Fat Fork Options on Normal Frame??- Mtbr.com
Results 1 to 14 of 14
    I am in the midst of creating a 'semi - fat ' bike for use at Arrowhead... due to sponsorship i have to use a standard frame and rebranding a pugsley is not acceptable..
    I want to get hold of a fat fork to allow at least a full fat front end and then i can at least bias my weight towards the front that will have the most flotation.
    The bike will be singlespeed and ideally i would want front and rear wheels to be interchangeable..
    Frame is a Genesis IO
    What are my options???
    thanks
    shoestring-racing.blogspot.com
    Derailleur? No thanks.
    Front and rear interchangability, but not with tires, correct? Well, any non-offset 135mm fork will do. Salsa Enabler would be a good choice, but the A-to-C would be a bit much for a 26er. Personally, I'd have a frame that could run a 29" in back for a little more float.
    Thanks..
    Yeah tyres would need to be swapped if wheels were.. its just a 'get out of jail free' option that i want to be able to swap wheels.
    Thought Salsa fork was not available yet??? What other non offset forks are there??
    29er would be great but my sponsor don't produce one
    How about you just get the Surly non-offset fork and as an easier drivetrain backup, get a Tomicog for the rear. Then if your freewheel/freehub dies you can flip the wheel, remove the rotor, bolt on the Tomicog and go. Probably easier than trying to swap tires in the cold.
    Thanks Schmucker
    Good idea on the fixed cog.. think i will carry one with me.. hoping this bike will be used for all kinds of adventures so gonna try and do the 135mm front and back if i can..
    Saw a post about sandmanbikes and his forks seem very reasonably priced and 135mm spaced..
    Reputation: PanFry's Avatar
    Nov 2007
    So a Pugsley Fork will or will not work with say a Karate Monkey?
    PF
    EXCUSES ARE THE NAILS IN THE COFFIN OF FAILURE.
    Spooooon!
    Reputation: Hairllama's Avatar
    Sounds like you're bringing a knife to a gun fight.
    Nov 2007
    Quote Originally Posted by Hairllama
    wtf?
    Spooooon!
    Quote Originally Posted by PanFry
    wtf?
    It's a metaphor. It sounds to me like the op's sponsor doesn't make the right equipment for the event. Hopefully the sponsor is not pusing him to race in these types of conditions with the wrong gear.
    I know what yoyu mean.. no pressure from my sponsor.. more pressure from me for them to let me do this.. if you've seen my blog you'll know i always 'bring a knife to a gunfight' but enjoy the extra challenge.
    I'm under no illusion to how hard this race is gonna be.. thats why i'm going.
    Spooooon!
    Quote Originally Posted by paul78
    I don't know how the whole sponsorship things works. You actually have to get permission to enter a race?
    Well yeah...
    Sponsorship is all about marketing.. if the sponsor deems your race will have little or no marketable value then they won't support you doing it....
    this is the double edged sword of being sponsored in that yeah you get free stuff but to a degree you have to base your riding to maximise exposure for the company you ride for, not really a big deal if you take the time to make sure the company you ride for has the same ideals as your riding.. in my case they do.
    surly and rigid
    Vicious Cycles makes a 135 fork. Don't know the price but they should be available.
    Ride = Life
    Reputation: racerxti's Avatar
    Black Sheep make a Steel and Ti 135mm and 100mm front fork. I love the Ti 135mm, which what I use. I purchased mine from Chain Reaction Cycles in AK.
    As for your rear wheel. You most likely will fit Snowcat rims on the back. Use the widest tire you can fit back there, maybe DH tire.
    http://www.allweathersports.com/winter/snowcats.html
    Interesting quote from Snowcat's website "In 200X Gary Fisher contacted us to ask if we would be willing to make a set of SnowCats for a new style of mountain bike he was considering building - one that had 29 inch wheels, but was not just a ‘sidewalk bike’. We told Gary “sure”, but we never envisioned anyone else ever wanting a pair."
    That should make your sponsor happy to know.
    "Riding is about rhythm and flow. It's the wind in your face and the challenge of hammering up a long hill…" - Gary Klein
