Front tire recommendation- Mtbr.com
Results 1 to 16 of 16
    Reputation: Overkill's Avatar
    I have used a surly bud on the front for 6-7 seasons and itís really showing its wear. Iíve used a variety of tires over the seasons, but nothing has performed better consistently in my local conditions up here in Quebec, so the bud normally goes back on shortly after.
    I really appreciate a tire with nice float and predicable cornering in loose to hard pack conditions. The vast majority of the trails I ride donít see a lot of traffic and itís normally me breaking them in. I also ride well tracked trails, but I value grip over rolling, so Iím not too concerned with a better rolling tire on the front.
    Before I pull the trigger on another bud, has anyone found a better front tire that floats and corners as well as the bud?
    Reputation: Dilligaff's Avatar
    Nov 2015
    Nope, still the Bud. If the Bud came studded I'd probably even ditch the Johnny5 for the front.
    Nothing to see here, move along folks.
    Quote Originally Posted by Dilligaff View Post
    I had a non studded J5 on the front last year for a bit, and it definitely didnít perform as well as the bud. Itís a great rear tire though, and that has been my best combo so far: bud front and J5 rear.
    I donít really need studs where I live but I know some guys who have studded buds and are quite happy.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    If you know you love Bud, there's no reason to complicate things.
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    Quote Originally Posted by mikesee View Post
    +1 ^^
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    Iím not trying to complicate things! Iím trying to take advantage of the a group of fellow fatbike addicts who may have found a tire to perform better in similar conditions as I ride.
    I guess Iím just surprised nothing obvious has surpassed the bud as a better non studded all round front tire over the past decade!
    turtles make me hot
    Reputation: NYrr496's Avatar
    Another fan of Bud here. I stick with what works.
    I like turtles
    Rippin da fAt
    Quote Originally Posted by Overkill View Post
    Frankly, your question is quite well put. Redesign of this particular mouse trap doesn't seem to have been done successfully as Bud is still the baseline that all others are trying to meet or exceed.
    Tough to beat the Bud for snow!
    Another tire quality issue is suppleness of the casing. How flexible or pliable is it and is it sufficient for snow riding, etc.
    Surly/Innova got the supple/pliable part sorted long ago.
    Reputation: SteveF's Avatar
    Disclaimer-I have not tried the Bud. But I sure do like the Wrathchild as a front ungroomed-snow tire.
    I tried a cake eater on the front. While a good tire, it does not corner or maintain traction when leaning like a bud. After a few rides, the bud went back on. I ride on groomed, ungroomed, snowshoe groomed, runner groomed and deer and elk groomed trails. Only wish it was the tubeless ready version. 😁
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Bud is hands down, the best front tire I've ever used.
    Nothing else seems to even come close to the design, so everything else is relegated to second place by miles.
    Sure, others "work", (I have a Snowshoe 2XL which certainly floats too), but nothing else works as well as Bud for cornering, especially when things get soft.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Sep 2015
    Quote Originally Posted by SteveF View Post
    I've run both. I ride studded wrathchilds on one wheelset and bud/lou on the other. Bud is better for looser/deeper/ungroomed/fresh stuff. Wrathchild does OK but isn't as good. I do only weigh about 150 so wrathchild may perform better for me than larger folks because I don't need as much float.
    Quote Originally Posted by urmb View Post
    This sounds like similar conditions to what I encounter. Ok, so it seems unanimous! The bud still rules!
    Iíll be ordering the newer tubeless version. Now if only it came in the supple Schwalbe casing....too much to ask I suppose!
    Dec 2008
    Bud is good, but front and rear snowshoe 2xl psc are better.
    I use to run the bud / Lou combo since they came out. I like the 2xl psc better.
    Minnesota Off Road Cyclists www.morcmtb.org
    Quote Originally Posted by Cerpss View Post
    Thanks, I'll keep that in mind if I ever feel like I want to replace the Wrathchild.
    Reputation: in the trees's Avatar
    Mar 2005
    I like the Johnny 5 up front.
  1. High volume front tire recommendations
    By broncbuster in forum Wheels and Tires
    Last Post: 04-22-2018, 01:27 PM
  2. Front tire recommendation for FATS!
    By Mitch1171 in forum North & South Carolina
    Last Post: 08-17-2013, 11:08 AM
  3. Replies: 22
    Last Post: 10-25-2012, 09:38 AM
  4. Need recommendation for big squishy front tire
    By loginhater in forum 29er Bikes
    Last Post: 03-09-2011, 07:05 AM
  5. Tire recommendation - Colorado Front Range
    By PDB in forum Wheels and Tires
    Last Post: 03-14-2007, 09:40 AM
Members who have read this thread: 88
