Fat front- Mtbr.com
Results 1 to 27 of 27
Thread: Fat front
    Fat front
    what forks are available, 100mm hub, 45mm snow cat rim, surly Nate. fat fronting a Trek Sawyer, looking at the surly 100mm fork but wondering about options. thanks (I have a Pugsley, just really liked frame design of Sawyer)
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    Salsa Enabler 135
    Surly Fat fork 135 symetrical
    White Bros carbon
    907 alu fork
    fatback cromo
    Any custom fork you can source from a local builder.
    Just a regular guy.
    Reputation: bikeny's Avatar
    Quote Originally Posted by ~martini~ View Post
    Salsa Enabler 135
    White Bros carbon
    907 alu fork
    fatback cromo
    He's asking for a 100mm hub fork, not 135. I think the safest choice is the Surly. Some of the rigid 29er forks might work, depending on how wide the tire ends up on that rim. I think the Bontrager Switchblade 29er might be the widest.
    Witty McWitterson
    my bad. Last one still stands though. Custom. Everyone ALWAYS forgets about custom.
    Just a regular guy.
    I just got this Sawyer as a warranty frame. Swapped over my fat front, etc... Rides awesome. Took it on a 20-miler today with lots of roots and climbing. I'm very happy width its performance.
    Is that salsa fork?
    Reputation: bighit's Avatar
    I thought about that myself. Can we get a Side profile pic please. I am so used to seeing the Jones Fat Front bike I am brain washed as to what one should look like.
    Thanks.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    Yes, that's a Salsa Enabler. The geometry feels right on. I'll upload a side profile pic later.
    Quote Originally Posted by bighit View Post
    Thanks.
    This is as close to a profile shot as I have.
    Nice. I am going to wait it out with a fat front on a frame I want. One foot on each side of the fence.
    2012 Moonlander.
    Reputation: Johnclimber's Avatar
    What about a custom Jones truss fork?
    090627 Meaty Beefy Big and Bouncy by Johnclimber
    Cool setup
    Reputation: firefighterdirt's Avatar
    This is my son's Half fat Niner EMD.
    https://www.facebook.com/photo.php?f...type=3&theater
    Heres mine
    Reputation: couby's Avatar
    does anyone have a photo of a half fat bike using a bontrager switchblade? I remember seeing one a few years ago but cant find it.
    any help would be great,
    cheers
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Lefty.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    I have pics because I did it. It rubbed a tad. I will try to dig em up.
    2012 Moonlander.
    should have said that its a 100mm pugsley fork.
    Cool would be good to see the pics,
    Cheers.
    May 2010
    I highly recommend looking into a Waltworks fork. Reasonably priced, quick turn-around, and built to your specifications.
    <a href="https://www.flickr.com/photos/[email protected]/5835215950/" title="Theo Wirth by Fat Tire MN, on Flickr"><img src="https://farm4.staticflickr.com/3558/5835215950_c795206059.jpg" width="500" height="375" alt="Theo Wirth"></a>
    Quote Originally Posted by couby View Post
    cheers
    I am pretty sure the tange switchblade crown is same as the crown used on early rockshox mag21. I looked at using a mag21 as basis for a fatbike fork and concluded that the legs were just spaced too close together. I used a early manitou fork instead, 92mm of space between the stanchion tubes, just clears a 3.8 larry on a 44mm snowcat.
    http://forums.mtbr.com/fat-bikes/fatbike-front-suspension-718335.html
    You might also consider using a pre-Y2K marzocchi fork (like early wildfire fat bikes used) or an early RS judy fork with pinchbolt crown if you wanted to change out and add rigid legs in place of suspension. Still a bit of fabrication invloved for adding dropouts and brake mounts but much easier project than fabricating an entire fork from scratch. The pinch bolt Marchocchi forks have 100mm of space between the fork legs and while I have not measured a Judy, I think they are similar spacing; certainly more that the Mag21 crowns.
    Sc32
    Don't forget the venerable Maverick SC32. Might have to do some shaving of the lugs, but you'll have some extra cush
    Nov 2008
    I ran fat front with a Switchblade for two winters. Worked good with a downhill rim.
    <a href="https://www.flickr.com/photos/droit/6639042781/" title="Fat_Front by bdroit, on Flickr"><img src="https://farm8.staticflickr.com/7002/6639042781_65b7b00577_z.jpg" width="640" height="423" alt="Fat_Front"></a>
    cheers
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    Reputation: MudInMyEars's Avatar
    Apr 2005
    Quote Originally Posted by FTMN View Post
    Nice photo. I have a Waltworks fork on the way, it's in powdercoating and then on to my 1st gen Fargo. I can't wait!
    -mud
    _____________________________________________
    Fat, drunk and stupid is no way to go through life, son.
    Jun 2010
    Will a Surly Nate on a Surly Clown Shoe fit into the Enabler? (on a Karate Monkey)
    Jun 2010
    I've been trying to find photos of this...ah, thanks. I think that helps.
  1. Half an Inch Front Wheel Movement when front brake is applied
    By Jacques Pienaar in forum Brake Time
    Last Post: 11-16-2009, 07:21 PM
  2. Replies: 13
    Last Post: 12-29-2008, 11:11 AM
  3. e-type front derailleur, downshifting issue, do they work w/ triple ring up front?
    By mmatador22 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-08-2008, 07:57 AM
  4. Parts help: chain link, front gears, front derailuer, more
    By serval in forum General Discussion
    Last Post: 12-17-2005, 01:16 AM
  5. Parts help: chain link, front gears, front derailuer, more
    By serval in forum Bike and Frame discussion
    Last Post: 12-13-2005, 07:14 PM
