fat bike rear hubs- Mtbr.com
    Jan 2009
    fat bike rear hubs
    I guess I should have liiked down a few threads regarding frame vs hub spacing. but anyone know about 12mm vs 10mm bolt on vs QR?
    I am researching buying my first fatbike. I have a list of options for frames, rims cranks but what about hubs?
    Which fatbike use which rear hubs? And what axle diameter is being used 10mm or 12mm?
    I know the pugsley uses 135mm x 10mm
    But what about the others? Also for the frames running 12mm is it QR, bolted or Maxle?
    I love the Maxle setup (I have a maxle fork) but is anyone using it?
    I know that Vicious has done some custom maxle rear ends for people (not necessarially fat bikes) but I'm not sure about the other manufacturers.
    It would be worth a call to them if you are really wanting a maxle.
    Turner Burner, Polished
    Salsa Mariachi 2
    Salsa Mukluk 2 Custom
    Bucksaw - Future Ride
    meh....
    Reputation: Monte's Avatar
    all the fatbikes I know of (pugsley, fatback ti and al, 907 ti and al) use QR (10mm) rear hubs. i don't know if any of those hubs are convertible to 10mm thru bolt. the hadley might be, but i've never seen any convert parts for it. i doubt the others are convertible.
    12mm maxle? only one i've seen with that is THE custom Smoots built for mikesee.
    Fatback
    Reputation: thirstywork's Avatar
    The Fatbacks come with either QR's or a (convertable) bolt on for standard 10mm rear drop outs. Not a through bolt, but a bomber connection.
    Attached Thumbnails Attached Thumbnails fat bike rear hubs-fatback-hubs-resize.jpg
    Speedway Cycles owner http://fatbackbikes.com
