Fat Bike Rim Tape help- Mtbr.com
Results 1 to 20 of 20
    Sep 2014
    New question here. Fat Bike Rim Tape help
    I have purchased a Chinese make aluminum fat bike. This bike has 100 mm rims with side-by-side drilled holes on the front wheel and single holes drilled holes on the rear wheel. I am looking to replace the rim tape. The only source that I have been able to identify are from Surley and the widest tape available offered is 75 mm. My rims require 100 mm tape, does anyone know of a source for 100 mm rim tape?
    Reputation: BigVaz's Avatar
    Feb 2010
    Why don't you just overlap 2 strips?
    I know, I'm sure toy already thought of this...
    2014 TREK FUEL EX8 29er
    2015 TREK FARLEY 6
    Reputation: pspycho's Avatar
    Aug 2005
    The TOTAL Rim width is 100mm. You will not need tape that wide. My Fatboy has 90mm wide rims and I am using 64mm wide Surly Tape. It was a perfect fit. The rim strips/tape needs to cover the inside width of the rim (over the spokes and drillouts). That's about it.
    2015 Specialized FATBOY EC70 Seatpost & Bars SRAM X7/Wolf 42T 1x10
    2016 Specialized DIVERGE Expert X1 SRAM 1x11 Force
    Aug 2014
    No reason that tape wouldn't work since it's what they include on clownshoe rims
    turtles make me hot
    Reputation: NYrr496's Avatar
    I made my own rimstrips out of camo gorilla tape. You can make whatever width you want.
    I like turtles
    Reputation: Fat907's Avatar
    Jun 2014
    Be creative........glow in the dark Batman symbols
    Feb 2014
    I put the reflective tape found on semi trailers to my Fatboy.
    Looks great with the lights reflecting red & white.
    Added the tape to duct tape, placed in rim them added the factory rim strip to hold it all in place. One guy told me "oh man, that's too heavy, too much weight to add to your tires" It's a Fatboy not a road racer!!
    Here's mine next to another Expert, mine has Bluto & rim strips.
    In the pics you can see the rim strip with & without the flash.
    Attached Thumbnails Attached Thumbnails Fat Bike Rim Tape help-aug-30-2014-077.jpg
    Dec 2013
    Quote Originally Posted by pspycho View Post
    Any pics of the fatboy rim with the surly tape? Still happy with it?
    I want to change the color of my fatboy tape. Rather than adding weight I am thinking of just replacing the fatboy strip altogether. Suggestions welcome.
    Aug 2005
    Quote Originally Posted by matto6 View Post
    Here you go. I bought the 64mm Orange Surly Rim strips and have had no issues with them whatsoever. FWIW - I'm also running the lighter 2.3 - 3.0" Specialized tubes as well.
    Aug 2014
    If you ever want your "orange" Surly strip to be orange, not red, put a white Surly on it. ;o)
    Reputation: Drummerboy1975's Avatar
    Electrical tape works great.
    Nov 2012
    I'm looking to add some reflective tape from here:
    Identi-Tape - All Kinds of Colored Tape
    But as a noob to fat bikes, I have a few questions... How thin mil-wise can I go, and obviously - is the securing technique to just peel off a thin ribbon where the tape overlaps and press?
    Thanks. Yeah - this is ridiculously obvious to those who have done it, but rather than make noob errors, I thought I'd ask!
    This depends on your current setup. I've had good luck with simply applying the tape to the existing colored rim strip and reinstalling. My ideal solution is a sandwich of 3 tapes. Color tape followed by strapping tape, and then a layer of Gorilla Tape. If using tubes, then you can omit the Gorilla tape.
    It also doesn't need to be adhesive tape, you can use the sew on reflective trim, or any cool fabric designs you like.
    Jason
    Disclaimer: www.paramountfargo.com
    Nov 2012
    Jag - thanks for the quick reply - gives me something to work from.
    Quote Originally Posted by iCollector View Post
    I'm looking to add some reflective tape ... How thin mil-wise can I go, and obviously - is the securing technique to just peel off a thin ribbon where the tape overlaps and press?...
    Retro-reflective makes you the most visible, as it reflects light back at its source (headlights...).
    It's fairly thick, and some of it can be very stiff. To get it to sit flat against the back of the rim (to seal the tape to the openings), you may have to use a hole punch (paper size, or possibly leather punch size) to make a cutout in the retro-reflective tape for the spoke nipple. Which means another backing tape over the rear of the retro-reflective, both to cover the nipple hole, and to anchor the retro-reflective in place. Small pieces of tape to cover the nipple holes are fine, if the tape will stay there...
    A thinner strip of tape along both edges will hold it in place and seal it to the rim to help keep debris out.
    You only need the retro-reflective to be wide enough to cover the openings in your rim.
    I did a complete backing of Gorilla Tape (I now don't think this is necessary), then ended up cutting out holes for the nipples, and another small piece of tape to cover each nipple. http://forums.mtbr.com/fat-bikes/rim...es-726473.html
    There are other and better threads on doing this. Search.
    Nov 2012
    I searched "Rim Tape" my search didn't pick that up - story - I did do a search - not that much of a noob!
    Thanks for the link!
    My point is that there are other threads - better threads - than the one I gave the link to, with more first hand experiences posted. That's the one I can find easy. You might have to move to google to get more results from forums.mtbr.com/fat-bikes.
    Nov 2012
    Point taken thanks. I get myopic with this site as the basically the only one i visit!
    I thought I was being clear.
    Quote Originally Posted by Canoe View Post
    ... other threads - better threads - ... from forums.mtbr.com/fat-bikes.com
    As in, at this site, this forum.
    Just that the search function doesn't necessarily turn up the terms you entered, hence often better results using google to search forums.mtbr.com/fat-bikes.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Each time I've done "tape" for my cut-outs, I've simply cut little squares and taped them inside with minimal clear/scotch type tape, then I run a small narrow strip of gorilla over the nipples and two passes of clear packing tape. Everything is solid and due to the low pressures, no issues, heck, even held 40psi just fine overnight a few days ago stretching my new tires. You "can" use one continuous piece of tape over holes, but you don't have to, unless you are also making it the rim-strip for tubeless.
  1. Use Velox rim tape under Stan's tape in Flow EX rims?
    By zuuds in forum Wheels and Tires
    Last Post: 08-29-2014, 11:03 PM
  2. Replies: 30
    Last Post: 09-14-2013, 04:36 PM
  3. Gorilla tape OVER Roval tape?
    By freeriderB in forum Wheels and Tires
    Last Post: 03-19-2013, 05:54 AM
  4. Stans Tape. Tubeless tape. Info needed.
    By MasterOMayhem in forum Wheels and Tires
    Last Post: 03-01-2012, 12:55 PM
  5. Gorilla Tape in place of rim tape?
    By dexetr30 in forum General Discussion
    Last Post: 05-01-2011, 10:41 AM
Members who have read this thread: 4
