Fat tire with puncture: apply boot or just chuck out?- Mtbr.com
Results 1 to 7 of 7
    Sep 2017
    Recently had a bad puncture on my Pugsley, which I ride year 'round for commuting and trails, mostly. Decent sized piece of what looked like a thin, sharp steel wire was the culprit. Couldn't get the wire out of the tire itself - no pliers in my repair kit - so got the bike home on my car's trunk rack, eventually. To expedite matters., I swapped in a new tube in another tire - a Knard I had sitting around.
    No big deal patching the tube in the usual way. The damaged tire is a 3.8" Nate in fairly good shape, in terms of wear. But I'm wondering if I should stick a boot on it and keep using it, or whether a boot is "really" only a temporary measure, meant to get you home in an emergency. Is there a better way to "permanently" repair a fatbike tire? I don't want to convert to tubeless, as the rims are standard Large Marges, not really well-suited to tubeless.
    Reputation: BlueCheesehead's Avatar
    You can patch the inside of the tire the way you would patch a tube. I actually do the "hot patch" method
    It works, even for tubeless.
    Sep 2017
    Interesting! Thank you.
    Reputation: Swerny's Avatar
    what about a car tire patch on the inside of the tire to fix the hole?
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    Quote Originally Posted by Swerny View Post
    That is essentially what the hot patch is. I went kind of extreme and got what should be a life time supply of patches from Amazon or eBay, a bulk bottle of vulcanizing rubber cement, bead sealer and even some prep-solvent. I have found it to work on even high pressure tubeless road bike tires. Total cost for the materials is less than one new tire.
    If you like running tubes and would like to in the future there is nothing needing to be done to the tire other than checking to see that the wire and any other sharp bits are removed. Toss in a new tube and go. The pin hole makes no difference.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Way cheaper to repair than replace, and there's no good reason here to just replace.
  1. Replies: 3
    Last Post: 02-25-2014, 08:26 PM
  2. Replies: 24
    Last Post: 05-19-2013, 05:10 PM
  3. fat fat fatty fat fat fat
    By evilbeaver in forum Riding Passion
    Last Post: 12-10-2006, 01:23 PM
  4. chuck, the full chuck, and nuthin but the chuck.
    By cactuscorn in forum Turner
    Last Post: 12-19-2005, 10:26 PM
  5. To boot or not to boot?
    By Phat Tire in forum Shocks and Suspension
    Last Post: 08-08-2004, 04:42 PM
Members who have read this thread: 80
