Fat tire width to rim width to hub width ratios, riding on beach- Mtbr.com
    Aug 2014
    Are there rules of thumb for the ratio between tire width, rim width, and hub width?
    Ive had good success with my 4 fat tires on 100mm rims at 15 PSI on hard sand and down to 4 PSI in the soft stuff.
    Might be building up a new bike and was just wondering about how the designers come up with tire / rim / hub sizes.
    Aug 2016
    The rims from 65 mm to 105 mm width are suitabe for the tires of 4,0" to 4,8' sizes... that's it.
    Reputation: BlueCheesehead's Avatar
    Quote Originally Posted by Comrade Sukhov View Post
    While that may work, 4" on 65-80mm and 4.8" on 80-105mm is probably a better all around guide.
    As far as hubs go, I see no reason not to go 150mm in front. Rear is up to you depending on if you want to run anything larger than a 4.5" tire. Greater than 4.5", go with a 197mm rear spaced frame and hub.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    If you're debating what rim width to use for a particular tire, do note, that the wider rims make less of a difference in inflated tread width that you might have been led to believe. With a second gen Vee Snowshoe (the ones labeled 4.5), the edge to edge width was only 4mm more on an 80mm rim than it was on a 57mm rim.
    I don't post to generate business for myself or make like I'm better than sliced bread
  1. Replies: 30
    Last Post: 04-03-2017, 10:30 AM
  2. Non-linear ratios: rim vs. tire widths
    By ro7939 in forum Wheels and Tires
    Last Post: 04-22-2016, 09:10 AM
  3. Replies: 17
    Last Post: 08-17-2013, 10:58 PM
  4. Tire height to width ratios
    By Proformance Cycle in forum 27.5
    Last Post: 05-26-2007, 01:26 PM
  5. fat fat fatty fat fat fat
    By evilbeaver in forum Riding Passion
    Last Post: 12-10-2006, 01:23 PM
