. I've only ever run the 4.6 that came on my Fatboy, wondering if anyone has had a chance to try the 4.0 and what the impressions are. I can swap them out through the dealer but need to do it before she rides it , so a "ride it and try them" is out of the question.
    BTW, this bike will only be ridden in snow, in Colorado.
    Reputation: tyriverag's Avatar
    Jan 2014
    There are a lot of tire questions on this forum, many of them completely unnecessary. However, I don't believe I've ever actually read a question about how two tires compare - both the skinny and regular version, of the same tire.
    it's a challenge some of us are ultimately worthy of.
    Quote Originally Posted by tyriverag View Post
    yeah, yeah, I tried a search and came up with nothing. New to Fat and not up to speed on all the different tires.
    Reputation: JesusJuice's Avatar
    Dec 2014
    I don't think there is much weight penalty to go with the 4.6" one.
    Reputation: arn907's Avatar
    May 2014
    I just got a comp carbon for Christmas and did the same thing. Swapped the 4.0 out for the 4.6s before riding. Switched the tubes out at the same time so I actually lost weight.
    Jul 2014
    I haven't seen a weight on the 4.0" GC, but if you are looking at using for low traction conditions like snow and sand, I'd go with the larger 4.6" tire. The 4.0" should be lighter and will probably hold an edge in rolling resistance if you are just looking for general trail use though.
    19 Fargo Ti
    '17 Cutthroat
    '15 Fatboy Expert
    Dec 2014
    Quote Originally Posted by chongo View Post
    4.6 Tire.
    If it matters, you will have a lower bottom bracket height with the 4.0
  1. Ground Control Fat
    By shoo in forum Fat bikes
    Last Post: 01-29-2016, 05:51 PM
  2. ground control
    By slowandlow in forum Colorado - Front Range
    Last Post: 08-06-2013, 06:15 PM
  3. Ground Control tyres
    By R+P+K in forum Specialized
    Last Post: 12-05-2011, 07:53 PM
  4. Specialized Ground Control.....
    By IFdeelux15 in forum Specialized
    Last Post: 09-24-2011, 09:34 AM
  5. Specialized Ground Control
    By SLIMBOY in forum Vintage, Retro, Classic
    Last Post: 06-07-2011, 08:54 PM
