Farley Low Gear Options?- Mtbr.com
Results 1 to 15 of 15
    Reputation: Inspector Gadget GPB's Avatar
    May 2005
    I have a Trek Farley 9.6 with a SRAM DUB GX 165mm crank (121mm spindle). Basically, I need to gear down the front so I can make a ďreasonableĒ attempt at Mount Washington in March; 30x50 is simply too big a gear for me on that climb. What are my possibilities? Iím not having much luck finding smaller direct mount chainrings with the same offset, hence the wide open question. Iím open to a different crank, maybe even a 2x up front to get what I need. Thanks in advance for suggestions.
    You know what I like about this place? They let you hurt yourself.
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    A 30?? Can you not find a 26 or 28 for that application?
    It looks to use the Sram direct mount standard so you should be able to use any Sram compatible DM ring.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    May 2005
    So far online, I canít seem to find the odd offset, -4mm. Everything seems to be 0, 3, or 6mm; nothing negative. Plus, Iíd really like to drop to a 24 if available. That leads to a follow up question. If I could find a 24t with a 0 offset, how much would that 4mm affect things? Iíll likely put <1k miles a year on the bike overall and half or less on that particular front ring.
    Reputation: sherwin24's Avatar
    Pretty sure you can just flip the chainring, so a 3mm would in essence also be a -3mm if flipped. That should be close enough.
    Rippin da fAt
    Quote Originally Posted by Inspector Gadget GPB View Post
    As Sherwin mentioned, flip the ring to move the offset as needed.
    Wolftooth stainless, BTI # WQ-1110
    49mm chainline and 24t
    Seems that's the only listing I can find in short order.
    Reputation: solarplex's Avatar
    Apr 2014
    My farley 9.6 with a raceface crank just has a normal ring flipped around.
    Fatbike, XC bike, Gravel Bike....
    Oct 2017
    Woolftooth makes a direct mount ring in smaller size. I have a 26t on my Farley.
    Jan 2009
    I'm not so familiar with this crank, but to be clear, do you need the chainring dished toward the frame (minus) or away from the frame (plus)
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Quote Originally Posted by sherwin24 View Post
    Ya, I have the same dub crank with the same chain ring offset on my blizzard and went with the 3mm and it works fine.
    Reputation: fishboy316's Avatar
    Jan 2014
    You may want to try a absolute black oval ring. I put one on my 7 and it really turned into a climbing machine. I went from 28T to a 30T oval. Within a couple weeks of using the AB I was climbing stuff I had a tough time with on the reg ring 2 gears higher. Really helped me.
    2013 Cannondale F29 1 Alloy
    2013 Cervelo S5 Rival
    2012 Trek X01 crosser
    2017 Trek Farley 7
    2017Trek Domane SLR 6
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    You can't flip SRAM DM rings.
    Nor do you need to -- there are 24 and 26t options out there.
    Reputation: screamingbunny's Avatar
    Ditto, unable to track down a -4 offset 28 tooth SRAM direct mount for my Farley 7. You'd think a 30/50 combo would be fine for climbing, but wow, the 27.5x4.5 wheels really stretch out the gear inches. Had to resort to ordering a Raceface Turbine crank, 28 tooth RF 3mm offset ring (cinch you can flipflop) and a new BB, not cheap but its the only way I'll be able to ride in the deep snow
    May 2005
    Minus, towards the frame. I'll also look into the flip idea. I was under the impression the SRAM rings might not be able to do that, but it's easy enough to try.
    cant flip sram direct mount
    Jan 2009
  1. Replies: 10
    Last Post: 01-12-2018, 07:58 AM
  2. 2014 Farley 2015 Farley 6 Fork Recall
    By PoshJosh in forum Fat bikes
    Last Post: 01-13-2017, 11:13 AM
  3. 2014 Farley 2015 Farley 6 Fork Recall
    By PoshJosh in forum Trek
    Last Post: 11-02-2016, 09:14 AM
  4. 2015 Farley 6 or 2016 Farley 5?
    By jgdblue in forum Fat bikes
    Last Post: 10-24-2015, 04:41 PM
  5. Replies: 4
    Last Post: 10-04-2014, 11:31 PM
