Which Fork?- Mtbr.com
Results 1 to 5 of 5
Thread: Which Fork?
    Sep 2016
    Which Fork?
    I'll be upgrading my wheels and part of that will include a new fork, since my current fork is 135mm QR. Most wheelsets seem to be 150/15 T/A so I've been looking at forks to match. Any opinions on the forks listed below or suggest any others? I'm not sure I trust the ebay chinese carbon ones.
    Carver
    RSD
    Framed
    BD?
    Sarma Hoboy
    2018 Trek Stache 7
    2017 Fuji Wendigo 2.3
    Reputation: dbhammercycle's Avatar
    What is the current axle-crown height of your current fork? How much do you want to spend? Are you only interested in carbon?
    I have a alu Framed fork hanging on the wall from an Alaskan. I ride with a chinese carbon fork in the snow and no issues but the axle is less than stellar. The axle is basically a qr housed in 15mm tube which bears the weight while the qr snugs it tight. The Framed is a screw-in axle.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Reputation: BlueCheesehead's Avatar
    Many fat bikes sold are simply Chinese frames that companies source and put their name on. The Framed and Fyxation carbon frames of a couple years ago appeared the exact same frame & fork as a Chinese carbon. As such, I would not rule out a Chinese fork. I would do enough research on them to make sure it has a proper through axle.
    Sep 2016
    I'll have to measure the current fork I have on there, specs aren't listed online. Guess I wasn't aware most of them are Chinese forks.
    I'm not necessarily dead set on carbon, if an aluminum one would fit my needs. As far as budget, I guess $300 would be about the highest I'd prefer to go.
    2018 Trek Stache 7
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Sarma Hoboy had great fork a little flex. RSD had one great fork stiff as fu*K.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
  1. Increasing fork travel, which fork offset?
    By Syncro in forum Shocks and Suspension
    Last Post: 09-11-2014, 02:02 PM
  2. Karate Monkey Fork vs Unit fork: which is softer?
    By El Train in forum Singlespeed
    Last Post: 01-06-2014, 04:31 PM
  3. 09 Specialized Pitch Fork Upgrade? Which Fork??
    By yellowpasta2000 in forum All Mountain
    Last Post: 05-17-2011, 01:51 PM
  4. Manitou: Which fork for which bike?
    By gthcarolina in forum Shocks and Suspension
    Last Post: 06-22-2006, 03:17 PM
  5. New Build: Which Disc Brake & Which Fork?
    By ncj01 in forum 29er Bikes
    Last Post: 03-15-2005, 06:18 PM
Members who have read this thread: 62
