Eagle chainline issue on Farley- Mtbr.com
Results 1 to 5 of 5
    Aug 2019
    Hey folks, here's the scoop:
    Frame: 2020 Farley so 121 BB shell and 197 rear spacing.
    BB: Pressfit DUB 121
    Crank: SRAM FAT5
    Spacers: 2mm outer non drive, 6mm outer drive side per SRAM
    Cassette: GX Eagle normal 12speed
    Rear Derailleur: GX Eagle
    B Screw: Set with red tool just to avoid that being an issue.
    Issue:
    Chainline seems way off. Looks to be dead straight on the smallest cog, so by the time I get up to the two largest I have way to much chain angle. enough where a couple pedal rotations actually pulls the chain off the chainring. Shifts well in all other gears though.
    What am I missing?
    fat guy on a little bike
    er... i thought the farley had the fat4 crank? All my friends bikes do, rigid or full squish... maybe that is your problem?
    Quiver:
    2016 Surly Wednesday
    2017 Lenz Fatillac
    2019 Lenz Fatillac
    Aug 2019
    Rigid. Trek shows FAT 5 on the website and in their tech docs.
    Attached Thumbnails Attached Thumbnails Eagle chainline issue on Farley-farley.png
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    What off set do you have on your chainring?? -4mm should be the fat5...
    I am pretty sure the Fat4 and 5 and the same cranks but different chainrings... if you order the +6mm you will gain the 10mm needed to correct your chainline.
    https://www.worldwidecyclery.com/pro...unt-6mm-offset
    Reputation: CanuckMountainMan's Avatar
    Oct 2018
    Both my new 2020 Farley's (7 and 9.6)
    have a pretty extreme angle on the hanger on the Big 50
    (SRAM 11-50t NX Eagle with 30t Fat 5 Crank)
    When on the next gear down (42?) it almost looks normal.
    I wonder if Trek kept the same chain length when they went from 11-42
    My 2018 Farley 7 with SRAM 11-42 cassette and 28t Race Face crank never had a problem.
    The derailleur arm angle on the new Eagle NX looks much better just one gear down from the 50 (42?)
    I haven't had any shifting issues.... yet.
    Attached Thumbnails Attached Thumbnails Eagle chainline issue on Farley-50v42.jpg
    2020 Farley 9.6 Matte Olive
    2020 Farley 7 ROARange
    2018 Farley 7 Viper Red
  1. Remedy 8 and gx eagle chainline issue
    By Fuse6F in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 1 Week Ago, 10:54 PM
  2. Converted 2x Tallboy LT to Eagle chainline issue
    By Santana SS in forum Santa Cruz
    Last Post: 10-31-2018, 07:30 AM
  3. Replies: 10
    Last Post: 01-12-2018, 07:58 AM
  4. Replies: 4
    Last Post: 10-04-2014, 11:31 PM
  5. GXP Chainline chainline issue...
    By notenoughtime in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-11-2008, 08:02 AM
Members who have read this thread: 47
