Fatty for a Clydesdale fatty?- Mtbr.com
Results 1 to 22 of 22
    Reputation: schnee's Avatar
    I'm about 6'-2", and built like a linebacker. If I were fit, I'd be 240. But I'm not. I'm about 275. I tend to overbuild stuff, or buy 'next rung up' spec in mountain bikes - like using a Niner RIP9 for XC, or 40c tires on my road bike.
    I am strong - my nickname on MTB is 'the chain breaker', I've cracked frames, ripped BMX cranks apart on a fixed gear, and I literally ripped a Hope cassette body off of the hub shell - and ended up bending the through axle - by cranking up a hill in a low gear. I've started to figure out I need certain brands - like Wipperman and King.
    I'll bikepack and try to keep it light, but I'll be pushing 310-320 pounds on the bike fully loaded.
    So. As tempted as I am by current offerings, I'm set on two things:
    - front and rear through axles
    - 100mm rims with 5" tires
    I just can't see trusting QR wheels. I also think due to my size I need to get the biggest tires just to have the same float a typical rider will have on 65mm/4" wheels.
    That leaves me with few options, from what I can tell:
    - 9:zero:7
    - Salsa Blackborow
    - Surly ICT
    Are there others I should look into?
    Anyone think I shouldn't worry about through axles and have other ideas?
    Reputation: tundratrader's Avatar
    I think you will be fine with just about any of the current offerings. I am huge and have had no problems with my mukluk 3. I just had mine fully loaded with me and gear with zero issue. I do want to thru axle the rear though. I think my rear hub bearings are about to go out. You can't go wrong with any that you listed. I would go ride some bikes and see what you like.
    Attached Thumbnails Attached Thumbnails Fatty for a Clydesdale fatty?-image.jpg
    turtles make me hot
    Reputation: NYrr496's Avatar
    I'm 6'5", 250 pounds and I've been riding a 907 with Clownshoes and Bud and Lou.
    Mine is a 2014, so it has QR front and rear. I've had zero problems with it.
    I'm going to trade up to a 2015 for polished frame, 150mm fork and thru axles. I don't feel I need em, I just want to have all my stuff compatible and I don't want all sorts of extra wheels for a Bluto.
    I've broken cranks and hubs and stuff as well but my fatbike's been hangin' tough.
    I like turtles
    230 lbs on a charge cooker maxi with a lefty suspension fork. Rides great and I absolutely love it.
    aka bOb
    Reputation: bdundee's Avatar
    Fixed it for ya ZB
    Perfect. I don't know why it is sideways. Upside down works. Using tapatalk vs web now. Through a different pic up but old one won't delete maybe because you quoted it or something.
    Reputation: maddslacker's Avatar
    Also check out the Fatback alloy with 190mm rear.
    Sweet. Thanks for the replies.
    Oh, I forgot: I live in Sweden. Fatbikes are basically non-existent here. There's one Surly dealer, one Genesis dealer, and that's...it. (There's also a Specialized dealer, but I'm a pedantic high-horse goody-good who can't forgive them for being so sue-happy.)
    If I go to the rest of the EU, my options open up slightly - Sandman bikes in Belgium, Singular, etc. - but for most other bikes I have to pay about 30% in duty and VAT to bring them in to the country.
    In other words, whatever I get, I hope I like it, because I'm going to have to cross my fingers and buy without ever riding it. A Pugsley Ops is close to $3k here, so no matter what it's gonna hurt.
    If you are in Europe I would get one of the fatbikes with a pinion drivetrain. Not many are setup to do it here.
    The Dog.
    Reputation: Dogdude222's Avatar
    Aug 2005
    Quote Originally Posted by tundratrader View Post
    if you are in europe i would get one of the fatbikes with a pinion drivetrain. Not many are setup to do it here.
    ^agreed.
    Reputation: Gus69's Avatar
    Nov 2012
    Cool another scandinavian, I'm danish.
    I bought the Pugsley from Cyclecomponents and upgraded it.
    Chris king Heavy duty rear hub with thru axle + funbolts, and 1 x 10 speed.
    The biggest trouble will be to find a 170 or 190 mm hub that you wont kill, that's why I'm riding 135mm.
    aka bOb
    Quote Originally Posted by Gus69 View Post
    I'm danish.
    And I was just wondering what I was going to have fro breakfast, sold!!
    Quote Originally Posted by bdundee View Post
    Your going to eat the Danish guy? Ish..
    Nov 2012
    275 lbs Danish dude, you will struggle. But if you ever come to Denmark
    I'll buy you a danish
    aka bOb
    Thanks for the offer
    <object width="560" height="315"><param name="movie" value="//www.youtube.com/v/YoY_Fahp_Qc?hl=en_US&amp;version=3"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/YoY_Fahp_Qc?hl=en_US&amp;version=3" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
    Aug 2014
    ^^^^ Freakin' TEARS ^^^^
    Jul 2014
    I'm 300lb+ and run an On One Fatty. I had no problem with qr front and rear although I have a suspension fork now with through axle. I have found it to be very strong and have only broken the chain and freehub but these I changed and have had no problem since. I would by an Fatty frame (150) and build with choice components then upgrade the frame later if you feel the need. Although I am really happy with the frame, it's the only part left of the original bike lol
    bigger than you.
    Reputation: Gigantic's Avatar
    Quote Originally Posted by schnee View Post
    i'd look into improving your technique. That's an awful lot of breakage, even for your size.
    Reputation: efuss's Avatar
    Dec 2011
    ICT. Upgrade as budget allows.
    Dec 2011
    Check out the Surly crew on their website and blog posts. Methinks big dudes are who originally designed these things. (I'm a full on fatty devotee at 150 pounds).
    Quote Originally Posted by Gigantic View Post
    Ehh, I have two answers.
    - That was over the course of six years. Stuff breaks in MTB.
    - You're just jealous of my astounding torque.
    I'm gonna take you up on that. I had a Finn online friend dare me to come over to hang out in Finland for the day and I ended up getting an awesome tour of Turku. Just you wait!
  1. On One Fatty BB Help
    By redchoppa in forum Fat bikes
    Last Post: 07-09-2014, 02:24 AM
  2. On One Fatty and Baby Fatty, complete or kit
    By eugenemtbing in forum Where are the Best Deals?
    Last Post: 02-14-2014, 10:39 AM
  3. On One Fatty
    By craigstr in forum Titus
    Last Post: 10-27-2012, 07:51 AM
  4. You're the one for me Fatty
    By brant in forum Fat bikes
    Last Post: 05-05-2012, 11:36 AM
  5. I'm such a fat fatty-a**-fatty-fat-butt
    By pippinr in forum Clydesdales/Tall Riders
    Last Post: 04-13-2011, 09:03 PM
