fat tire tubeless- Mtbr.com
Results 1 to 6 of 6
    vermonter
    Reputation: reynoldseight5three's Avatar
    fat tire tubeless
    http://https://www.reddit.com/r/fatb...e_tire/e7azfkb
    For FAT TIRES I use Soap on the bead, the valve core out, and a compressor with regulator @150psi. (Overnight with a tube in the tire helps form it and the rim strip.) I wrap a ratchet strap around the middle of the tire to push the bead onto the rim. Blast the air, release the strap, the bead snaps in around 20psi, release air to put in 4oz. of sealant in each tire, replace the valve core and inflate to 20psi again and spin em. Use more soap to identify leaky spots. An immediate ride once holding air is also essential to a good sealing. Iím a mechanic and have been setting up tubeless for 15 years and fat tires for about 5 and this works every time
    for stubborn tires or winter riding i recommend the "ghetto" method.
    split a 24"x2.4" ,presta (w/removable core) valve, down the non-valve side. seat the valve in rim hole (with rim tape of course) letting cut edges drape over the rim edge. follow above directions for the easiest tubeless fat ever.
    Brattleboro/Keene NEMBA officer and trail hero! :thumbsup::)
    fat guy on a little bike
    Reputation: BlueCheesehead's Avatar
    Who knew?
    hmmm
    Quote Originally Posted by BlueCheesehead View Post
    Who knew?
    Kinda...almost...everyone.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Or you could get some Surly My Other Brother Darryls and cut the whole operation down to a couple of minutes.
    I like turtles
    Reputation: Swerny's Avatar
    what is this "tubeless" sorcery that you speak of?
    Mike
    Toronto, Canada
    2019 Scott Foil 10 Disc
    2019 Giant Revolt Advanced 0
    2017 Trek Farley 9.6
  1. Replies: 4
    Last Post: 05-30-2015, 10:03 PM
  2. Best am tire to run tubeless, also tubes Vs. Tubeless
    By FRidekid in forum Wheels and Tires
    Last Post: 01-25-2011, 04:07 PM
  3. Fat Skinny Fat Skinny Fat
    By Bob the Wheelbuilder in forum Surly
    Last Post: 07-13-2007, 11:34 PM
  4. fat fat fatty fat fat fat
    By evilbeaver in forum Riding Passion
    Last Post: 12-10-2006, 01:23 PM
  5. Fat rider, fat arse, fat saddle
    By GrumpySmurf in forum Beginner's Corner
    Last Post: 02-17-2006, 08:00 PM
