Front Shifting Problems- Mtbr.com
    Reputation: drofluf's Avatar
    Dec 2010
    Having problems shifting from small ring to big on my Puffin, I can only shift if the chain is on the smaller cogs at the back.
    Set up is Mr Whirly cranks, Deore triple shifter and mech but just using the small and middle settings.
    Chain length seems OK.
    I can't change the H screw because the mech will rub on the crank, similarly the mech is quite High, about 8mm above the chainring. If I put it any lower it won't move far enough over to shift the chain before it fouls the crank.
    Any thoughts?
    If you need me I'll be at the bar
    Spooooon!
    Reputation: Hairllama's Avatar
    Which version of the Mr Whirly cranks are you using? The ones that are offset for the Moonlander won't work on a Puffin without swapping to the longer offset derailleur mount. I ran into the same problem with mine, but I was playing with different spiders on a Middleburn crank. I ended up with a 2x front shifter and less offset in the spider to make it work.
    Dec 2010
    Getting the Moonlander version was my first mistake! But I've got the right axle now so that bit's sorted
    Dec 2010
    Actually raised the front mech about 5mm and shifting is fine!
  1. SLX Shifting problems
    By trap121 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2013, 02:08 PM
  2. still having shifting problems
    By 29ernb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-23-2012, 03:46 PM
  3. Odd shifting problems...
    By Goannaman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-16-2012, 02:06 PM
  4. Shifting problems
    By morningmist in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-06-2011, 08:41 AM
  5. Shifting problems
    By morningmist in forum Beginner's Corner
    Last Post: 04-26-2011, 06:04 AM
