Fatboy SE 1x Low Q Factor Crank- Mtbr.com
Results 1 to 9 of 9
    Sep 2015
    Hi. What are my options for upgrading my fatboy SE crank and bottom bracket if needed to get a lower q factor and go 1x. I searched and couldn't find much. Thanks..
    Sent from my XT1563 using Tapatalk
    The lowest qf-cranks are from race face. Running a 1x could also meen that you can go for a 170 spesific crank. On my Borealis I run next cinch cranks with the chainring put on with the raceface logo turned in. Than you have clearance for 100mm rim and bud/Lou and decent chainline. The thing I don't know, is if the 170 will clear the CS on the Specialized.
    Sent fra min D6603 via Tapatalk
    Dec 2014
    This should help. You have a 100mm bottom bracket.
    Race Face
    Jul 2014
    I recently installed the Race Face Aeffect cinch spaced for a 170mm rear hub on my 190mm spaced lurch. Went with RF NW 28T "flipped" to keep a good chain line. Fit with plenty of room. Q factor went from 228mm to 205mm. Couldn't be happier with how it went!
    http://www.raceface.com/comp/inst/Cr...chainlines.pdf
    This link above was helpful to find the crankset to use the same BB.
    Sep 2015
    It looks like I wont need a new BB just the crank which is good news. The higher end Fatboys come with this Crank so it should definitely work. Thanks.
    Distributor
    Reputation: carbonLORD's Avatar
    I swapped down to a 170 RF Next SL on both my FatBoy alloy and carbon frames. You can run a 32 tooth ring on there with plenty of clearance too.
    carbonLORD /// KILOMETER
    Sep 2015
    Quote Originally Posted by carbonLORD View Post
    What BB did you go with?
    Reputation: cardnation's Avatar
    Jul 2014
    Quote Originally Posted by mix123 View Post
    Seconded.
    I bike with tires.
    Distributor
    RaceFace.
  1. HD3 Crank Q factor
    By DeeZee in forum Ibis
    Last Post: 12-17-2015, 07:24 AM
  2. Need a wider (Q factor?) crank set
    By Stevebiker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-01-2013, 12:02 PM
  3. Which q factor XX1 crank?
    By limba in forum SRAM
    Last Post: 12-30-2012, 03:47 PM
  4. E.13 crank Q factor
    By PoorCyclist in forum Singlespeed
    Last Post: 08-15-2011, 12:27 AM
  5. How do I reduce the Q factor on XT crank
    By Rod in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-06-2011, 05:35 AM
