Frame crack?- Mtbr.com
Results 1 to 11 of 11
Thread: Frame crack?
    Reputation: thickfog's Avatar
    Oct 2010
    Frame crack?
    This is the bottom bracket shell of my Surly pugs.
    Are these lines the start of cracks or just the powdercoat cracking?
    They emanate from the welds.
    I can feel them by running my fingernail across the lines.
    Light use on this bike. Surprised if these are the beginnings of the frame cracking.
    CRAMBA Chairman
    Full Tilt Boogie
    May 2005
    I would say it's suspect enough to warrant inspection at a trusted LBS, or a local frame builder if available. Have it checked before riding again just to be safe.
    I sell bikes here. Check out the Blog here. Facebook.
    44.951909NRTH
    Reputation: Old Bag's Avatar
    Agreed -- have it looked at just to be sure. Paint that cracks needs to be checked for movement going on underneath.
    Dr Gadget is IN
    Reputation: wadester's Avatar
    Yeah - powdercoat doesn't crack. It can chip and scratch, but not crack.
    I would pull out the BB and look at the inside of the shell. If it's a crack it should be on the inside too. You'll need an inspection mirror.
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
    Oct 2010
    Thanks. Great idea to look inside. Better than chipping the powdercoat away to see.
    CRAMBA Chairman
    bcv
    bcv is offline
    Surly has 3yr. warranty on Pugsley frames I think, so they should do something to make it right for you if indeed is a frame crack at weld. Hopefully this is not beginning of a recall, like the Salsa stems, I have a new Pugs heading my way soon.
    Reputation: Velobike's Avatar
    At least it is a steel frame.
    Even if it isn't covered by the warranty, any decent welder can fix it.
    Latitude: 5736' Highlands, Scotland
    Sub standard finish on the fillet?
    On second look it appears welded...oops
    Reputation: mijstrat72's Avatar
    It's worth a second look for sure, but these Pugs are made out of some of the hardest chromoly I've ever come across. I highly doubt that is a frame crack, but more so a production error.
    Oct 2010
    Looked inside the bb shell. It looks ok. I'm just gonna keep riding.
    CRAMBA Chairman
  1. Replies: 45
    Last Post: 01-26-2012, 09:17 AM
  2. Frame crack or paint crack?
    By Rad Rider 415 in forum Niner Bikes
    Last Post: 05-06-2011, 07:20 AM
  3. Replies: 7
    Last Post: 05-26-2010, 02:17 PM
  4. a different EX 8 frame crack
    By Beemer2 in forum Trek
    Last Post: 09-01-2009, 06:54 PM
  5. Frame crack on a NRS?
    By btadlock in forum Giant
    Last Post: 11-08-2007, 11:43 AM
