Page 2 of 2 FirstFirst 12
Results 101 to 119 of 119
  1. #101
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by shoots View Post
    I've always just sanded my brakes when they squeal and it solves it.
    Until very early in the next ride. Maybe.
  2. #102
    Reputation: BlueCheesehead's Avatar
    This seemed to help:
    1.) remove pads and clean back of pads, inside of calipers and pad separator spring
    2.) coat back of pad plate, the little tab on the front side of the pad that screw or cotter pin goes through and the separator spring with a light coat of Sil-Glyde brake lubricant.
    I think lightly lubing the separator spring is key as that thin piece of metal makes for a nice reed.
    So far so good
  3. #103
    Reputation: chode's Avatar
    I’m doing this soon. They scream on descents and it’s like nails on a chalk board.
  4. #104
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    https://forums.mtbr.com/specialized/...-779649-2.html
    This is one of the best threads (I mentioned above) because it shows real understanding of the issue and fixes that address the underlying issue. Not sure if it would affect a bit of water-burn-off though that most bikes seem to encounter, on the other hand I've ridden with peeps that had howling brakes no matter the conditions.
  5. #105
    Tried Sli-glyde on both the back of each pad where the piston contacts the pad on front and rear SLX brakes. The howl went a way a bit quicker but they still howled.
    urmb
    “Nothing compares to the simple pleasure of riding a \mountain or fat/ bike.” ~ John F. Kennedy
  6. #106
    Thin Man on a Fat bike
    Reputation: SAM313's Avatar
    Quote Originally Posted by urmb View Post
    urmb
    You have to do the edges to, just make sure not to get any on the pad itself. 10 miles in the snow Saturday, no noise at all. I just redo them once a year.
  7. #107
    urmb
    Did you Sil-Glyde the spring too? If not, try that. (sparingly to not get it on the pad itself)
  8. #108
    Quote Originally Posted by BlueCheesehead View Post
    So far so good
    Thanks for the detail. Will put on more liberally.
  9. #109
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    Switch the pads, front to back or spin them around, inside to outside. The rotor will pattern the pad and draw the material out. Changing the orientation freshens up the biting surfaces, hushes the squeal with grip.
    Todd
  10. #110
    Music & Bikes
    Reputation: fokof's Avatar
    Good thinking , I'll try that.
    "There is a big difference between kneeling down and bending over" -FZ
  11. #111
    Reputation: mtbeagle's Avatar
    Jan 2009
    Maybe the noise is a good thing? I was just going through some of my videos and when I was watching this one https://youtu.be/cSecxgL5Qdg, it reminded me of this thread.
  12. #112
    Reputation: iliketexmex's Avatar
    Oct 2016
    Quote Originally Posted by ultraspontane View Post
    Embrace it. I love hearing that shriek echoing through the hills in the dead silent winter.
    Scares the coyotes away
  13. #113
    I get this squeal all the time. always when wet. sucks when I am hunting off of my bike.
  14. #114
    Inconsistent results from users in this thread could easily be due to different temps/humidity conditions.
    Cleaning the pads and rotors with IPA and a paper towel always eliminates the squeal for me. I also lube the pin and back of pad lightly with silicone grease. It is nice to check your brake pads anyway from time to time. The squeal seems to come back eventually when the temp/humidity/salt/glaze buildup are just right again. You can use brake cleaner or even starting fluid if you prefer instead of IPA.
  15. #115
    Enough IPA cures most problems for me
    Latitude 61
  16. #116
    Mine is back with a vengeance. Frustrating.
  17. #117
    Nov 2018
    Just wanted to come in and add that I still think the issue is a glazing issue caused from moisture with some pads. Sanding the pads and rotors will solve the problem.
    Also worth adding I've been running the nukeproof resin pads with new centerline rotors and they have been dead silent.
  18. #118
    sunday, everything was pinched up tight. no water on the rotors and no brake noise. it is a wetness issue.
  19. #119
    Quote Originally Posted by tim208 View Post
    That may be your issue. Mine seems more related to cold.
  1. So Cal fatbike snow ride vid
    By DirtDad in forum Fat bikes
    Last Post: 12-17-2014, 12:09 PM
  2. SNOW - 29 tubeless vs fatbike
    By srs0909 in forum 29er Bikes
    Last Post: 10-21-2014, 08:53 AM
  3. Snow + FATBike + beer?
    By OldschoolReloaded in forum Fat bikes
    Last Post: 12-05-2013, 05:36 PM
  4. I think there may be something to this Fatbike thing!
    By skiahh in forum Riding Passion and Stories
    Last Post: 10-16-2013, 07:32 AM
  5. 2012 XX Brake Rotor - The thing for the mud!
    By TigWorld in forum Brake Time
    Last Post: 09-12-2011, 08:16 PM
Members who have read this thread: 241
