Fat rim options- Mtbr.com
Results 1 to 9 of 9
Thread: Fat rim options
    hellraiser
    Reputation: coach#1's Avatar
    Mar 2006
    Fat rim options
    Hey there,
    I'm looking at getting a Maverick SC32 fork for my pugsley and I'm curious as to what other rim options are out there. I currently have offset large marges and they're fine, I just thought that if I'm building a new wheel why not see what else there is for rims (maybe something a bit wider 70-80mm?).
    I plan to use my bike in the summer with the Maverick fork for some trail riding (plan to put Gaz 3.0s on for summer - sidenote: I only have one right now so if anyone has an extra shoot me a line...).
    So the question is: Are some of the other rim offerings (vicious graceful fat sheba, speedway 70mm or 80mm, ...?) burly enough for trail riding? Or are they meant more for snow touring/racing type of deal? Should I just go with a DH Large Marge to be safe?
    Cheers,
    Coach
    eh?
    Reputation: FredBMOC's Avatar
    As far as I know 70mm is as wide as you can go on the Mav.
    Good luck.
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Running an 80 mm from Choppers US on my SC32, no issues. The 100 doesn't work. It does fit, but so barely, that it's not worth bothering with.
    http://www.choppersus.com/store/prod...-26-x-3-Black/
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Good to know
    Quote Originally Posted by MendonCycleSmith
    Reputation: davesauvageau's Avatar
    Are these single wall?
    My motorcycle runs on infant blood
    Feb 2005
    Quote Originally Posted by davesauvageau
    Nope, double wall. Speedway gets their rims from this guy.....
    - FrostyStruthers
    hellraiser
    Mar 2006
    Sweet, that's what I might try. Only snag is the chopper rims come in a 36 hole drill pattern and the Maverick hub is 32 hole. Are you using a King or Hope hub? I've heard there are issues with using a non-Maverick hub on a Maverick fork.
    Cheers,
    Coach
    eh?
    Feb 2005
    Quote Originally Posted by coach#1
    King. No issues, but I also don't ride this bike like I ride others. KNock on wood, fine so far.....
    Seems odd no? A Maverick sepcific hub, causing problems with the fork it's built for....
    - FrostyStruthers
    superluker
