El Gordo Izquierdo- Mtbr.com
Results 1 to 27 of 27
    Reputation: ferrstein's Avatar
    El Gordo Izquierdo
    Or is it Izquierda? My Spanish is not so very good.
    Thought I'd share a few pictures of my El Gordo Build. A few things about it that I find interesting:
    1. I used the "narrow" Q-factor Sram X9 crank even though this is a 190mm spaced frame. I did this because I'm running a 1x10 and I didn't want to increase my Q-factor to Moonlander territory just to have the capability to run a 2x9 or 2x10 down the road. So, the crank is the standard Sram X9 fatbike crank.
    2. I used a North Shore Billet direct mount chainring, but I used a BB30 type, which places the single chainring where the big ring would go. This was necessary to get around the Lou tire on a Clown Shoe rim. I draped a chain over the sprockets/chainring and in low gear I'm quite close to the tire. Doesn't look like it'll rub, and the chainline looks nice with the 190mm rear spacing. It's 26t. Yeah, I know... I need to eat a few cans of toughen-up. It'll work for now.
    3. Speaking of low gears, I have a 42t Wolftooth cog on the back, with the 17t cog removed from a Sram PC1090 cassette.
    4. It has a Hope Fatsno 190mm hub with a steel freehub body. The bike is setup with the 197mm x 12mm axle. UPS says my bolt from the nice folks at Fatbikes.com is almost here. If I decide to ride it with the current nylon allthread and wingnuts in place I'll be sure to take a video for y'all.
    I'll post back as the build progresses. For now here are some pictures:
    I will say this: heel clearance is tight. I sat on it making "vroom, vroom" noises whilst clicked in and wearing my size 11 Shimano boots. Heels are very close to the chain and seat stays. No rubbing, though... even if I tried. My summer shoes are about the same.
    Nemophilist
    Reputation: TrailMaker's Avatar
    Exceptionally Sweet!
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Reputation: gcappy's Avatar
    Bravo! Looks great with the Lefty!
    aka bOb
    Reputation: bdundee's Avatar
    Love it!!
    Reputation: pucelano's Avatar
    Quote Originally Posted by ferrstein View Post
    Technically, it should be El Gordo Zurdo
    Reputation: Stopbreakindown's Avatar
    Want
    Thanks for the compliments! Looking at the pictures I'm thinking I'd like to black out that Lefty fork. Not sure how. Maybe a sheet of satin black vinyl decal material?
    Also of note that I forgot to mention - since the El Gordo is designed for a 483mm a-c fork, this large frame puts a stock length Lefty Max at about the perfect a-c length. It is at 500mm unsagged, and around 480-485mm sagged.
    Quote Originally Posted by pucelano View Post
    Now that one wasn't even on my radar. I knew there was a difference between direction and location... but I thought that only involved izquierda/o. I really haven't even mastered English as of yet, so I haven't done much with Spanish...
    Loser
    Reputation: Jisch's Avatar
    Nice looking bike. That would kill me having the bike that close to finished and not able to ride it.
    Lord Thunderbottom
    Reputation: TitanofChaos's Avatar
    The bike looks great, I'm contemplating moving to this frame with the X9 crank, can you snap a few pics showing the clearance of the crankarm/chainline/chainstays?
    Today I will do what others won't, so tomorrow I can do what others can't
    Quote Originally Posted by TitanofChaos View Post
    Will do. I'll wait until my thru bolt gets here. Turns out my weigh-saving 1/4" nylon threaded rod doesn't keep the rear wheel in position very well...
    Reputation: buckfiddious's Avatar
    I always wished I could build a functional mountain bike that looked that clean- no cables, no visible brake levers, no visible shifters...
    Trying to imagine wireless brakes...
    Like this?
    Heat shrink tubing.
    This right here is some tight clearance, Clarence!
    Pic of the chain in low gear, Lou Tire on a Clown Shoe rim centered in the frame. As mentioned earlier, that is a Sram X9 crankset with a NSB BB30 direct-mount chainring. Frame is spaced at 190mm. The chain is tight to the tire. This all wouldn't have worked on a 170mm spaced frame, and it wouldn't work with a 2x10 setup unless you went with the widest cranksets out there:
    Pic of the boot passing the chainstay. It is tight... but I do have the shoe rotated backwards quite a bit. Size 11 Shimano boot, clipped in. I do clip a bit "foot forward" compared to some folks, but I do have the cleats outboard on the boots as much as possible - which moves the boot in towards the bike as much as possible. I do this to keep the Q factor down. It clears but it is tight:
    Not a huge issue at the seat stay:
    Yes, like that! That is a beautiful Grape Ape right there. What diameter HS tube did you use? Do you have a good source? I may need to haunt McMaster's website later...
    McMaster's didn't have the diameter for it in black.
    I'm pretty sure I bought it from this guy:
    Heat Shrink Tubing Tube Diameter 50mm 2" x 1M 3ft Black | eBay
    Reputation: brankulo's Avatar
    Aug 2005
    you could spray it with black plasti-dip
    Lord Thunderbottom
    wow, that's pretty tight clearance, I'm going to have to wait and see the new 2x spider for the x9 crank before making a decision now, I want to maintain the double crank
    Yep. Ain't no way a 2x will work with this setup. To get a 2x around a Lou/Clownshoe you will need a Moonlander-specific crank or any of the wide Q cranks on the market.
    The camera flash makes things look tighter than they are. I have about 3mm between the chain and tire in low gear. I'm happy with it but my goal was to go really fat with the narrower Q factor.
    I am running a 3x10 on Marge Lites with Lou tire, 170mm spacing. In the smallest sprocket, largest cog it just clears the tire's whiskers. I couldn't pull it off with a Darryl or Clown Shoe. But if you guys want to run a lot of gears with a wide tire, I think this will be your only option (on the 170mm rear spaced frames).
    Pics from my maiden voyage. I ended up getting some stick-on vinyl and blacked out the Lefty Max fork. It doubles as cable rub protection. Other than having to dink with the b screw on the derailleur a bit it was rock solid. I love the geometry of this thing, it seems to handle very well. I'll need to go get myself into some dicey situations to know just what it's capable of.
    aka bOb
    Very nice, well done sir!!
    Get yourself a black top cap for the lefty. edit: you had one in the earlier pictures.
    What does the build weigh?
    Lord Thunderbottom
    Quote Originally Posted by Bacons View Post
    can you post some pictures of this for us to drool on? Thanks!
    Quote Originally Posted by bme107 View Post
    Good eye sir! I was hoping nobody would notice. The first fork pictured was fresh from Mendon Cyclesmith with a new PBR damper installed. That fork ended up on my Niner RIP9. The fork I'm using now is a stock Lefty Max TPC with some travel limiting. I don't have any black top caps for that configuration.
    Not sure what it weighs. I don't have an accurate scale. I think it weighs a bit less than a Buick...
    Seriously, though... I will see if I can figure out a reasonably accurate way to weigh it.
    How you liking this bad boy? Any other fatties to compare it to with regards to performance?
    What is the weight?
    Looks great!!!
    Iím hoping the Original poster can help me here! Looking to purchase an El Gordo but Iím afraid of joint pains with 197mm spacing on the rear hub. Is it too much with Q factor With the 100mm BB? Iím also worried 177 is being phased out. And I canít find cranks compatible with the 100mm BB and the 197 rear hub spacing. Any advice?
  1. Ventana El Gordo
    By Tripower in forum Fat bikes
    Last Post: 12-07-2015, 03:04 PM
  2. Gordo, you were born too soon.
    By canyonrat in forum 29er Bikes
    Last Post: 01-20-2014, 11:40 PM
  3. 48h 26" Gordo X where to get some?
    By jamesabaldwin in forum Salsa
    Last Post: 04-03-2013, 07:12 AM
  4. Which Rim:Salsa Gordo or Sun-Ringle MTX 33??
    By Winky in forum 29er Bikes
    Last Post: 01-03-2012, 12:45 PM
  5. Gordo 29'er
    By rodeoroll in forum Salsa
    Last Post: 03-18-2011, 06:45 AM
Members who have read this thread: 17
