Fender with Fatback Carbon Fork?- Mtbr.com
Results 1 to 17 of 17
    aka bOb
    Reputation: bdundee's Avatar
    Anyone using built or purchased a fender to use on a Fatback carbon fork? Or any ideas would be greatly appreciated.
    Thanks.....Bob
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Had an epiphany tonight, no idea if it's an old idea or not, but certainly tires aren't a new repurpose idea.
    Yep, it's an Endomorph. Since I just cut off the bead, it's actually wider them a BFL on an Uma 90. 3 minutes with a pair of scissors, a pair of dikes to snip the holes, 3 zip ties and you're good. I plan on playing around with a rear version in the next day or two.
    And we had a really wet ride tonight, my whole front end from the waist up is clean and dry.
    Attached Thumbnails Attached Thumbnails Fender with Fatback Carbon Fork?-fat-fender.jpg
    Cannondale Lefty and HeadShock servicing, wheel building, etc...
    www.mendoncyclesmith.com
    aka bOb
    Quote Originally Posted by MendonCycleSmith View Post
    I like it!! I wonder if a person could use big o-rings somehow to hold it on?
    I used the clips left over from lights, speedometers, reflectors etc. to mount racks to my ti fork. You could probably figure out a way to make them work for a fender, for sure for the strut mounts.
    Latitude 61
    Reputation: GTR2ebike's Avatar
    May 2010
    Quote Originally Posted by bdundee View Post
    How would you get a o-ring around the frame
    aka bOb
    Quote Originally Posted by GTR2ebike View Post
    Folded in half like my niterider lights mount to my handle bars. Just need something to hook both ends as it comes around the tube.
    aka bOb
    Like this but a bigger o-ring. Oh yeah and I really like the idea with the clamps.
    Attached Thumbnails Attached Thumbnails Fender with Fatback Carbon Fork?-oring.jpg
    May 2010
    Gotcha, I was thinking about what you were saying as i was looking at the wire ties in Mendon's picture, made my mind turned 1 dimensional.
    Feb 2005
    Glad someone liked it! As for O rings, sure, they could work. I've done this before, take a small nut or washer, pinch the O ring and put a small bit of it through the hole. Slip the rest of the O ring through that little loop. You now have an O ring that you can run the majority through the holes in the tire, and around the down tube. Then, stretched tightly, the nut will slip in, and keep it all in place. Like those bungie cord loops with a ball on them, same concept, just home made.
    Feb 2005
    Kinda stoked. Apparently, Surly liked my idea!
    Blog | Surly Bikes
    Blog | Surly Bikes
    And then there is this little gem:
    I expect you'll see more about fenders soon, but don't quote me on that.
    Well, I quoted it.
    aka bOb
    Blog | Surly Bikes
    Pretty cool! I just wish I had a tire to sacrifice.
    Reputation: Velobike's Avatar
    And if you notice a large oval cut out of your rear tyre, you'll realise someone else had the same problem.
    For making mounts for the fender try this stuff - Sugru
    Any bike, anywhere, anytime.
    Latitude: 5736' Highlands, Scotland
    Rednose/Greenback
    Reputation: apbtlvr's Avatar
    @ bdundee Is your carbon fork capped on the bottom? I'd be curious to know as the steel (non tapered) fork is not. If a front fender were to be installed, some type of plug with a hole for mounting fender hardware would need to be fashioned. Don't know if this applies in your case however.
    The only fender related item on my bike so far is a crud catcher picked up through ebay. It's worked out pretty good for a first time user experience. It uses a pair of 100mm O rings.
    Attached Thumbnails Attached Thumbnails Fender with Fatback Carbon Fork?-fb-fork-opening-1.jpg
    38 54' -77 15
    Quote Originally Posted by apbtlvr View Post
    @ bdundee Is your carbon fork capped on the bottom? I'd be curious to know as the steel (non tapered) fork is not....
    I pop a star-fangled nut in there for that job.
    Rednose/Greenback
    Quote Originally Posted by Velobike View Post
    Thanks Velo, gonna do just that.
    38 54' -77 15
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    It's solid carbon under there! No star nut love for us fatback carbon users anyways!
  1. Fatback Carbon Fork
    By rio in forum Fat bikes
    Last Post: 01-01-2013, 12:22 PM
  2. Anyone broken a Fatback Carbon Fork yet?
    By Drew Diller in forum Fat bikes
    Last Post: 06-12-2011, 06:10 AM
  3. Fatback carbon fork!
    By thirstywork in forum Fat bikes
    Last Post: 02-28-2011, 08:50 PM
  4. Fender for Niner Carbon fork...
    By GRFSR in forum Niner Bikes
    Last Post: 04-04-2010, 07:51 PM
  5. Full front fender on carbon fork? How?
    By Fastskiguy in forum 29er Bikes
    Last Post: 02-06-2008, 08:17 PM
