Gear ratios- Mtbr.com
Results 1 to 7 of 7
Thread: Gear ratios
    Oct 2015
    Gear ratios
    So Iíve had the Framed Minnesota 2.0 for a couple of years now, and love it.
    Came across the Alaskan carbon model a couple of weeks ago, and bought it, pretty awesome bike for the money.
    I was wondering, what gear ratios are available for the front chain ring. I am coming from a double chain ring on the 2.0 to a single on the Alaskan.
    Last couple of times, I feel like I am over spinning on the Alaskan, using the 11 on the back, and I believe the front is 32.
    I feel that if I go with a little bit larger front chain ring, would be ideal.
    Or, like on a rode bike, do I need to get a new cassette for the back with a different ratio? Is the a 10 available.
    Any suggestions would be greatly appreciated
    , I like to ride on paved/gravel trails.
    Thanks.
    Wanna ride bikes?
    Oct 2013
    Sounds like you just need a bigger chainring, but it would be helpful to know what cassette is on the back?
    If the frame has clearance you could switch to a 34t chainring, or maybe a 36t.
    No, most likely you can't get a 10t small cog on the cassette. Posting pics of your current setup would help though.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Oct 2015
    Bought it from someone who rode it only a couple of times, so i think it is all stock.
    Looking at the website, it looks like it came with 11-50 cassette on the back, and it is also a 12 speed Eagle components.
    Will try taking a pic tomorrow and will post it.
    Thanks for the reply.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by laxdad View Post
    Thanks.
    What do you need the larger front for? Are you spinning at 90rpm on the front? I say this with the caveat that wind resistance limits me far more than gearing does on a fat-bike, racing high expert and occasionally winning races, with a 32 up front. I think a lot of this has been shown by how the old 42 and bigger rings have essentially faded away, even from DH riding, because while you could turn them, you really weren't going faster than turning the smaller ring with higher cadence.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Cheapest is just go up to a34 or 36 chain ring.
    Hybrid Leftys aren't real Moderator
    Feb 2005
    This is the workable part of the problem. I was puzzled, till I get to this...
    "I like to ride on paved/gravel trails."
    Ah.
    Yes, bigger ring in front, or, take some spinning classes and learn how to harness the power of higher cadence....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Have a play about with a gear calc, you can work out all sorts to compare what you have to what you would like...
    https://www.sheldonbrown.com/gear-calc.html
  1. 2 x 10 speed adopters - what gear ratios to spec?
    By awai04 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-15-2011, 11:00 AM
  2. OK, I searched. Gear ratios for serious climbing?
    By rideit in forum Singlespeed
    Last Post: 08-03-2011, 06:34 AM
  3. Gear ratios and hub engagement
    By rob_co2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-09-2011, 02:51 PM
  4. best gear ratios ever - ActionTec
    By CaveGiant in forum 29er Bikes
    Last Post: 02-07-2011, 11:22 PM
  5. Gear Ratios Question
    By wieczorek24 in forum Beginner's Corner
    Last Post: 01-30-2011, 08:08 PM
Members who have read this thread: 53
