Frameset + Bluto combos- Mtbr.com
Results 1 to 20 of 20
    So which manufacturers or retailers are offering frame and suspension fork combos? The only one I can find so far is Rocky Mountain. Any others?
    Aug 2014
    Bikesdirect
    Dec 2014
    I did see Bikesdirect. That would be a good option except that they seem difficult to get to Canada.
    I don't see a frame-only option for Trek, and Specialized only offers a frame + rigid fork unless I'm missing something.
    Aug 2014
    Why not just get your frame of choice and buy a Bluto? Although I see what you are saying - there is only one production fat bike fork (unless you count the new Chinese fork), why not have a fram+fork combo? I bought a frame that was designed for this fork (Salsa Bucksaw) and had to buy the fork separately. I did find a good deal on the fork but the BikesDirect option only ads $300 where mine cost $460.
    Just figured it might save a few bucks to get the frame + fork + headset all together.
    Reputation: RickBullottaPA's Avatar
    Mar 2015
    Borealis offers a frame/fork combo for the Echo. Also, realize that all Bluto forks are not the same. The OEM forks that show up on the lower end bikes have different internals.
    Aug 2014
    Quote Originally Posted by RickBullottaPA View Post
    Actually all the Bluto forks are the same except the Borealis ones - they are putting in an RCT3 damper. There are no differences in the Bluto unless you get a pimped out Borealis one or put the upgraded damper in yourself.
    Mar 2015
    Good info, Destr0. I happen to have owned both, thus my perception. I had a Minnesota 3.0 w/a Bluto and now ride a Borealis Echo. Thanks for the info.
    Mar 2015
    Good info, @Destr0. I happen to have owned both, thus my perception. I had a Minnesota 3.0 w/a Bluto and now ride a Borealis Echo. Thanks for the info.
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    RSD The Mayor $1100.
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Good stuff guys, thanks. I was checking out The Mayor earlier but the website is down.
    Reputation: Fat907's Avatar
    Jun 2014
    What about the Blizzard from Rocky Mtn
    Was mentioned in the original post
    Sep 2014
    If you live within driving distance of the border, ordering from bikesdirect is doable. From Ottawa, its about an hour to a US border town where a UPS store does pretty good business receiving packages for Canadians... Pick up there and declare (or not) at the border on the way back.
    Quote Originally Posted by Fat907 View Post
    Had to
    Attached Thumbnails Attached Thumbnails Frameset + Bluto combos-uploadfromtaptalk1426889283849.jpg
    Team Captain
    Damn I just checked out the bikesdirect deal, that is stupid cheap. Someone clue me in, do the Bullet frames fit the 5" meat on 100mm rims?
    Rocking on a Rocky
    If you want to go nuts check out Wiseman Frame Works Or Matter Cycle.
    Quote Originally Posted by ScaryJerry View Post
    You might have to go through the thread.
    I can tell you mine fits 80mm rim/ snowshoe xl easily.
    I since switched to 65mm and 1x10 and there is about 4mm tire clearance with the chain
    Reputation: ADKMTNBIKER's Avatar
    Nov 2014
    I love my Mayor with the BLUTO. RSD is just working on the site. If you want one of their bikes. Try the factory or one of the shops that carry them. I'm sure there's still one around.
    Attached Thumbnails Attached Thumbnails Frameset + Bluto combos-img_1347.jpg
  1. clipless combos?!? how to get the right set up?
    By stonemxfan369 in forum General Discussion
    Last Post: 04-15-2013, 09:41 PM
  2. Hub/cog fixed combos
    By shackleton47 in forum Singlespeed
    Last Post: 08-27-2012, 04:58 PM
  3. 2X9 with all combos rub free?
    By OuterNational in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-25-2012, 09:25 AM
  4. 12 Hour combos?
    By robotfury in forum Singlespeed
    Last Post: 10-06-2011, 08:40 AM
  5. DB Combos version 3
    By trailbrain in forum XC Racing and Training
    Last Post: 09-08-2011, 04:59 PM
