First ride on DIY studded tires- Mtbr.com
Results 1 to 3 of 3
    Reputation: Steve Balogh's Avatar
    Over a year ago I studded the original pair of Endomorphs that came with my Wildfire, using Ward's method with the sheet metal screws. Sadly, that winter it was warm and I never saw any ice. This weekend SE Michigan trails are pretty icy, so I put on the spare wheelset with the studded tires and rode a nearby trail. There was a light amount of snow last night, so most of the ice was covered just enough that I know would raise a typical studded tire off the ice enough to make them slip. Not so with these. I had solid traction going up and down a small hill that was glare ice. Best studded tires I've ever used. Thanks Ward!
    Note the front wheel is a 47MM trials rim. The front worked fine despite the extra curvature from the smaller rim.
    Dinner for wolves
    Reputation: buddhak's Avatar
    Very neat. can you hotlink to the thread that inspired you to do this? You know, for the uber lazy DIYers like myself.
    Responds to gravity
    Quote Originally Posted by buddhak View Post
    I'm unable to find Ward's post, other than this one:
    http://forums.mtbr.com/fat-bikes/stu...es-731164.html
    Drill the holes, install the #6's x 3/8" screws, and put small strips of duct tape over them
