DT Swiss Hub Upgrade time - Pawl to Star Ratchet- Mtbr.com
Results 1 to 44 of 44
    Reputation: JeepRage's Avatar
    Oct 2017
    Just posting to share my recent experience, blowing my Novatec hub on my 29er and upgrading to a DT Swiss 350 star ratchet hub. I then swapped to the 54 tooth ratchet and went from 20 degrees to about 6 degrees of engagement. WOW, truly an amazing transformation and makes my forced upgrade/replacement hub worth it.
    So I got to thinking and began researching converting my fat bike (DT Swiss 370 hub on the Canyon Dude). Although it has a 3 pawl system, I found a fantastic video of a guy showing how to swap in a 240/350 ratchet drive. Parts are on order to make the fatty a 54t star ratchet as well.
    I just never considered something so small would impact my riding that much. Anyone else notice drastic changes with increased points of engagement? I ride very technical roots and rocks for what its worth.
    Video: https://www.youtube.com/watch?v=e_XpRZCLTX4
    2017 Santa Cruz Tallboy C 29er
    2018 Canyon Dude fatty with Mastodon
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    When the engagement point count goes up, the ride improves immensely.
    I have 108 point engagement on one bike and an Onyx sprag drive on another. The sprag is near zero lash engagement and makes 108 point seem sloppy. The difference on the trails is an outstanding ride experience as opposed to an average experience. With power more accessible, clearing a section becomes more enjoyable and easier.
    20 degree would be horrendous, indeed
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Some people notice the difference, some don't. Some think the difference is important, some simply don't care. Sounds like you're in the former camp on both.
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Quote Originally Posted by mikesee View Post
    It's a very interesting observation!
    I was in the firmly in the 'Care' camp, and made a conscious decision to get i9 hubs for my plus bike build and I loved these when I got them. Fast forward 12 months, I did a wheel building course and laced up a wheelset for my Fatbike with DTSwiss 350 and standard 18t ratchet.
    I straight out thought that it was going to be awful with such low engagement, as when I ride the fatbike on the beach, its usually very technical rock crawling that frequently needs half pedals and the like. I was thinking I'll goto the 54t in the near future, as the fat hubs that were being replaced, were 36t.
    What I found, was that I don't/didn't notice. Or at least not to a point where it is causing me not to clean lines that we are trying. In fact, I prefer the 'reliability' that it may be offering; at one steep sharp climb I try, the hub see's full force on the pedals as you stall out in 1st grear, would a 54t hold up to that, time after time? Who knows? And the beauty is that if it did fail I could be back running in 5 mins if needed.
    Forward another 12 months, and I have built another 350 into my Salsa Vaya wheelset, I again don't notice the 18t engagement and in fact am now moving into the 'Don't care' camp.
    I am not saying I am right, just that it's not something that I think about when out playing about on the bike anymore!
    What camp are you in, Mike??
    Jun 2013
    Care camp - I just got a new to me Yeti SB5.5 with a 18t DT350 hub. Coming from Hadleys with 72 POE of my other bikes I notice the difference right out the gate, and negatively in techie sections. 54t upgrade kit is on the way.
    Also care camp....many years ago, I had to replace a wheel, the new hub had 36 poe vs 18-ish(?) of my previous. At the time, poe wasn't something that I thought of or even understood to be an upgrade. However, once I started riding in techy terrain (Moab) it was obvious. It was almost as if my brain subconsciously knew that ratcheting the pedals back while going up and over rocks (to avoid strikes) would suddenly be a useful thing to do.
    Now, lower poe bug me.
    Reputation: roughster's Avatar
    Dec 2017
    I've now blown out two Novatec hubs. Replaced both with DT Swiss 350 Big Rides. Absolutely love them!
    Strive CF 8 / Farley EX 8
    2020 Dry January 2020 (success!)
    2020 FTS 2020 (success!)
    Nov 2015
    Quote Originally Posted by roughster View Post
    How did those Novatecs broke? I had one cracked freehub body in mine, but with a steel freehub those seem quite robust.
    Dec 2017
    Quote Originally Posted by solisti View Post
    Both in the exact same way. Climbing a steep rocky chute which requires throw down power. CRACK!!! And then I could pedal in either direction with no resistance. No cracks on the hub body, just destruction of the pawls inside.
    Oct 2017
    Pretty similar to mine, though I was at the trail head after riding to the park, and when I pushed off the crank just spun. I didn't even take it apart to inspect, but the shop mentioned cracked by the bearing, which he hadn't seen before. I knew it was toast and ready to upgrade regardless.
    Aug 2003
    Quote Originally Posted by Flying_Scotsman View Post
    Don't care. Not even a little. I have DT hubs with 18t ratchets on 3 of my 4 bikes. Onyx on the other, because I like the less harsh engagement for maintaining traction when snow and ice riding.
    rth009
    May 2010
    I just recently started riding a pair of DT 350s with the 54t star ratchet. I did not purchase the 54t, but bought a used set (that I was told originally came from mikesee), and while Im not yet sure if the engagement is necessary to me, what I do like is the sound they make when free-wheeling. Its a bit louder than 18t DT (from my limited experience), but more than anything, it just sounds like quality and makes me happy.
    Aug 2003
    Quote Originally Posted by rth009 View Post
    54t are definitely pitched higher than 18t. Might be louder too.
    I don't care for any noise when coasting, but I can see where the more the merrier for some.
    rth009
    May 2010
    I've got Griz to deal with, so the louder the better.
    I would not call the 54t DT 350 particularly loud, not as loud as a Hope, but it is louder than some.
    Rippin da fAt
    You want an obnoxious hub? Older Hugi fills that position!
    But they can only hear you when you are coasting.
    Latitude 61
    Reputation: Redlands R&C's Avatar
    Dec 2013
    Quote Originally Posted by BansheeRune View Post
    Boom! Yes, this is a loud hub. I had an even older (stupid me for selling it) Hayes/Hugi hub, that thing was ridiculous.
    Silly bike things happening.
    Rocks belong
    Quote Originally Posted by JeepRage View Post
    For the record, this video was great.
    Too bad all of the parts and tools required to do it are what a new DT350 star ratchet hub costs
    I like 'em long, low, slack and playful
    Rippin da fAt
    Quote Originally Posted by Redlands R&C View Post
    I still have a pair of em with the logo in red. Noisy enough to wake the dead!
    Feb 2006
    All of my bikes spend some time on the paved trails/paths, for various reasons...I love the loud freehub noise because I find it better to just stop pedaling and let my freehub do the "on your left" talking for me. Works like a champ. Love the Onyx to, my best bud has 'em on his fattie, sweet hubs, but I find noisy hubs useful so I'll always have 'em, and I do not care about points of engagement, at all.
    rth009
    May 2010
    Quote Originally Posted by sryanak View Post
    But blasting downhill in thick forest is when I need the noise to let them know I'm coming. When I'm grinding uphill at slow speeds the Griz can smell me or hear me grunting and belching my barbaric yawp over the hills of the world.
    Rippin da fAt
    Quote Originally Posted by litespeedaddict View Post
    If it weren't for trials, I likely wouldn't care about engagement however, 108 point spoiled that. Don't really care about SPL from a rear hub, so long as it engages sooner than later...
    Reputation: Mudguard's Avatar
    I have a pair too. On my old Enduro SX. I'm always shocked how loud that bike is.
    Rippin da fAt
    Can't beat the durability, despite the louder than a jackhammer driver!
    So, so loud.
    Reputation: EOS_'s Avatar
    Dec 2012
    Just read this thread, I am also thinking about upgrading to DTswiss 350 ratchet hub. Beside the engagement, sound etc. did you also feel any difference in how well the hub spins? Is there any difference in how easy the ratchet hub turns vs. a 3-pawl hub? Does it save any "watts", or is it neglegeable?
    Thingamejigger
    Quote Originally Posted by EOS_ View Post
    You are not going to be able to tell the difference when coasting from a pawl to a star ratchet, assuming all your bearings are free running. However, the fact that some freehubs are loud and the 18t star ratchet is near silent; those loud hubs are using your kinetic energy to generate said sound, and therefor reducing your ability to maintain speed, it's going to be a tiny part of the loss but still there never the less.
    Jun 2014
    When I upgraded to the DT Swiss 350 hub from a Salsa hub I thought I would notice the 18t engagement but I quickly forgot about it. Plus it's quiet. I might someday try a 36t for a compromise between the 18 and 54.
    Reputation: bikeny's Avatar
    That's pretty neat, I didn't know you could convert the 3 pawl hubs to star ratchet hubs. 06HokieMTB is right though, the cost of the tools and required parts are likely to cost more than a new hub. But, if you buy a new hub, than you have to have the hub laced to your wheels, which can be pricey. It's still great info and if you have some of the stuff already, it's well worth swapping to the star ratchet for reliability and ease of maintenance.
    As for the POE argument, I'm kind of in the middle. I have DT hubs on all of my bikes, some are still 18t and some have been upgraded to 36t. I notice the difference at first when switching between them, but quickly adjust and it doesn't bother me. I do think it's an advantage on really techy trails though, and have the 36t on the bike that gets used for that. The singlespeed I'm building up will also have the 36t ratchets. I'd like to try the 54t, but have read about some durability issues, so I'm not sure I want to deal with that.
    Edit: Actually the tools can be had on Ebay for under $15 each, so not expensive at all. No, they're not actual DT Swiss tools, but they will work just fine and be fine for occasional use.
    Oct 2017
    I did not notice any difference is free spin, other than louder (mostly to others riding with me that heard it vs me being in front of the rear hub). I went 54t and immediately noticed the POE improvement. I ride North East with many many roots, tech sections, old farm rock walls, etc. I won't go back to a lower engagement hub.
    I bought the tool on ebay for little money. The 54t upgrade would have been money I'd have spent whether I bought a new hub or upgraded the 370, so that was not a factor to me. And because I didn't need to rebuild a wheel, I did this myself in 20 minutes.
    Apr 2017
    I had my new carbon wheels built with Onyx Racing hubs. To me, the difference in feel, control, ride, and rolling resistance is like night and day between these new wheels and the "decent but not exceptional" OEM wheels my 2017 Specialized Fatboy Comp Carbon was delivered with. It feels like I just bought a whole new bicycle...
    G
    Reputation: rammalammadingdong's Avatar
    Novatec Aluminum bodies are the problem. If you ask your carrier to up/downgrade or just sell you a spare Steel body they donít kerplode.
    At any rate, the DT Swiss ratchet system is so awesome to work on.
    Wipe it down, regrease from time to time - 5min job max.
    Here is a video of how simple that process is
    https://youtu.be/ouSzeR3ExO4
    Dec 2012
    Thanx for all the info. So star ratchet system is mainly about durability and easy servis. When it comes to free spining, rolling resistance when coasting, there no significant difference to pawl hubs. Only with 36 or 54t compared to 18t: more teath = more drag so there will be a bit more resistance.
    rammalamma, in that video, the only thing that guy did was cleaned and regreased the ratchet rings and his free hub then was spinning so much smoother? He did not change/upgrade anything?
    Uh, no.
    Points of engagement - not drag.
    The more teeth, the faster it engages.
    There is no more or less resistance if both ratchets have same amount of grease on them. The 18t had a bit more than the 54 in the video
    Nov 2014
    FWIW I have noticed that my 54T 350 hub is quietin the winter with the thickening of the grease.
    Another benefit of the DT system is that you can swap the cassette to another wheelset very quickly if both wheelsets are DT.
    This is going to come in handy for my 27.5+ wheelset; I won't have to buy another 54T ratchet or steel freehub (or microspline freehub eventually)
    I also carry my original 18T in my pack just in case; can't do that with other systems.
    DT Swiss Hub Upgrade time - Pawl to Star Ratchet-7266269e-4685-4df2-9d30-ad6be400773d.jpg
    Summer or winter, if you are experiencing a quiet freehub, the engagement face is supposed to be DRY.
    The cog teeth on the outer edges and the receiving teeth in the hub and hub body are where you place the grease.
    NOT the engagement points.
    Thatís the last place you want slippery
    Quote Originally Posted by rammalammadingdong View Post
    What? Am I reading that right? The engagement teeth needs the grease, DT will tell you this. They will be noisier without grease.
    Also, I can't believe any recreational mtb'er would be concerned with coasting friction.
    Aug 2003
    This is inaccurate.
    You definitely lube the engagement face -- like little glazed donuts.
    Aug 2003
    Uh, no.
    My evidence is only anecdotal here, but I've always felt that 54t coasts/slows down faster. Subjectively feels like a substantial difference.
    Nov 2014
    Subjective wheels spin testing seems to agree
    I'll reiterate what others have said, you most certainly want some grease on the engagement teeth! If you put too much on, they con't engage properly, but they need a thin coating.
    Reputation: akacoke's Avatar
    i went from 18t to a 54t night and day difference. and it helps a lot on climbing and slow sections. besure to grease the star ractchs only a thin coat DO NOT let them run dry
    17 Lynskey Fatskey
    07 Kona Stab
    14 Specialized Fatboy
    04 Santa Cruz V10
    My Ebay store link
    Reputation: solarplex's Avatar
    Apr 2014
    My lbs owner/mech and i use a light oil on our ratchets. Only downside is it flings out and your hub and spokes get dirty.
    Ive had zero issues. Pulling the ratchets out they still have a light coating of oil.
    Fatbike, XC bike, Gravel Bike....
    Quote Originally Posted by solarplex View Post
    What is the 'upside'?
  1. DT Swiss 3 Pawl 370 Hub convertible to Star Ratchet
    By RiderofPA in forum Wheels and Tires
    Last Post: 12-16-2019, 10:29 AM
  2. DT Swiss 36T Star Ratchet Upgrade - $30 shipped!
    By skinner2909 in forum Wheels and Tires
    Last Post: 03-18-2016, 01:01 PM
  3. DT Swiss 36T Star Ratchet Upgrade - $30 shipped!
    By skinner2909 in forum 29er Bikes
    Last Post: 07-17-2013, 02:43 PM
  4. DT Swiss 36T Star Ratchet Upgrade - $30 shipped!
    By skinner2909 in forum General Discussion
    Last Post: 07-17-2013, 02:04 PM
  5. DT swiss 36 star ratchet upgrade Pros and Cons
    By Ace5high in forum Wheels and Tires
    Last Post: 07-02-2013, 08:06 AM
Members who have read this thread: 194
