Fat bike front hub question (DT big ride)- Mtbr.com
Results 1 to 3 of 3
    I posted this on the wheel forum but will probably get more experience here?
    While getting my fat bike ready for the upcoming snow season, I noticed some side to side play on my DT Big Ride front hub. This was after I clamped it into my my Bluto fork. I have had the wheel for two years and it has around 980 miles on it. Pressing on the end caps with my hands, they stay centered, but without the pressure they are loose. I have increased the clamping pressure on the Bluto as much as is possible. Anyone have experience with this or similar and do you have a fix.
    Thanks,
    “How inappropriate to call this planet "Earth," when it is clearly "Ocean.”
    ― Arthur C. Clarke
    New end caps are cheap, but to me that sounds like worn out bearings. You need the 4 digit number from the side of the bearing and can get them at a transmission bearing supply shop for cheap, but you need a bearing press kit to install them. You can do it on the cheap with a socket and bench vice but if you put em in crooked the hub is garbage. Im a pretty good home mechanic but I pay to have bearings pressed in.
    FWIW posting my mistake; might help someone... I failed to tighten the RS maxle on my Bluto correctly.
    urmb
    ― Arthur C. Clarke
  1. DT Big Ride Front hub question
    By urmb in forum Wheels and Tires
    Last Post: 11-04-2018, 01:16 PM
  2. Replies: 1
    Last Post: 04-14-2015, 04:33 AM
  3. what width fat front rim for a front fat?
    By ifrider2 in forum Fat bikes
    Last Post: 03-21-2013, 06:20 AM
  4. My fat front El Mariachi \ Fat front review
    By rockcrusher in forum Fat bikes
    Last Post: 09-12-2011, 03:27 PM
  5. fat fat fatty fat fat fat
    By evilbeaver in forum Riding Passion
    Last Post: 12-10-2006, 01:23 PM
